20 Most Recent Harman Kardon AVR 325 Receiver Questions & Answers
Harman Kardon AVR325 stays in standby mode
Was a solution ever found for this? I have almost the same problem, except that mine makes a horrible sound through the speakers before it shuts off. However, after an attempt or two, mine usually starts working and sounds fine (I love how this thing sounds!). It seems to happen more when I've let it sit for a week or two. When I use it regularly, it usually works fine. It's almost like it knows when I'm about to give in and replace it... because it will start working again! Maybe I just need to make an effort to use it more....
5/23/2019 5:46:10 AM • Harman Kardon... • Answered on May 23, 2019
4answers
AVR 254 is not responding. None of its front panel
ok The reason your receiver is causing you issues is cause of a 2 time Delay fuse's on the transformer board all you have to do is to by pass them. Check the connector on the top front of the HDMI board. at the bottom of the connector it tells you the voltage of each wire the middle one is GND. should read 1.8v and 5.6v if the 5.6v line is dead. you key's in the front panel and sometimes video and audio as well.. will also stop working. all you have to do is to by pass them. I will be posting a video later today on how to fix this issue. Regards, Search for AVR 254/354 fix
1/29/2014 12:23:13 PM • Harman Kardon... • Answered on Jan 29, 2014
0answers
Hi, I have a Harmon
it sounds like Amp burned, but not all burn parts you can see, you have to measure them by DMM. I guess at least one AMP transistor shorted. you can check SPK terminals by DMM DC, it can be easy to find different with other one
3/19/2011 9:19:58 PM • Harman Kardon... • Answered on Mar 19, 2011
My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
4/10/2010 7:30:27 PM • Harman Kardon... • Answered on Apr 10, 2010
Harman kardon avr 325 fan motor is making a noise.
Fans are typically not serviceable. They die, they get replaced. Maybe you could look inside it and see if it has dust on it, possibly unbalancing it. Then you could assess the scope of removing it yourself. My guess is the fan may be a common variety available at Radio Shack, unless it has an internal sensor circuit for temperature or rotation speed.
2/12/2010 10:36:09 PM • Harman Kardon... • Answered on Feb 12, 2010
Harman Kardon AVR 325 randomly switching inputs
Step one would be to ascertain exactly what the failure mode is - which input(s) aggravate it, what kind of connection, etc. Narrow the scope a bit.
The clicking and fickering sound like it's struggling with an intermittent source connection. When it starts flickering see if you can change the problem by wiggling the cables one at a time.
Do any of your video sources have multiple attachment types connected at the same time, say, hdmi and component, but to different assigned inputs?
4/30/2009 3:43:10 PM • Harman Kardon... • Answered on Apr 30, 2009
Shutdown during exciting audio
I have the same problem also. Customer service told me to double check all my cable wires to make sure there is no short. Heck I just went ahead and unplugged all the speaker wires and then it was fine. I replaced all speaker wires and it worked for a couple days but its starting up again. i did the hard reset like the manual told me to do but the same problem.
Thats what customer support told me to do. They said it could be because its going into a safe mode. Mine is just shutting down no matter what sound is coming out of the tv or movie.
4/11/2008 2:32:07 PM • Harman Kardon... • Answered on Apr 11, 2008
5answers
No sound from "Front Right" channel
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: MOST HK equipment have internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized HK service center must do this.] But, before you take this beast in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the left front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. HK is among the best equipment money can buy, and their equipment is pretty much "bullet proof!" Hopefully one of these "fixes" will work for you. GOOD LUCK!
1/24/2008 7:20:41 AM • Harman Kardon... • Answered on Jan 24, 2008
Harman Kardon AVR 630 8CH mode not available
According to the Harman-Kardon AVR 630 User Manual, if the 8CH mode is not available, you can try unplugging the unit from the AC wall outlet and waiting for at least three minutes. After the pause, reconnect the AC power cord and check the unit's operation. If the system still malfunctions, a system reset may clear the problem. The 8CH may not be available according to the user manual. You need to contact Harman-Kardon customer support.
10/26/2023 1:09:22 PM • Harman Kardon... • Answered on Oct 26, 2023
Harman Kardon 3490 Stereo Receiver. The standby light on but won`t turn on when power button is pressed.
Check the power button first. It is Ok ? It may require replacement.
10/23/2023 1:30:40 PM • Harman Kardon... • Answered on Oct 23, 2023
2answers
Hello, Our Harman Kardon receiver HK 3450 is showing error on desplay, and nothing realy goes. Also, when I put on the system, first, the left speaker makes a brrr noise for a little while...
i recommend you turn off the receiver and then disconnect it from the power outlet for a few minutes
8/31/2023 12:06:16 PM • Harman Kardon... • Answered on Aug 31, 2023
HOW I CAN CONNECT MICROPHONE IN HARMAN KARDON AVR-141/230
headphone is audio out for your headphones not audio in. you will need to buy mic pre amp and use output to aux or preferably tape in RCA connectors.
4/19/2023 4:59:16 PM • Harman Kardon... • Answered on Apr 19, 2023
2answers
Harman kardon avr 146 no front led display. but clicks on from orange light to blue. is there a fuse for display screen ? fuse at AC in is OK.
Hello, there is no fuse for the screen, there is a power supply circuit that makes it work and that if it is wrong the screen does not work The rest of the team works well? Can you hear something? if not, you do not have a display problem, you have a bigger problem If you have knowledge to review it, I will attach the service manual, but go to a specialized technical service Hola, no hay fusible para la pantalla, hay un circuito de fuente de alimentaci?n que lo hace funcionar y que si esta mal la pantalla no funciona El resto del equipo funciona bien?, puedes escuchar algo? si no, no tienes un problema de display, tienes un problema mayor si tienes conocimientos como para revisarlo, te adjunto el service manual, sino dir?gete a un servicio t?cnico especializado https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Harman-Kardon-AVR-146-Service-Manual.pdf
9/25/2022 8:24:59 AM • Harman Kardon... • Answered on Sep 25, 2022
2answers
Harman Kardon AVR PROTECT mode seconds after turning it on. No speakers are connected
Fault in one or more channels. Take your DVM and test for short circuits or take it to an HK repair shop.
9/25/2022 8:24:01 AM • Harman Kardon... • Answered on Sep 25, 2022
Poor Bass from my AVR-141
try electronic cleaner on volume
9/25/2022 8:17:33 AM • Harman Kardon... • Answered on Sep 25, 2022
Where can I get a schematic for a Harman Becker BEB200 amplifier?
Contact Harmon Kardon directly to inquire.
3/30/2022 11:37:11 PM • Harman Kardon... • Answered on Mar 30, 2022
Harman Kardon AVR 325 Receiver Logo
Popular Tags
16 questions posted
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Sean Wright
Sean Wright
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Harman Kardon Audio Players & Recorders
Most Popular Question
avr 254 not responding none its front
  • Audio Players & Recorders
