20 Most Recent ASUS Notebook N75sf-dh71 17.3inch Intel Core I7-2670qm 1tb 8gb Gt555m Retail Questions & Answers
Tip
Asus A32-N55 battery
Laptop battery waste, can be reused for the light bulb!
Even if a computer that had been used by pleasure favorite, I know the case that Asus A32-N55 AC adapter around is forced to had made facing a lifetime. But be that wasteful Continued throw away the battery of lithium-ion rechargeable battery!
In the "DEV 2014" conference, which was held last week in San Jose, California, IBM Research India has been announced about the possibility. According to them, out of the laptop battery to be discarded, 70% is still so I'm sufficiently available in other applications. The project, which promoted the institute of Smarter Energy Group and RadioStudio jointly, remove the good rechargeable battery cell of degree from among the waste battery, and only cells that can withstand use to create a new IdeaPad G570 - compatible battery. And that field test results of the idea to finish in power for the LED light bulb has been unveiled.
In order to produce a usable bulb in places where the infrastructure of the electricity not Seiwa most expensive part is the battery. However, in the present project, the object of the largest power ensure has come to be covered by waste. A new regeneration method of utilizing old ASUS K55VD notebook PC battery only did not discarded, Vikas Chandan Mr. researchers IBM Research India that was introduced in this wind. He, the supply of electricity towards the area where no stable, although some solutions to develop and reusable bulb with a combination of the solar panel and battery, after all the less expensive better approach to reuse the waste battery efficient It pointed out has to be it. Just in the United States, even taking into account the actual situation in which the computer amounting to annual 500 million units continue to be discarded, and is to effectively take advantage of the things that can be used from within the, but it makes sense.
In addition, finished playing ASUS N75SF battery, already in such stalls lined up in the streets of Bangalore, it seems to be utilized in practice as a power source for LED light bulb. Moreover, that's pace to be lit every day for four hours, lightly one year has the potential to continue to use and is Toka I are good evaluation. While reusable, because it has a power unexpectedly seems to proceed smoothly addition to the development of LED bulbs next generation model of increased brightness.
By the way, IBM If ride this project is on track, while promoting the recycling of waste laptop battery going discarded, seems have been announced a policy to continue to donate to the developing countries. In which Japan, I might be the flow of the PC battery collection and recycling is gradually fixed by these applications ....
Any adapter and cable for charging the same?
The charging of the battery, it's basic is to use the AC adapter and USB cable. There are many commercially available in addition to the genuine products, but it is not may use any.
AC adapter voltage terminal needs, need to be able to supply current. Only reason that because the connector of shape is connected the same, to use an AC adapter other than the one that comes with the product, it might be possible, it is not recommended from the point of view of trouble prevention. It's safer is to use accessories or genuine. Cables to be used for charging even when a large resistance value, it may not be possible to supply a voltage or current required by the battery for ASUS M70SA - compatible.
In the editing unit to try, in case you are connected by USB cable and when you connect with accessories USB cable not supplied, I tried to experiment whether the difference in current is generated (Figure 1). As a result, the current value is about 0.2A, was small it is a USB cable of non-accessory. If you feel the charge of the battery is slow, it is advisable to see if may be checked using the appropriate AC adapter and cable.
Alienware M11x In the case of long-term unused rechargeable battery or AC adapter is firmly plugged into the connector on the computer back or side, please confirm that you are not missing power cord.
In addition, even if the AC adapter and power cord is connected, if it is to use and OA tap, there is that the power supply is unstable. Please check if you can solve by connecting the power cord to the problem of directly to a wall outlet.
Since the battery has a natural discharge even in unused condition, and allowed to stand immediately after the state and the battery purchase a long period of time, it may not be able to recognize the ASUS K75V PC battery. If it was a state of long-unused battery, remove the battery once from the computer, and then start only in the AC adapter. Please check whether the computer is charging by mounting the battery from the start is started.
http://www.bizcentral.com/listapp/post-3400.htm
http://listapp.70623.x6.nabble.com/-td4.html
ASUS A32 N55 PC ASUS N75SF AC PC ASUS M70SA ASUS AC ASUS K75V
on Jun 11, 2015 | ASUS Notebook N75sf-dh71 17.3inch...
If you hit full screen on the youtube video and its not full screen, then it sounds like your monitor resolution is to low.
Rt click on a place on your screen and pick screen resolution, then pick resolution and increase it.
The first number is width, so say it's on 800x600 then go 1024x768
ASUS Computers &... | Answered on Feb 23, 2021
You can use PLEX install on PC and Google TV or try AVIA or Media House through google play
ASUS Computers &... | Answered on Feb 18, 2021
https://www.youtube.com/watch?v=uL97XhontSo
ASUS Computers &... | Answered on Feb 14, 2021
1. Restart the laptop PC and press repeatedly [Esc] on bootup to open Boot menu.
2. Select the optical drive (may be labeled as "CD/DVD").
3. Press [Enter] to boot from the CD/DVD.
ASUS Computers &... | Answered on Jan 07, 2021
John, most monitors made have no service guide.
all are different, every brand and every model
some of this thin devices, like this are snap apart
and some are glued (using glue not unlike "stickynotes"
they do that also to make it water proof (limited) so that makes it super hard to repair, just like many notepads,
or both. they are all very tricky to work on, (that is the price for thin)
the users manual at asus has no facts here.
nor do they list a service manual on it. (sad)
google for it or youtube it is the only way.
ill looked on youtube, see nada
buy dead one on ebay,learn to take the dead one apart first
then work on yours.
other than that, call ASUS, ask for service manual
or google all week,
ASUS Computers &... | Answered on Dec 21, 2020
ok my PC in south american beach house.
has no @ key
nor do any of their internet cafe's
spanish keyboard, has non.
so we use the alt 64 trick
see next post for that.
but the kboard needs a right side keypad to do that
if not ouch get one, usb and plug it in.'
the top row of numbers on a keyboard can not
do the 6 4 strokes, only a working keypad right side.
I can not see you PC. nor country sold. so can not be more accurate.
this trick is from IBM, the first PCs did this too.
Thanks to IBM. (and the complex scan coded keyboard)
ASUS Computers &... | Answered on Dec 14, 2020
Wait until the installer prompts you. The generic mouse driver in bios is not good for the mouse you are using.
ASUS Computers &... | Answered on Nov 08, 2020
I just had a similar problem with the same Asus model. It drained the battery yesterday and today wouldn't start even after charging for 15min (the middle light was on so it was charging). The light bulb light was on though even when it wasn't charging. Tried pressing the button several times. Didn't help. Tried holding it for several seconds. Didn't help. But when I hold the button for around 30sec the light bulb turned off. And then another press and it turned on as normal. So the laptop must have been hibernated/sleeping. But it did give me a heart attack, especially when I realised that I will have to take it to Currys for repair where their very unknowledgable KnowHow don't know how to fix anything (send a laptop three times and still didn't fix the problem, they only know how to install software updates).
ASUS Computers &... | Answered on Sep 24, 2020
Watch this YouTube video which explains how to replace the screen.
ASUS Computers &... | Answered on Sep 15, 2020
Via a cable, with an SD card, you could also email a copy to yourself if you set up email on your android tablet. There are many ways to do it.
ASUS Computers &... | Answered on Sep 02, 2020
check the power management options, UNDER settings and or control panel - you will be able to see the time like minutes and secs of the options to sleep and wake up
ASUS Computers &... | Answered on Aug 30, 2020
I think it is running a test mode. Some kind of button pressing combination might free it from this.
It might go away if you can plug it into a vga source (pc, laptop) and hopefully change it from there.
Good luck.
ASUS Computers &... | Answered on Jul 08, 2020
Try reseatting the DVD/CD drive also reinstall the DVD/CD driver.
If this does not fix the problem then most likely the DVD/CD drive is faulty and then needs to be replaced.
ASUS Computers &... | Answered on Apr 17, 2020
I use VLC Media Player. It works great and it is free! Go ahead and Google VLC and it will lead you to this site:
http://www.videolan.org/vlc/index.html
Hope this solves your problem. I assume you have Windows 10 at this point.
Kind Regards;
Craig in San Diego, CA
ASUS Computers &... | Answered on Mar 24, 2020
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
ASUS Computers &... | Answered on Mar 14, 2020
ASUS Notebook N75sf-dh71 17.3inch Intel Core I7-2670qm 1tb 8gb Gt555m Retail Logo
1 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
asus p5sd2 vm multimedia audio
  • Computers & Internet
