20 Most Recent Harman Kardon AVR 120 Receiver Questions & Answers
same fuse you could get 1 at radio shack
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Harman Kardon... | Answered on Dec 13, 2017
Hi! self also facing similar problem with AVR120. No sound coming from any channel. Video is coming from DVD but no sound. Display / Remote is working. Did a RESET but same situation. please advice next step. local repair shop suggesting that some 'IC for sound is gone and charging a bomb for replacement. Please advice.
Harman Kardon... | Answered on Oct 10, 2013
What we are doing, in this case is looking for a shorted out speaker system, or wiring to speakers, or cables or components that are connected to the receiver that have a short circuit. This is what I would do if I were called to your house to debug your sound system.
Follow this procedure and see what happens:
Disconnect one set of speakers at the back of the receiver and turn the power button on again. See if it stays on.
If not, remove the next speaker and keep repeating the test.
If it still stays off, disconnect all of the equipment connected to the unit, one piece at at time.
Somewhere along the line, the receiver may not shut down. If that is the case
identify the the offending cable(or component)and replace or service it.
I hope this solves it for you. If not your receiver will need professional servicing,
Best Regards,
Mark
Harman Kardon... | Answered on Dec 09, 2011
It means that you need to have both the remote control and the system checked. You may be able to check if the remote is functioning by aiming it at something else. I had a Sony Stereo which had a little LED lamp in the volume control knob which would flicker no matter which remote control I aimed at it....it was very handy for checking if any Remote suspected of being inoperative was transmitting anything !
You can buy remote control testers, that have an LED that flickers if the remote is transmitting. It wont tell you if the codes from the remote are correct.
You might also like to try checking local advertisements to see if someone has an identical unit to yours up for sale. You might get them to let you pop in and see if your remote is working...... for a beer or a small gift as a token of thanks.
Harman Kardon... | Answered on Oct 30, 2011
probably worse,the first thing I am going to check is,input selector in preamp module,(it is an IC)....Shorly It means the unit is ready for someone ho is an expert for the problem.
If the test tones work, the audio hardware is fine.
"Attachments"? You may have to re-visit the setup for them.
Harman Kardon... | Answered on May 17, 2011
Hi. Found this PDF manual which may help you out. http://www.enusbaum.com/hk.old/AVR120%20sm.pdf. It's quite a read.
Harman Kardon... | Answered on Feb 19, 2011
Is the DVD player's audio correctly connected, associated (if digital) and selected for playback?
http://www.retrevo.com/support/Pioneer-VSX-D510-Receivers-manual/id/385ci969/t/2/
Page 14, etc.
Harman Kardon... | Answered on Jan 30, 2011
Check that the player's Dolby / DTS is enabled. Sometimes it is defaulted in the player to 2.0 / Stereo PCM. What model Samsung? Those Harman receivers are old favorites of mine...
Harman Kardon... | Answered on Jan 06, 2011
Go to www.harmankardon.com and visit customer support to see if they can provide a replacement.
Harman Kardon... | Answered on Dec 30, 2010
Harman Kardon AVR 120 Receiver Logo
Popular Tags
39 questions posted
Top Harman Kardon Audio Players & Recorders Experts
Laser Plus Computers...
Level 1 Expert
 Grubhead
Grubhead
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Harman Kardon Audio Players & Recorders
Most Popular Question
h k reciever keeps powering down itself
  • Audio Players & Recorders
