20 Most Recent Harman Kardon AVR 135 Receiver Questions & Answers
Can't access osd on screen display from remote control
Have you checked to make sure your TV is on the correct input? It should be on the input the Receiver is connected to in order for the OSD to appear .
10/6/2014 5:12:08 AM • Harman Kardon... • Answered on Oct 06, 2014
Center speaker does not work. diagnoses is the output from receiver is not functionin properly.
Try another speaker connected in that position with new wires And, what surround setting are you using for your setup? Thanks
5/27/2014 1:04:55 PM • Harman Kardon... • Answered on May 27, 2014
0answers
Factory reset
Be the first to answer 1/27/2014 12:30:28 AM • Harman Kardon... • Posted on Jan 27, 2014Be the first to answer
My Harman Kardon AVR 135 6.1 needs repair
You can bring your unit to Digital Dreams in SM North Cyberzone or in SM Megamall. They carry Harman Kardon brand and they accept unit for repair.
Hope this can help you.
Avamar23
8/15/2013 8:11:52 AM • Harman Kardon... • Answered on Aug 15, 2013
3answers
Will no turn on
i HAVE THE SAME PROBLEN. CAN ANYONE HELP PLEAZZZZZ!!!!!!!
10/27/2012 4:43:08 PM • Harman Kardon... • Answered on Oct 27, 2012
I have a active sub woofer (akari bazooka) but the
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
5/20/2011 5:41:38 AM • Harman Kardon... • Answered on May 20, 2011
0answers
My HK AVR 135 wont
Try unpluging the unit for atleast 2 hrs. The capacitors bleed off energy very slow, thats why it needs to be unpluged for a couple hrs. If that doesnt work it usually means the powersupply is going out.
3/30/2011 5:07:08 PM • Harman Kardon... • Answered on Mar 30, 2011
3answers
Hi dear. how can connect my dvd to hamman kardon
connect tv video in to kardon video out (tv audio in to kardon audio out) dvd audio and video out to kardio audio video in. and if you what to record also signal from tv. make a cable from tv audio / video out to kardon audio / video in.
5/26/2010 1:19:52 AM • Harman Kardon... • Answered on May 26, 2010
Need Help
Search the internet for 'white van speaker scam'. It will tell you all you need to know.
3/4/2010 11:44:49 PM • Harman Kardon... • Answered on Mar 04, 2010
Re: Harman Kardon AVR 135
The switching on this unit is done electronically via computer commands to the switching IC. I would guess that there is a problem with the power supply such that either the 5V line is too low (less than 4,4V) or that there is AC noise on the DC line. Any shop that handles audio equipment should be able to determine the problem with a few internal measurements. Typical parts costs for a repair of this type should be under $20.
Dan
1/30/2010 11:29:57 PM • Harman Kardon... • Answered on Jan 30, 2010
User manual needed
Go to www.harmonkardon.com. Choose "Product Support" fom the top menu bar, choose "Owner's Manuals" from the drop-down menu. Click on the "all products" drop-down arrow and select AVR-134. You can dowload a PDF user's manual.
Rhais
8/29/2009 10:07:56 PM • Harman Kardon... • Answered on Aug 29, 2009
Plugged a 110 volt kenwood receiver accidentally to 220 volts
Considering 220 and 110 systems have different receptacles, you worked at doing this.
Since it is already inoperable, you may as well remove the housing and inspect the guts. If you see burned traces or boards, don't bother to have it repaired.
If you see a fuse in a clip, you might replace it once, two would be the waste of the second fuse.
8/23/2009 7:22:12 PM • Harman Kardon... • Answered on Aug 23, 2009
How to connect a microphone in an harman kardon
The only way is to get yourself a separate karaoke mixer that you can connect to your receiver, or get yourself a small two channel disco mixer
8/3/2009 12:48:33 PM • Harman Kardon... • Answered on Aug 03, 2009
Harman Kardon AVR 135 Receiver Logo
36 questions posted
Top Harman Kardon Audio Players & Recorders Experts
Marvin
Marvin
Jaime Hernandez
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Harman Kardon Audio Players & Recorders
Most Popular Question
access osd screen display from remote
  • Audio Players & Recorders
