20 Most Recent Microsoft Multimedia Optical Keyboard/Mouse KBMMSCOMBO Questions & Answers
1.?Open the Start?Menu and click Devices?and?Printers . The Devices And Printers panel opens, in which you can access all the external devices connected to your computer, including your printer . m-ydpxpf3wblkuljzof3anecxv-4-0.png Windows 10 - Control Panel - Keyboard - Settings u2-ydpxpf3wblkuljzof3anecxv-4-2.png untitledmouse-ydpxpf3wblkuljzof3anecxv-4-5.png
Microsoft... • Answered on Apr 11, 2017
If all you did was drain it there's a bood chance that there is still residue that could be causing a short somewhere on the board. My personal suggestion is to remove the batteries, and then wash thoroughly underrunning water; then leave to dry out for at least a day preferably somewhere warm and dry. Once it's completely dry again replace the batteries and try again, if this doesn't work then there is likely permanent damage to your keyboard and you might want to get it checked out or get a replacement.
Microsoft... • Answered on May 07, 2011
http://sourceforge.net/projects/overflow/
i would get it from these guys
i hope this helps you and good luck with your game and please vote for me
Microsoft... • Answered on Dec 05, 2010
UPSIDE DOWN DISPLAY Caused by unintentional pressing Ctrl-Alt plus the down arrow key.
Restore by pressing Ctrl-Alt plus the up arrow key.
ALSO
To change the display from portrait to landscape
Press Ctrl-Alt plus a left or right arrow key.
Microsoft... • Answered on May 26, 2010
re-synchronize and re-encrypt your keyboard with your pc. to do that, use the software that came with your hardware. this is a step by step process, and is not the same as that when you push the receiver button and the hardware button to connect your devices. as an alternative, go to your manufacturer's website, click support and look for FAQ's, you should get answers from there.
Microsoft... • Answered on Jan 05, 2010
It sounds as if you need to chnage the batteries in the mouse
Microsoft... • Answered on Oct 23, 2009
I had this problem today with a new Microsoft keyboard. The Alt + Print Screen did not produce an image when pasted in Word.
We found that "F LOCK" button needed to be cancelled and this useful facility now works!!
Bob Wallace
Microsoft... • Answered on Aug 18, 2009
hit printscreen, then open mspaint to paste what you have taken the shot of.
Microsoft... • Answered on Mar 30, 2009
http://www.microsoft.com/hardware/mouseandkeyboard/default.mspx
Find your product on this page.. there are several drivers listed but since I do not know which OS you are using I can not be more specific
Microsoft... • Answered on Mar 18, 2009
The game contains bad programming.
Microsoft... • Answered on Feb 27, 2009
have you tried pressing the connect button on the reciever then on the mouse so it picks it back up again?
Microsoft... • Answered on Oct 26, 2008
my microsoft wireless multimedia keyboard 1.1 does not function at all
Microsoft... • Answered on Oct 21, 2008
try To download the latest drivers for the keyboard that you are using, visit the following Microsoft hardware Web site:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
If the issue occurs again, connect the keyboard to a different computer. If the keyboard functions correctly on a different computer, the port to which the keyboard was connected on the original computer may be damaged. If this is the case, contact your computer manufacturer to inquire about how to repair or replace the damaged port.
If the keyboard does not function correctly on another computer, the keyboard may be defective. If this is the case, and the warranty on the keyboard is still valid, you can exchange the defective keyboard for a new keyboard.
good luck :)
Microsoft... • Answered on Oct 04, 2008
Check if there is anything stuck or jamming the button before buying a new one, but i think it is likely you'll get a new one. Because sometimes the key won't work, as somthing is preventing the trigger.
Microsoft... • Answered on Sep 02, 2008
I'have no idea to suggest u, I think u have more knowledge about this comparision against me!!!!!!!! Sorry
Microsoft... • Answered on Mar 21, 2008
No there aren't. The power for the reciever comes out of the port it plugs into. My suggestion would be to replace the batteries in the mouse itself, or replace the unit.
Microsoft... • Answered on Nov 07, 2007
Unfortunately many programs "Interfere" with the Screen Saver.. certain programs actually "Disable" it. The only "Fix" as it were is some sort of "Work around" perhaps, another screen saver program may work? As a thought tho, have you had a look on the Microsoft hardware Forum site? Perhaps something there may shed some light on it?
Microsoft... • Answered on Aug 18, 2007
If Outlook stops responding at a screen that says "Processing," you can close Outlook, start it in safe mode, then close it and open it normally to fix the problem. - Close Outlook. - Launch Outlook in safe mode by choosing one of the following options. In Windows 8, on the Apps menu, choose Run, type Outlook /safe, and then choose OK. - Close Outlook, and then open it normally Also you can try open your file with the help of https://www.openfiletool.com/ostopen.html
Microsoft... • Answered on May 10, 2021
Error code 0x80070005 is also known as ACCESS DENIED. This error usually occurs when you lack file or registry permissions that are required to install the update. To fix this error code, you could use the following method: Method: Acquire Permissions of the Packages Folder Step 1: Press Windows Key + R to open the Run box. Step 2: In the run dialogue that pops up, type in %appdata% and then click OK. Step 3: The computer will take you to the Appdata\Roaming folder. Click on AppData\Local in the address bar in the File Explorer and navigate to the AppData\Local folder. Step 4: Look for the folder called Packages. Step 5: Right-click on the Packages folder and select Properties. Step 6: Switch to the Security Tab. Step 7: Now click on the Advanced button and make sure that all the users listed there have full control. If not, then click on Add. Select Select a Principal, type in users in the box labelled Enter the object name to select once this is done. After that, click on Check Names and then tick off the box next to Full Permission. Step 8: Click on OK. The computer then should grant full permission and your issue should now be tackled. If the method fails to work, check out this article: [Solved] How to Fix the x80070005 Error Code
Microsoft... • Answered on May 09, 2021
Computers & Internet Logo
24 questions posted
Top Microsoft Computers & Internet Experts
efs_perpends
efs_perpends
k24674
Jax Planet
Jax Planet
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
upside down screen
  • Computers & Internet
