20 Most Recent
Sigma Zoom Telephoto 170-500mm f/5-6.3 APO Aspherical Autofocus Lens for Canon EOS Questions & Answers
Why does my lens only zoom to 200
Could be, because most camera's only can auto focus till f/1:5.6. And if 5.6 is reached at the focal length of 200 mm, the camera stops it from going to a part it can't be focused.
Perhaps you try the lens in manual focus, and manual zoom.
Sigma 170-500mm f.5-5.6. fit on nikon d 200 ???
Sigma makes their lenses with a variety of mounts for a variety of cameras. A lens with a Canon mount, for example, will not fit onto a Nikon camera. Assuming the lens has a Nikon mount, it is fully compatible with the D200.
If you mean the 150-500mm, you can see a review at
http://www.popphoto.com/gear/2008/12/sigma-150-500mm-f5-63-dg-os-hsm-apo-af
In general, Sigma supertelephoto zooms have a pretty good reputation. However, only YOU can decide whether a particular lens is "good enough" for you.
I am putting the sigma
Turn the aperture ring to its smallest opening (largest f/number). You can control the aperture from the camera body, the same way you do so on a lens without an aperture ring.
I have a sigma 170x500 that is getting stiff how
The rubber grip that surrounds the barrel comes off which is very hard to remove without stretching it out of shape. Once off the screws can be removed to add a few drops of solvent to loosen the stiffness
Autofocus not working
If you don't know how to fix it yourself send it to Sigma UK (01707 329999). They are quite resonable charges for that sort of fault. Their website give a price guide depending on lens and fault. Steve
Where can I find out how to take apart a Sigma 150-600mm contemporary lens?
Taking it apart is not the problem - re-assembling it will be. Unless you have access to an optical laboratory, where laser instruments can measure the exact tolerances required, don't even think about it. You will be left with a pile of optical components, and a far higher repair bill than if you had just let the experts sort out the problem in the first place.
