20 Most Recent Onkyo HT-R560 Receiver Questions & Answers
Hi Richard please try the following reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings., Thanks, JT
Onkyo HT-R560... | Answered on Jul 31, 2015
Did you check the manual? Seems it has auto off features
https://www.onkyo.ca/wp-content/uploads/2019/08/SN29403450_TX-RZ730_En_180518_web.pdf
The Mini Player is always displayed. "Auto Off": The Mini Player turns off automatically in 30 seconds after displayed. If operation such as changing the volume is performed, it is displayed again for 30 seconds
Onkyo Audio... | Answered 2 days ago
Does the display show you are in protect mode , or is a light indicating that? The unit automatically switches to standby when the
"Hardware" - "Power Management" - "Auto Standby"
setting in the Setup menu functions are set. The protective circuit function may have been activated.
If this has occurred, "AMP Diag Mode" appears on the
display when the unit is turned on again, and the unit
enters diagnostic mode. If the results of the diagnosis is
that there is no problem, the "AMP Diag Mode" display
disappears and you can use the unit normally again. If
"CHECK SP WIRE" appears on the display, the speaker
cables may be short-circuited. Make sure bare speaker
wires are not touching each other or the back panel of
the unit, then turn the unit on again. If "NG" is displayed,
immediately unplug the power cord from the wall outlet
and contact your dealer.
• The protective circuit function may have been activated
because the temperature of the unit rose abnormally.
If this happens, then the power will continue to turn off
after you have turned the unit on again. Make sure the
unit has plenty of space for ventilation around it, wait for
the unit to cool down sufficiently, and then try turning it
on again. This is out of your users manual.
General suggestions are to remove all speakers and speaker wiring with unit off. Turn on and see if problem has stopped. If not, let unit cool down if warm and try again later. If problem is still there it needs repair shop work. I fht problem went away, shut off power and connect one speaker at a time and testing. Keep adding speakers one at a time with power off and see if a bad speaker or wire set can be located
Onkyo Audio... | Answered on Aug 23, 2020
I don't know the answer but I suggest obtaining and reading the user manuals before your purchase will give you that information.
It will then be important to ask the supplier the answer and then the responsibility will be theirs.
If the amplifier provides either a 3:1 or 5:1 output there will be provision for a subwoofer - but what type of subwoofer (active or passive) will be hidden in the specs and if you already have a subwoofer, in the specs of that.
When buying a new amp and preamp the last thing you want is mismatch or overload conditions that will either produce a less than good sound or perhaps stressing the amp.
As a matter of diverse interest, in the old days before subwoofers had been invented the hifi enthusiasts seeking the perfect sound developed the three rack amplifier for domestic use. This type of amp had been used in cinemas for a long time and basically consisted of three amplifiers each built to handle a different frequency spectrum - one amp would drive the tweeters, another the midrange and the third would drive the bass units or woofers.
Another thing hifi buffs did was to introduce a ghost speaker driven by a mono amp that derived an input across the left and right channels.
My opinion is the best sound still comes from a quality 10 or 20 watt tube amp into quality low power handling speakers with cabinets as big as a sideboard. 300Mw is the average power needed for a good listening experience in the average lounge or bedroom.
Onkyo Audio... | Answered on Jul 08, 2020
Its fault in the AUX cable that cable which is connected to the speaker system.
Onkyo Audio... | Answered on Jun 18, 2020
If you want to DIY, send an email to me . This email will be deleted after 1 week. It is a very common
faulty found in onkyo av-amp, very easy to get fixed,
however. I won‘t tell you here. Why? I buy faulty av-amp to repair, selling them on the web!.
Onkyo Audio... | Answered on May 28, 2020
Hello, To test the subwoofer when the blue light is on if you apply your thumb to the end of the subwoofer cable (the end that you would plug into the receiver) there should be feedback from the sub. If there is no feedback then the sub is not working correctly. Thanks, FJD
Onkyo Audio... | Answered on May 13, 2020
https://chilker.com/product-category/saree/
Onkyo Audio... | Answered on Mar 31, 2020
If you want to DIY, send an email to me at . This email will be deleted
however. I won‘t tell you here. Why? I buy faulty av-amp to repair, selling them on the web!.3_31_2020_7_49_47_am.jpg
https://www.youtube.com/watch?v=gfJEw-VlpWY
Hold the "VCR/DVD" button while pressing the "On/Standby" button, and the receiver should enter "Standby." Turn it on again by pressing the "On/Standby" button. Bear in mind that this will clear all the presets and other settings - but it may be those settings that are causing the problems.
https://www.techwalla.com/articles/how-to-troubleshoot-onkyo-receivers
Onkyo Audio... | Answered on Mar 26, 2020
You need to check 3 things:
1) DTS will only work through a digital connection (coaxial, optical, or HDMI) between your receiver and dvd player. DTS and Dolby 5.1 cannot carry a signal over red and white rca connections.
2) After number 1 is solved ensure the reciever is set to the digital channel, your DTS-HD in this case, or in an auto mode.
3) Finally the most important is that the signal is a DTS signal. Start a DTS capable dvd, go to the sound menu and set it for DTS.
Press play and all should be well...
Cheers,
NTIMID8
Onkyo Audio... | Answered on Mar 18, 2020
Onkyo HT-R560 Receiver Logo
5 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
when in video mode only plays one front
  • Audio Players & Recorders
