20 Most Recent MSI K8MM-ILSR (MS6741030) Motherboard Questions & Answers
When I boot up the
1. your issue sounds as if the mother board and or the power supply needs replacement
2. this PC possible need service.
3. there could be a hard drive issue also.
3/13/2011 6:15:08 AM • MSI K8MM-ILSR... • Answered on Mar 13, 2011
0answers
2answers
How can i boot from usb
http://www.bootdisk.com/pendrive.htm
Try this,it's how to boot from a pendrive thru a USB port.
1/29/2010 4:40:04 AM • MSI K8MM-ILSR... • Answered on Jan 29, 2010
I NEED DRIVERS
esalud
If you go to the link below you can download the drivers for your MSI motherboard.
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=601
Issken
1/15/2010 6:45:56 PM • MSI K8MM-ILSR... • Answered on Jan 15, 2010
Msi -6741 no da bios ni video sol oenciende el
plzzzz sand mee drivers to this board
12/16/2009 2:33:23 AM • MSI K8MM-ILSR... • Answered on Dec 16, 2009
I have been using the MSI K8MM-ILSR mother board
Check your bios battery. It may causing this problem
12/2/2009 9:18:03 AM • MSI K8MM-ILSR... • Answered on Dec 02, 2009
Lost sata drivers
u must change optin from bios . the option is sata native mode u must change in to disable . or change any legacy into enhanced thanx enjoy good luck plz vote on my comments
9/3/2009 9:21:52 AM • MSI K8MM-ILSR... • Answered on Sep 03, 2009
2answers
Pin placement for ms 6741 mb
the manual for your motherboard can be downloaded here:
http://www.msi.com/index.php?func=downloadfile&dno=3812&type=manual
On page 2-17, the pin-outs for those connectors are specified in detail. They are part of the JFP2 header:
PIN SIGNAL DESCRIPTION
1 HD_LED_P Hard disk LED pull-up
2 FP PWR/SLP MSG LED pull-up
3 HD_LED_N Hard disk active LED
4 FP PWR/SLP MSG LED pull-up
5 RST_SW_N Reset Switch low reference pull-down to GND
6 PWR_SW_P Power Switch high reference pull-up
7 RST_SW_P Reset Switch high reference pull-up
8 PWR_SW_N Power Switch low reference pull-down to GND
9 RSVD_DNU Reserved. Do not use.
-Jon
9/1/2009 2:34:27 AM • MSI K8MM-ILSR... • Answered on Sep 01, 2009
0answers
Cpu upgrade
According to the spec sheet on the MSI website, this motherboard will take up to a 3700+ Athlon. Check out the link:)
http://www.msicomputer.com/product/p_spec.asp?model=K8MM-ILSR&class=mb
Further testing is being done on this board, but here is the UPDATED CPU compatibility chart:)
http://global.msi.com.tw/index.php?func=prodcpusupport&maincat_no=1&prod_no=601#menu
12/30/2008 2:31:24 PM • MSI K8MM-ILSR... • Answered on Dec 30, 2008
2answers
Hello i have a MSI
from the msi web site
CPU • Supports 64-bit AMD® Athlon™ 64 processor (Socket 754) • Supports 3000+, 3200+, 3400+, 3700+ • Supports Sempron 2600+, 2800+, 3000+, 3100+(CG), 3300+
12/30/2008 2:28:04 PM • MSI K8MM-ILSR... • Answered on Dec 30, 2008
Case wires to connect to motherboard
Hello!
To connect front usb header see this diagram:
http://www.celtnet.org.uk/images/usb_connectors.gif
To connect front audio header see this:
http://www.celtnet.org.uk/images/audio_connectors.gif
Hope this helps!
10/2/2008 5:55:24 PM • MSI K8MM-ILSR... • Answered on Oct 02, 2008
2answers
How do i download MSI N082 graphics driver
To get the MSI N082 graphics driver: 1. Find your graphics card model. Note down the model number. 2. Go to MSI's website. 3. Look for the support or downloads tab and click on it. 4. Use the search or menu options to find drivers for your specific graphics card model. 5. Download the driver package. 6. Run the installer file once the download is complete.
3/26/2024 10:36:50 PM • MSI Computers &... • Answered on Mar 26, 2024
Screen does not fit after adjusting the screen resolution msi N082 i tried updating the VGA driver online but it keeps telling me that driver is up to date
If adjusting the screen resolution didn't resolve the issue and you've already updated the VGA driver, try manually adjusting the display settings through your computer's control panel or display settings menu. Look for options like overscan or scaling to ensure the screen fits properly. If the issue persists, it could be a hardware problem or compatibility issue with your monitor. Consider reaching out to MSI support for further assistance.
3/26/2024 12:50:33 PM • MSI Computers &... • Answered on Mar 26, 2024
How do i connect my fire stick thru bluetooth on my MSI windows 11 laptop??
To connect your Amazon Fire Stick to your MSI Windows 11 laptop via Bluetooth, you will need to follow these steps:
  1. On your Fire Stick, go to Settings > Display & Sounds > Enable Bluetooth.
  2. On your MSI Windows 11 laptop, go to the Windows Settings > Devices > Bluetooth & other devices.
  3. Turn on Bluetooth on your laptop and make sure that it is in pairing mode.
  4. On your Fire Stick, select your laptop from the list of available devices.
  5. On your laptop, click "Pair" when prompted to complete the pairing process.
  6. Once connected, you should be able to stream content from your Fire Stick to your laptop.
1/20/2023 11:59:27 PM • MSI Computers &... • Answered on Jan 20, 2023
Wanting to connect an older AV received to my Win 10 PC via optical input. Should I use MB or Graphics output?
You should use the audio output on your computer that is labeled as "optical" or "S/PDIF" (Sony/Philips Digital Interface Format) to connect to the optical input on your AV receiver. This will typically be labeled as the "digital audio out" or "digital output" on your computer. The "graphics output" is used for video, not audio.
1/12/2023 2:39:40 PM • MSI Computers &... • Answered on Jan 12, 2023
How can i enter the bios on my pc.
Proper training and equipment are needed to modify the (Basic Input Output System ) BIOS on a PC. You could turn your PC into a paper weight. The game has been criticized for its anti-cheat software, Vanguard, as it was revealed to run on akerneldriver, which allows access to the computer system.[56]OSNewsexpressed concern that Riot Games and its owner, Chinese technology conglomerateTencent, could spy on players and that the kernel driver could be potentially exploited by third parties.[56]However, Riot Games stated that the driver does not send any information back to them, and launched abug bounty programto offer rewards for reports that demonstrate vulnerabilities with the software.[57][58]The bounty will reward white hat hackers between $25,000 to $100,000 for reports on its vulnerabilities, with the pay being based off the severity of the exploit.[59]Gameplay bugs do not qualify for this bounty.[59] Valorantwill not run onWindows 11if the system does not have aTrusted Platform Module(TPM) 2.0 compliantcryptoprocessorandUEFI secure bootenabled, as mandated by Microsoft's minimum system requirements for the operating system.[60]
11/20/2022 7:19:17 PM • MSI Computers &... • Answered on Nov 20, 2022
Replacing an msi laptop screen
no PC told at all MSI is maker only but yes they all unplug on laptops(is it) they are held on by tricky ways and if forced you break mobo or display there are the easy ones push on pull off the the wedge locked, , unlocked first. and last the hinge lock FFC cable ends learn not to force them, look first for locks, 2/3rs of them are locked.
8/22/2022 8:33:42 PM • MSI Computers &... • Answered on Aug 22, 2022
I need the MSI MS7506 AMD AM2 Bios bin file
Contact AMD.
8/1/2022 10:43:59 PM • MSI Computers &... • Answered on Aug 01, 2022
MSI K8MM-ILSR (MS6741030) Motherboard Logo
15 questions posted
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
need drivers
  • Computers & Internet
