20 Most Recent
MPC Computers (9052701) PC Desktop Questions & Answers
How to change hard drive
change your hard drive by replacing another hard drive with ide a belt type one end to the mother board and other end to the harddrive..... then another wire that comes from your smps box in your cabinet with red blue green colours connect it to your hard drive thats it..
if your harddrive is sata then do the same in the sata
SIR
I HAVE AN OLD LAPTOP
there is one possible way
1. remove hard drive from your laptop
2. plug your HDD into another laptop in anyway(usb or enclosure)
3. Make your HDD bootable with DOS mode
4. copy the new OS folder to your HDD
5. Put back your HDD to your old laptop then boot it with DOS
6. find the OS folder you copied, from there run setup your new OS.
My mpc laptop cant openn programs like facebook and yahoo
some countries block these sites. Try going via a free web proxy (google for one) and see if this makes any difference although i would not been too keen to put your username and passwords in while using a free proxy as they may not be secure. The issue you have could also be with your security levels being set a little too high on your browser. You could try donwloading an alternative browser like Opera, Chrome, Firefox etc...
How to avoid stress when over using computer
In today digital era, most are already used to use digital products such as computers... in our home office and others but most are having problems after several hours of prolong use or exposure to computer... here a few reminders...
* Keep a proper eye distance from your computer screen at least 12-14 inches
* Maintain proper posture especially back support
* Have a momentary break for every hours
* Use sufficient lighting in your working area
Tear down
Yes you can. You might use Sugru to re-attach the cover. http://www.sugru.com
To Block the Access to certain links
yes. using a simple text editor like notepad simply add entries to the file:
c:\windows\system32\drivers\etc\hosts
the entries should look like this:
127.0.0.1
www.siteiwantblocked.com
that IP address is the "localhost" and will result in and error or if the computer is running a web server it will go to that site.
Install ide drive
make sure power is removed, open case and connect drive using the only cable that will fit.
How can I fix my computer stop message 0x00000402
Normally this happen when they are blue screen. Problem with RAM memory.You can test using the utility coming with the computer. Or go to the websiste from your supplier computer and download the utility for to test the RAM memory.+Update the computer with MicrosoftGod bless you
