Translate this page
There are two different rear sight options for the M4-177 depending on which model you purchase.) Option 1- ... the airgun in any way inconsistent with this manual may make your ... Adjust the rings on your scope to match the measurements of the top rail. ... Toattach the sling at both ends push the sewn webbing loop end.
? 24:29
https://www.youtube.com/watch?v=s_0grKCOmX0
May 18, 2012 - Uploaded by Replica Airguns
ReplicaAirguns.com - Crosman M4-177 Pellet-BB Multi-pump Air Rifle ... -Single shot - bolt action with manual advance magazine.... I particularly like the removable iron sights and full rail formounting a scope or red dot sight.
? 8:38
https://www.youtube.com/watch?v=x8XKOmb41QA
Aug 28, 2012 - Uploaded by Crosman
A detailed look at installing and adjusting the sights for the M4-177 and sighting ... Crosman MK-177 Pellet-BB Multi-pump Air Rifle Table Top ...
Not available online anywhere. Crosman just say 'some parts available', and Pyramid Air which are my go-to place for diagrams and parts only have the Owner Manual. Contact Crosman direct and ask what they have?
https://www.google.com/search?q=crosman+cfamp1+parts+diagram
not at all. the Benjamin has a pump handle like the rack of a shot gun below the barrel. the Crossman 3100 the barrel is what you **** the round in with. the Benjamin shoots pellets and bb's the Crosman only shoots bb's
It is considered advisable to photograph each step when dis-assembling any mechanism. Have you contacted the mfr, or looked on their website for a service manual ?
They are only 15 dollars to buy new. With that in mind you could attempt to rebuild it but you need at least a micrometer to measure clearances. The pictures that I am looking at show a fiber retainer and a washer seal unit. You need to see if you can get those parts individually. The fiber washer may soften if you wet it and this would make it easier to insert it because the edge of the case appears tapered. However if you do that you need to be able to dry it in its original dimension.
