20 Most Recent Yamaha RX-V371 5 CHANNEL PAL /NTSC HOME THEATER RECEIVER FOR 110-240 VOLTS Questions & Answers
Might help to check for a good ground
Yamaha RX-V371 5... | Answered on May 14, 2012
More likely, the power supply will have to be repaired.
Yamaha Audio... | Answered 2 days ago
More likely, the remote control will have to be replaced.
If the two units are compatible, you should be able to use the remote control directly.
Your Yamaha receiver offers a variety of configurations. You may have selected one in which speakers are off with the exception of FL and FR.
Yamaha Audio... | Answered on Jul 27, 2020
I bought a damaged rx v1 to repair it and I measured everything and according to the voltages it is ok but and repair it
Yamaha Audio... | Answered on Jul 20, 2020
It's in protection mode. Disconnect all speakers and hold the Tone and Straight buttons while hitting the power button. Hold all buttons down for 3 to 5 seconds. This will turn off protection mode. Now power down then back on. If you haven't damaged anything it should work fine. Make sure all speaker connections are good. Always power down the unit before making any speaker or other connections.
Yamaha Audio... | Answered on May 12, 2020
Just connect the VX7 to the 5730 using an RCA Y cable. It should help
Yamaha Audio... | Answered on Apr 25, 2020
Should have very small hole, insert straightened paper clip to eject. Alternately accelerate it at 32bft per sec sqd
Yamaha Audio... | Answered on Mar 24, 2020
It is most likely locked in protect mode. Try resetting by holding the TONE CONTROL and INFO buttons and pressing power. Watch the front panel display when you do this, and it will tell you what protect was tripped.
Yamaha Audio... | Answered on Mar 16, 2020
If your Yamaha output has the same impedance as the speaker, yes, you can. Attention - if the Yamaha amplifier has more available output power than the maximum allowed speaker power, the speaker may be damaged at a higher volume!
Yamaha Audio... | Answered on Mar 08, 2020
Yamaha RX-V371 5 CHANNEL PAL /NTSC HOME THEATER RECEIVER FOR 110-240 VOLTS Logo
1 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
different fm antenna connect
  • Audio Players & Recorders
