20 Most Recent
Samsung Av-r730 A/v Surround Receiver Receiver Only Working Perfectly Questions & Answers
Receiver could be in protect mode or suffering from failure of amplifier chain component(s)
Samsung Av-r730...
Answered
on Apr 08, 2021
Try a quick blast of compressed air into the headphone jack area. Worked great for me.
Samsung Av-r730...
Answered
on Aug 09, 2014
There is a internal problem. Will have to be taken in for repair,
Samsung Av-r730...
Answered
on Dec 02, 2012
But it's an antique :>D It is before the time of HDMI connectors and may well be before the time of composite audio. You would be looking to Phono Connectors 'Out' on the television and a Phono Input Source on the AVR 2000.
There is full specs and manuals here, but you have to register to get them.
https://www.hifiengine.com/manual_library/sansui/2000.shtml
Samsung Audio...
Answered
Yesterday
Contact Samsung directly to inquire.
Samsung Audio...
Answered
on Apr 15, 2021
This is usually caused by a damaged audio output stage.
Time for a specialized repair.
Samsung Audio...
Answered
on Feb 26, 2021
You know, m4v files have DRM protection and can't be played on Android devices. But you can do it with a 3rd party tool, NoteBurner. It can remove DRM legally and then convert m4v to mp4, mov, avi, etc. Besides, AC3 dolby 5.1 audio and multilingual subtitles can be all kept after conversion. You can learn more from: http://www.noteburner.com/mac-m4v-converter-plus.html
Samsung Audio...
Answered
on Jan 26, 2021
You probably will get the best result if you use a digital to analog audio converter. Amazon has a number of models:
https://www.amazon.com/DA-Converters/b?ie=UTF8&node=3224445011 . You will need to provide the optical audio cable. You connect the TV's optical audio out to the converter's input. Then use the converter's RCA output to the home theater system's audio input.
The TVs HDMI port is only an HDMI input (possibly with Audio Return Channel). This isn't usually resolved by an HDMI-RCA Converter. This converter might have worked to split off the audio signal from a Blu-ray player with an HDMI cable to the converter and then another HDMI cable to the TV and the RCA audio going to the Home Theater system.
I hope this helps.
Samsung Audio...
Answered
on Jan 01, 2021
IC801 is ICE2QS03 and Q801 is KF8N60F
You must replace the components that caused the failure otherwise it will not work properly.
Samsung Audio...
Answered
on Dec 31, 2020
You have to check the ratings of woofers for wattage they have been designed. Have you got a manual? They would definitely be working up to that mark.
Samsung Audio...
Answered
on Aug 16, 2020
Yes, it can connect to your tv if your tv support the any wireless connection check your tv settings then connect it.
Samsung Audio...
Answered
on Jun 16, 2020
Connect the power cords for the soundbar and the subwoofer to the back of each, and then plug both into a wall outlet. Use a small pointed object to press the ID SET button on the back of the subwoofer. Continue holding until STANDBY turns off and LINK (Blue LED) blinks quickly.
Samsung Audio...
Answered
on Jun 04, 2020
