20 Most Recent Denon AVR-2311CI 7.2 3D Home Theater Receiver Questions & Answers
Check the supply line and circuits to the display.
Could be cold solder joint, rectifier or capacitor.
check also if there are resistors in series.
Denon AVR-2311CI... | Answered on Feb 25, 2015
This will depend on the Blue ray player and other equipment. For a direct connection to the receiver, if your player has either type of digital audio output (coaxial or optical), get the appropriate cables. Then connect the chosen cable between the Blue ray player and the receiver. Connect the Blue ray player to the TV with an HDMI cable. See page 10 of the manual, available at http://pdfstream.manualsonline.com/6/69f43064-f593-49b8-8d4a-23174b496e65.pdf , to see the connections for the audio sources. (I'll assume your Blue ray player doesn't have component video out or you would use the component audio to the receiver.)
If your player doesn't have a digital audio output, check your TV audio output. You can get the same result by sending the videos via HDMI to the TV and using the TV audio out to the receiver. Set the audio source to TV and leave it there for both TV and Blue ray and DVD videos. (Sometimes there could be a slight delay in the audio compared with the video signal when you do this. I've never noticed it with my Blue ray player signal going to the TV and the TV digital audio out to the Denon receiver.)
If you can't send the audio out to the receiver from either your Blue ray player or TV, then you will need some sort of HDMI audio extractor. You can find models with Analog Audio Out, Digital Audio Out or both. ( https://www.amazon.com/J-Tech-Digital-Extractor-Converter-JTDAT5CH/dp/B00BIQER0E lists units with both types of audio output. One models requires a 3.5 mm to RCA audio adapter.)
I hope this helps.
Denon Audio... | Answered on Aug 08, 2020
After you have set your clock time simply just hold down memo button and I goes to minutes and click memo once to save your chosen time.
Denon Audio... | Answered on Apr 29, 2020
I expect your tuner/amp has a fair number of ultra sensitive CMOS devices inside and a power surge is likely to be instant ***** for them - if the surge reached them.
Any piece of equipment that has a computer inside really should be protected by an anti-surge device.
Your Denon tuner/amp is a bit of really premium equipment and I advise you it is best to entrust it's resurrection to a Denon approved repairer.
Denon Audio... | Answered on Apr 26, 2020
Welcome to the most diverse technology & Telecommunication products provider in the US. We are the official partners of Plantronics, Logitech, Jabra, Gai-Tronics, Panasonic, Motorola, HIKVision, LOREX, RCI and UNIDEN technologies https://www.telegiants.com/
Denon Audio... | Answered on Feb 22, 2020
if you want to set your playback speed exactly right, you need a test tape with a test tone on it (3khz for example). now you hook a frequency counter to your tapedecks output and set the speed accordingly.
Denon Audio... | Answered on Feb 11, 2020
https://searchmanuals.net/search94-sh/?keyword=%2Bdenon+%2Bmanuals&msclkid=7df6682623ae12d6f4d035cf55d9e058
Denon Audio... | Answered on Dec 05, 2019
I find the best way to connect any equalizer is to connect via the tape monitor sockets, assuming that the AVR has one. From the equalizer in and out sockets - connect the Eq OUT to Tape IN on the AVR. And Eq IN to Tape OUT on the AVR.
Some AVR don't allow connections, due the equalizer interfering with Surround Sound systems. If you can connect switch off the equalizer when listening to Dolby or other surround formats, as it will spoil the sound.
Denon Audio... | Answered on Oct 12, 2019
Denon AVR-2311CI 7.2 3D Home Theater Receiver Logo
3 questions posted
Popular Products
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Audio Players & Recorders
Most Popular Question
avr 2311ci display
  • Audio Players & Recorders
