20 Most Recent MSI Microstar KT6 Delta (MS-6590) Motherboard Questions & Answers
Display mode setting refresh
on your monitor there are bottons to do that
5/23/2014 4:16:12 AM • MSI Microstar... • Answered on May 23, 2014
0answers
0answers
2answers
I need MSI-MS 6590 motherboard
Drivers for MSI motherboards can be downloaded from the MSI website.
Start here:
http://www.msi.com/service/download/
11/13/2012 1:12:20 PM • MSI Microstar... • Answered on Nov 13, 2012
0answers
MSI usb problems
Sounds like your O/S was damaged when the old MB failed. I'd boot the computer with yoru system disk and run a scandisk or, in the case of Win Vista or 7, choose the option to repair Windows.
3/22/2012 5:04:42 PM • MSI Microstar... • Answered on Mar 22, 2012
How to boot from dvd
Turn the computer off.
Turn the computer on, and look for the message:
Press <BLAH> to enter BIOS SETUP.
Press the <BLAH> key.
Change the "boot-order" to make the CD/DVD the "first" boot-device.
Save/Exit from BIOS SETUP.
Insert the media into the CD/DVD device.
Boot from the media.
8/2/2011 11:00:29 PM • MSI Microstar... • Answered on Aug 02, 2011
0answers
The markings on the motherboard are KT^ DELTA MS
try clean install and don't forget to format the hardisk and do some partition
5/21/2011 8:04:44 PM • MSI Microstar... • Answered on May 21, 2011
Where to find a manual
http://eu.msi.com/product/mb/KT6-Delta-SR--LSR--FISR--FIS2R.html#/?div=Driver
drivers can be found there
If you found this info useful please vote for me
4/10/2011 9:12:16 PM • MSI Microstar... • Answered on Apr 10, 2011
I install bios update for MS-6590 KT6 Delta coz i
Typically updating the bios will not make the pc faster, but hopefully make it more stable and support newer memory and CPU´s.
Check the Task manager to se witch programs use CPU power and memory with CTRL+SHIFT+ESC. I find that making sure the harddrive is up to date model, is the most import!
Try using MSINFO32.exe to see what programs starts in the background when the PC starts. A description on how to us the program is here: http://support.microsoft.com/kb/308549
3/13/2011 7:30:06 PM • MSI Microstar... • Answered on Mar 13, 2011
When i install Bios up
Ram need to be installed in pairs. Windows XP only recognizes a max of 4GB ram 3.5 usable. Windows Vista 32bit only recognizes a max of 4GB ram as well as Windows 7 32bit. Vista/7 64bit can recognise a much larger amount of ram. Find out if your operating system is 32 or 64 bit and make sure you are using the right kind of ram for your system.
3/13/2011 7:16:10 PM • MSI Microstar... • Answered on Mar 13, 2011
Sata hdd wont boot up
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
2/20/2011 10:39:45 PM • MSI Microstar... • Answered on Feb 20, 2011
Ms 6724 ver 1 password
2/17/2011 5:34:05 AM • MSI Microstar... • Answered on Feb 17, 2011
2answers
I need a pasword.when i enter the bois there need
Hi Good day!! turn off your PC Remove your CMOS battery (2032 3volts) within 1minute and then put it back, turn on your PC now your bios password should be remove.
10/19/2010 8:40:03 AM • MSI Microstar... • Answered on Oct 19, 2010
2answers
Manual
http://global.msi.eu/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=557
depend on you language
and there ist the training for any case
http://us.msi.com/support/tshooting/BasicTroubleshootingGuideV.3.pdf
9/25/2010 7:34:51 PM • MSI Microstar... • Answered on Sep 25, 2010
BIOS update on MSI KT6 Delta (MS-6590 v2 5.0)
You should be able to get it from here.
http://www.motherboard.cz/driver/msi.htm
4/26/2010 12:38:30 PM • MSI Microstar... • Answered on Apr 26, 2010
Took the two green jumpers off-what are they for?
The jumpers you have taken off might usually be jumpers for clearing the CMOS (think of it as the BIOS settings). This usually not be a problem. You can look for your motherboard's support for "Resetting BIOS". Most of the time, there will be some things involving jumpers.
3/7/2010 10:06:24 AM • MSI Microstar... • Answered on Mar 07, 2010
MSI Microstar KT6 Delta (MS-6590) Motherboard Logo
48 questions posted
Top MSI Computers & Internet Experts
Ekse
Davit Mamyan
Davit Mamyan
Mandeep  Singh
Mandeep Singh
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
need msi ms 6590 motherboard
  • Computers & Internet
