20 Most Recent
Boston Acoustics TVee Model 25 Sound Bar and Wireless Subwoofer Blac Questions & Answers
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process.
Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com)
Using Pre-Programmed 3-digit Code method
-Turn on soundbar
- Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit.
- Point remote control toward the soundbar and enter code (447 for Boston Acoustics)
- Press the device button again to store the code.
The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me.
Step 2: Program your remote from the Boston Soundbar.
- Press the power button and the volume up button simultaneously until the indicator light flashes orange.
Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming.
- Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange.
- While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed.
- Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote.
Good luck, I hope this helps. -Deidre.
Boston Acoustics Solo volume knob stopped working altogether. Turning it either way does nothing, no volume number appears. Soft reset doesn't fix it. Any thoughts?
I don't know if you will see this or not, your post was 2 years ago. I have the same problem. My volume is stuck at 24. I have tried soft-reset........among other things. One thread says to turn volume down to 00 then press for 10 seconds. I have no control over the volume, so, yeah, thanks for that fix. I found that I could get the volume down by unplugging it,plugging it back in and sometimes the volume would pop up and I could turn it down one notch. I did it till I got to 00.............thought AHA! My problem is solved! No such luck. When I press the volume at 00 and try to hold it for 10 seconds, after 3-5 seconds it just pops back to the station frequency. I also thought that if I could get into the guts and spray the volume control with tuner-cleaner, it might help. No go.......after taking off the cover, I found a bunch of REALLY delicate looking electrical tapes and wires..........I was scared I would destroy something in an attempt to reach the volume control. I hate to trash this radio, the sound is awesome...............great design on the speaker, NASTY design on the controls. I'd be VERY interested to know if anyone, anywhere, has found a fix for this. I think maybe my next step will be hitting it with a hammer.
