20 Most Recent Magnavox ZC320MW8 Multi-Format DVD-R/-RW/R/RW Recorder, Refurbished Questions & Answers
This I believe will come down to software. The DVDs are all copy protected but by no means is it high security. I would check into some firmware update or additional software to download on to the recorder to open and finalize.
Magnavox... | Answered on Jan 21, 2013
Hello Gene, I sent you the link where you can buy what you need for your Magnavox
Hope this can help you
Greetings Franco Dosil
Hola Gene, te envio el link donde puedes comprar lo que necesitas para tu Magnavox
Espero que te sirva
Saludos Franco Dosil
https://www.amazon.com/Newpowerking-Phonograph-Turntable-MAGNAVOX-1ST-635/dp/B017GA88V4
https://www.amazon.com/Newpowerking-Phonograph-Turntable-MAGNAVOX-1ST-635/product-reviews/B017GA88V4
https://www.ebay.com/itm/Stereo-Turntable-Needle-N314-for-EV-136D-132-Magnavox-560305-1-EV2619-359-DS73-/123446097048?_ul=AR
Magnavox Audio... | Answered on Jun 05, 2019
Espero que te sirva
https://www.amazon.com/Newpowerking-Phonograph-Turntable-MAGNAVOX-1ST-635/dp/B017GA88V4 https://www.amazon.com/Newpowerking-Phonograph-Turntable-MAGNAVOX-1ST-635/product-reviews/B017GA88V4
Hi, there.
I checked for that model number in my Magnavox catalogs and could not locate it. I also went ahead and searched - based on the number - on the Sam's Technical Publishing site that carries user and repair manuals - but no luck. However, you can request the manual through the site to see if it is in stock. I don't work for Sam's, so not advertising. It's the site I have used for locating manuals for the many units I have repaired. Where the pros shop for Photofact manuals Quickfact manuals service...
Magnavox Audio... | Answered on Apr 19, 2019
The problem with your 1960s "music centre" turntable is likely to be mechanical - rubber tyres, drive belts, etc. These are less spare parts for your Magnavox unit and more spare parts for the turntable which is likely to have been bought in by Magnavox. Similarly the stylus will be a spare part for the brand and type of cartridge fitted to the tone arm.
Finding a suitable grey-bearded service technician who can remember how to service and repair classic music equipment and is willing to tackle the work and keep the total cost in proportion to the value of the unit will be very difficult or nearly impossible.
If you really can't or don't want to tackle the work yourself I speculate finding a restorer of jukeboxes or a hi-fi enthusiast with a long experience is likely to be more useful...
Magnavox Audio... | Answered on Apr 15, 2019
Fixya does not sell power cords.
Magnavox Audio... | Answered on Feb 25, 2019
I don't know but will take a guess - I expect the radio is a vintage am/fm transistor radio. The am antenna is likely to be a ferrite rod tuned directional type that will be inside the cabinet.
The fm antenna might be a single core wire that dangles from the set in the way commonly used by many fm radio-alarm clock-radios. This performs the same function as the single telescopic antenna of portable radios without the cost and similarly is connected internally to the first rf stage. Sometimes due to age, mishandling or ignorance the dangling wire is lost or cut off.
A higher quality table radio (not designed to be portable) is equipped with a facility to connect a 300 ohm balanced antenna, a 75 ohm fm antenna or both.
The 300 ohm type connects to a pair of screws accessible at the rear without removing any covers and is usually an indoor type. The 75 ohm type plugs in with a standard coax plug and could be either an indoor type or an outdoor type.
A matching transformer is available to use a 75 ohm antenna with a 300 ohm input. The 300 ohm type is highly directional in horizontally polarised signal areas and is not always convenient to use.
Magnavox Audio... | Answered on Dec 12, 2018
Use HDMI 2, They make an HDMI switcher/ selector / expander.
They have 3 or 4 inputs, and they are even remote control. Just what you need, another Remote to add to the stack!
Magnavox Audio... | Answered on Sep 28, 2018
The cartridge is marked L & R, The R + and R- cannot touch or you will have no sound from one side of the stereo. The two center wires go to L & R ground and the two outside to the center posts of the L & R plugs. That is the wiring diagram.
Check the balance or fader control and turn it to the left channel and if that doesn't provide quality volume from the left try swapping the speakers.
If there is no improvement there is an amplifier fault...
Magnavox Audio... | Answered on Dec 11, 2017
Magnavox ZC320MW8 Multi-Format DVD-R/-RW/R/RW Recorder, Refurbished Logo
1 questions posted
Top Magnavox Audio Players & Recorders Experts
Jay Plesset
Kenneth Walker
Are you a Magnavox Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Magnavox Audio Players & Recorders
Most Popular Question
magnavox zc320mw8 dvd recorder am
  • Audio Players & Recorders
