20 Most Recent Dual MXDM66 Marine Receiver Questions & Answers
Turntable Stopped Turning
If it's belt driven, maybe it snapped. It's just rubber.
11/7/2023 7:42:17 PM • Dual Audio... • Answered on Nov 07, 2023
How do i go about connecting a dual wireless uhf microphone system to a yammaha rx-v683 av receiver
I can provide you with the steps to connect a dual wireless UHF microphone system to a Yamaha RX-V683 AV receiver:
  1. First, make sure that the microphone transmitters and the receiver are turned off and unplugged from any power source.
  2. Connect the receiver to the AV receiver using audio cables, such as RCA or XLR cables. The output jacks on the receiver should match the input jacks on the AV receiver.
  3. Turn on the AV receiver and set it to the input that the wireless microphone system is connected to.
  4. Turn on the wireless microphone system and set it to the same frequency as the receiver.
  5. Adjust the volume levels on the AV receiver and the wireless microphone system as needed.
  6. Test the microphones to ensure that they are working properly and that there is no feedback or other audio issues.
It's important to note that the steps above may vary depending on the specific wireless microphone system and AV receiver model
1/22/2023 3:16:40 PM • Dual Audio... • Answered on Jan 22, 2023
Connecting a dual volume control
Your message is to 'Alan'. We are Fixya dot com. Perhaps sending via email would be better. The wires from the amp go to the input of both volume controls. The output goes to the speakers Or forget about stereo and left and right. Have the left channel go to the jukebox and the right channel go to the extension speakers
12/7/2022 12:32:38 AM • Dual Audio... • Answered on Dec 07, 2022
I have a pair of Concepts CCDCIR10 Enhanced Dual IR Headphones, and I don't know how to use them I have no booklet to go with them
No instructions are available online. You may as well buy a new pair for $24 and get the manual with them https://www.google.com/search?q=concepts+ccdcir10++manual ..
11/2/2021 2:46:56 AM • Dual Audio... • Answered on Nov 02, 2021
Looking for a set of belts for a Fisher MC-630 dual cassette and diagram.
FISHER MC-630 AUDIO COMPONENT system Turntable ...
https://lptunes.com > products > fisher-mc-630-turntabl...
Buy a FISHER MC-630 AUDIO COMPONENT system Turntable Replacement Belts for your record player. Fix your broken FISHER MC-630 AUDIO ... US$16.99 · ‎In stock Videos https://www.google.com/search?q=Fisher+mc-630+belt+replacement ..
4/21/2021 5:37:45 PM • Dual Audio... • Answered on Apr 21, 2021
I have my mint condition dual record player hooked up to my Harmon Kardon AVR 120, however the output sound is alot lower and only goes up to +10 DB, I checked all the connections and they are perfect
Record players have a phono output that is much lower level than other audio equipment. If your receiver has a phono input that will have a preamp to adjust the level. Or your turntable may have a switch between phone o or line level and that would increase the volume as well. Most audio signals are line level but phonos are a magnetic signal that is much weaker and needs to be Amplified by a preamp in your receiver or in the unit itself.
12/18/2018 5:04:01 PM • Dual Audio... • Answered on Dec 18, 2018
2answers
Where to obtain user guide for marantz sd-160 dual deck cassette player
Hello, Edward - I have only been able to find Service Manuals for the Marantz SD-160 dual deck cassette player for sale. I was unable to find the operating manual for the vintage cassette player / recorder on the Marantz website. However, if you have not yet already done so, I suggest you contact Marantz Support, either via phone or email, and ask if there is a copy of the operating manual for the SD-160 in the company archives and if they could provide you (sell you) a photocopy or scanned PDF version of the manual. This is the link to the Marantz Support page: https://marantz.custhelp.com/app/answers/detail/a_id/104/kw/manual/related/1 If that option doesn't work out, Option 2 is to find one or more online sellers (eBay, Craigslist, Amazon, etc.) of the model of cassette player / recorder and see if they mention the operating / owner's manual in the product sales information. If they don't mention a manual, I suggest contacting the seller/s and asking if they have the manual. If you find an online seller with the manual, ask if he / she would either photocopy the manual for scan it as a PDF document and sell it to you. Best wishes.
1/26/2018 7:07:49 PM • Dual Audio... • Answered on Jan 26, 2018
My whahl super taper is dual voltage, it runs 220v in 50 hz and 230volts in 60 hz. my question is how can i convert the clipper that will runs 220v in 60hz ??
All you should need to do is tune the clippers with the large tuning screw on the side of the case until the loud noise stops and they just hum as they should. They might need some other adjustments to blade alignment after this. A barber should help you with this if your not sure. I pays to have blades correctly aligned for clippers to function correctly and safely so they dont pull hair or cut your skin. Oil blades every time you use clipper and they will last a lifetime.
8/17/2017 8:22:35 AM • Dual Audio... • Answered on Aug 17, 2017
Dual 1228 turntable service manual
Just google it.
6/26/2017 2:07:56 AM • Dual Audio... • Answered on Jun 26, 2017
I have a Thomas Pacconi Model TPC-MSE-807 turntable. The Power/Volume Control has gone on it.
Look on the data plate to see if there is a voltage and current draw value on it. The switch should be rated at 120 Vac @ 10 A.
2/2/2017 7:56:47 PM • Dual Audio... • Answered on Feb 02, 2017
The volume comes on loud even when i have turned it down before turning off
It sounds as if the UP VOLUME button/switch is broken and ON all the time. See if it is stuck down ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
1/7/2017 5:34:54 AM • Dual Audio... • Answered on Jan 07, 2017
How do I connect my technical pro dual 10 band equalizer to my professional hybrid amplifier
Use the pre in out connections or any in/out connectors that you have. Can you send a picture? ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
1/7/2017 5:34:02 AM • Dual Audio... • Answered on Jan 07, 2017
My Dual CS 1264 Does not work. The arm swings out over the record, drops slightly and then returns to its resting position on its base
It seems that the special grease is old. There is a wheel moving the toneam. Remove any old grease from it and try again. If you need further instructions or a way to get new grease please refer to www. dual-board.de This is the worlds largest knowledge base for vintage Dual turntables. It is in german, but feel free to post in english, most people here in germany speak english, too.
12/3/2015 8:30:40 AM • Dual Audio... • Answered on Dec 03, 2015
I am looking for a face plate XDM6820 for a car radio.
  1. so who knows what kinda malware this site is spewing.
  2. But if ya still looking for a xdm6820 faceplate I recently aquired one in auction
  3. You still got the deck?
  4. july 06 2014 today is 3 18 2015
  5. Dallas Tx area
3/19/2015 1:44:05 PM • Dual Audio... • Answered on Mar 19, 2015
Red flashing still I have check all the wires ands
on what
8/31/2013 2:20:53 PM • Dual Audio... • Answered on Aug 31, 2013
2answers
Horn blew,diaphram burn
Try
www.usspeaker.com
2/7/2013 3:47:43 PM • Dual Audio... • Answered on Feb 07, 2013
Dual MXDM66 Marine Receiver Logo
6 questions posted
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Dual Audio Players & Recorders
Most Popular Question
connecting dual volume control
  • Audio Players & Recorders
