20 Most Recent Redfield Vintage Browning A-bolt La Rifles Scope Mount Base Gun Parts Lk Questions & Answers
Your scope should be "in the ball-park" out of the box. This ball park will of course be determined by the height of scope rings you put on your rifle. The taller the scope rings/bases the lower your initial shot... Go to a range or safe outdoor shooting area. Put a large target up at 100 yards, 16"x6" will usually do. Aim at the bulls eye, and click off a round. Use a spotting scope, binoc's or your scope to see where your shot has hit. If it is off the paper and no where to be seen, click off a shot one foot high, check paper, repeat one foot low, one left, one right until you find your shot on paper. Once you find your shot, you will need to adjust the windage (left to right) or elevation (up to down) by using the turrets on the scope. Part of the trick in sighting in your scope is to remember if your shot is high, then you need to crank the turrets in the "up" postion (if it shoots left, turn turrets to the left, and so on). This part is sort of counterintuitive, and may feel foreign. Once you get your scope on paper, continue to adjust until you are hitting consistently 1 inch above bulls at 100 yards. Shooters benches and rifle rests help in this process, but it can also be achieved without. I hope this helps. D
Redfield Optics | Answered on Oct 02, 2014
well if the bullet hit is jumping about its all down to your scope,,,it could be that its just "lose on its mount!" or its died on you,,like the cross hair is bouncing about inside the scope so with the recoial it jumps into a new place with every shot fired there by giving you a new point of impact,,,
this can happen if the scope was wound right up or down or left or right and strain was put on the adjusters,,,you may need to buy a new scope,,,,a good "air rifle!" scope will work quite well on most full bore rifles,,,yer right i here you say!!! ok,,iv got air rifle scope's on my .303 + 7.62 + 22-250 + .357 under leaver marlin cowboy, all 3 of my .22 rim fire's and they have been on these rifles for years now,,,1000,000, of rounds fired so far, with no problems! and no drifting so far,,,
an air rifle scope is very strong you know,,,but they only cost £150,00p or less for a good one?????
ps,,,,dont buy a tesco scope there cra*y
Redfield Optics | Answered on Feb 13, 2013
Looking for instructions on the use of an Acu-trac rifle scope by Redfield. There are lines above the crosshairs and a yardage graph on the bottom of the crosshairs.
Redfield Optics | Answered on Nov 22, 2010
This may help you:
http://www.abousainc.com/ATsystem.htm
Nice sope!
DonB
Redfield Optics | Answered on May 01, 2010
Paul , got the fotos, now I know what you got. And now I know I don't have that one, but,,,, My local ace hardware has a ton of ancient bases and rings in a draw, I can go through them, also, did you try gunparts.com? They sell to the public and have just about everything known to man. E-mail,,, [email protected]
Redfield Optics | Answered on Feb 15, 2010
Contact Leupold, they purchased Redfield.
Here's the info from Redfield's website, hope this helps, Mark the Gunsmith:
When Leupold purchased Redfield in April, 2008, Leupold did not assume the Redfield warranty. Because many Redfield customers have contacted Leupold with regard to the former Redfield warranty, Leupold is making this information available to Redfield optics owners.
At this time, three Redfield repair facilities are available should your Redfield product require service: Parson's Scope Service(513-867-0820), ABO USA Inc (305-859-2010) and Iron Sight Inc. (918-445-2001). The contacts provided are for information purposes only, as these companies are not affiliated with Leupold & Stevens. Please contact them for all information regarding repair, service, and associated charges.
As a courtesy we are now offering 20% off the price of a new Leupold scope, up to $100, in trade for any defective Redfield scope. If you would like to take us up on that offer you may call us at 1-800-LEUPOLD.
Redfield Optics | Answered on Jan 03, 2010
Here's the info I found on Redfield's website:
Warranty InformationWhen Leupold purchased Redfield in April, 2008, Leupold did not assume the Redfield warranty. Because many Redfield customers have contacted Leupold with regard to the former Redfield warranty, Leupold is making this information available to Redfield optics owners.
http://stevespages.com/zip/united_states_army_fm_23-10%20-%2017_august_1994.zip
in order to get basics you need to know how to run the optic, i suggest you download this and read it, and start practicing. or find the users manual on your scope to figure how to work your elevation, windage, and rectify paralax.
Redfield Optics | Answered on Dec 27, 2009
Is it bent or is it a dent? If its a dent no biggy, it should work ok, may even put a good mount over the dent and tighten it to take it out. If bent it may still work good enough to hunt with and you will not fear it getting bent again. You will loose a bit of Viewing area at far distances, and the cross hairs may seem out of center, with dark area to the bent side but should still work.
Redfield Optics | Answered on Oct 29, 2009
1. For AHD10, HDA10, HDA30, NVRH5, NVR IH8, NVR IC8 Series:
  • Go to DVR/NVR Main Menu (You may need to log in after this step)
  • Click on Advanced Tab
  • Maintain Tab will appear by default
  • On this screen locate the Load Default option and click on it.
  • Select "All" to factory reset all your DVR/NVR Settings and click on Save (You may need to log in to this step)
  • Your system may restart after this step (Older systems do not restart)
2. For THD Series DVR:
  • Right-click anywhere on the screen and the drop-down menu will appear
  • Click on Main Menu (You may need to log in after this step)
  • Go to Maintenance option
  • Click on Default Sub-tab. On this screen, click on Factory Defaults to restore all parameters to default settings
  • Your system will restart after this step
3. For XHD Series DVR:
  • Right-click anywhere on the screen and the quick launch bar will appear at the bottom of the screen.
  • Select All to factory reset all your DVR Settings and click OK
4. For WNVR Series
  • Go to Maintain Tab
  • Select Factory Default Sub-tab on the left menu
  • On this screen, Select All to factory reset all your NVR Settings and click on Apply
Optics | Answered on Sep 21, 2020
Redfield Vintage Browning A-bolt La Rifles Scope Mount Base Gun Parts Lk Logo
1 questions posted
Top Redfield Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Redfield Optic Expert? Answer questions, earn points and help others
View Most Popular
Redfield Optics
  • Redfield Optics
Most Popular Question
not find lens caps covers redfield
  • Optics
