20 Most Recent Sony D-ej011 Walkman Cd Player G-protection Cd-r/rw Grey Questions & Answers
you can find your instruction manuals
http://www.sony.co.uk/support/en/product/D-EJ011/manuals
hope that it helped
Sony D-ej011... | Answered on Feb 19, 2014
Unplug the player from the wall, press power button on the player for about 10seconds and plug in power again.
Sony Audio... | Answered on Jul 26, 2020
Assuming you are using a cable to connect your cell phone to the speaker you could be overloading the input of the speaker when you turn the phone volume up very high. That would cause distortion that might damage the speaker so it shuts down or turns off.
Sony Audio... | Answered on Jul 25, 2020
FIXYA DOES NOT MAKE VIDEOS TRY WWW.YOUTUBE.COM
Sony Audio... | Answered on Jul 20, 2020
You will have to disassemble the player sufficiently to gain access to the mechanism. Keep track of all the little parts and how they are installed to make reassembly easier.
Sony Audio... | Answered on Jul 15, 2020
cara membuka protect push power sony MHC-RV8
Sony Audio... | Answered on Jul 02, 2020
Hi my Sony mgongo amplifier says usb protect why ??
Sony Audio... | Answered on Jun 30, 2020
Cause:
Battery is 100% discharged. Therefore, PC's USB with 5V/500mA set up has not enough power to start up the charging process because loading current is greater than the set up, therefore USB is disabled immediately due to sudden current load.
Remedy:
Battery must not be discharged 100%
If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
Sony Audio... | Answered on Jun 28, 2020
I suspect there is either a problem with the radio (AM side) or most likely it is a matter of poor AM signal strength where you are and/or high levels of interference.
With FM reception the wire lead of the earphones acts as a fairly efficient antenna but AM reception is via the internal ferrite rod aerial that also is part of the tuned circuit and consequently is not only highly directional but is sensitive to vertical/horizontal orientation - if the signal is polarised vertical the antenna is more efficient when it too is vertical, unfortunately horizontal polarisation is more common.
Development of AM receivers stopped decades ago due to it falling out of favour because of high levels of interference around population centres causing much dissatisfaction and a move to FM and over the last two decades an increased interest in digital radio.
Sony Audio... | Answered on Jun 26, 2020
There's so much information missing from this question, but assuming this is a DVD changer, it's a disc error. Either the disc is upside-down or backwards and can't be read, is too dirty/scratched or unsupported and can't be read, or the entire mechanism is jammed or malfunctioning. If there are discs in the tray and you can remove them all, remove them and see if the error goes away. If the tray will not open, either take the cover off and remove the discs, or bring it to a service center.
Sony Audio... | Answered on May 27, 2020
The internal antenna cud b issue or some capacitor cud b
Sony Audio... | Answered on May 20, 2020
What do you want?
You have to ask a question for us to know what you need to know!
Ask a question and we will try and help!
Sony Audio... | Answered on May 11, 2020
This is a very good make!
You require a phono input or a phono pre amplifier to use this turn table.
There is no phono input on your Yamaha.
Sony Audio... | Answered on Apr 25, 2020
Are the videos in the right format? The format that works for the mp3 is MP4 video. you must convert your videos using a mp4 converter.
i use winavi ipod converter (works with nwz a728)
Hope This Helps!
Sources: I have one myself and came across this problem :)
Sony Audio... | Answered on Apr 22, 2020
https://www.youtube.com/watch?v=tJ--L7peFMM
  1. Unplug the power cord from the electrical wall outlet.
  2. Plug the power cord back into the electrical wall outlet.
  3. Press the power button. to turn on the stereo system.
  4. Press and hold the STOP button. and EQ button at the same time until RESET or RESET OK appears on the display panel.
https://www.sony.com/electronics/support/articles/00026921
Sony Audio... | Answered on Mar 21, 2020
Sony D-ej011 Walkman Cd Player G-protection Cd-r/rw Grey Logo
1 questions posted
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
free instruction manuals
  • Audio Players & Recorders
