20 Most Recent Harman Kardon HKTS 14 System Questions & Answers
TS14 Sub woofer switch on and off with loud noise
Its a blue relay, with 4 posts. 2 for collapse thru an one negative one positive. That control open and close to relay. Imagine a relay like a swing open gate, When it's open nothing can flow through it when it's closed something can flow through it what you have is something causing that relay to open and close I'm not sure without a schematic what that blew relay is on the board if it's a safety Shunt For whatever but I have one in my hand right now doing the same identical thing. With Alice kamatik I can't track it I'm pretty sure it's every mode on relay or a safety relay not sure exactly without a schematic.
6/7/2020 4:21:04 PM • Harman Kardon... • Answered on Jun 07, 2020
The subwoofer on my HKTS Home Theater Speaker
Hello Ennisfamily, Typically these noises "present" when CHEESY capacitors... fail: (what I lovingly call "GUM-WRAPPER") break down... FAILURES are an ECONOMIC choice of the manufacturer (in my trained & experienced opinion). Although SAMSUNG has gotten most of the attention ... Most major manufacturers of CONSUMER grade "entertainment" equipment GLEEFULLY pocket a few extra cents for EACH high-grade (MIL Spec) QUALITY capacitor... THEY DO NOT BUY...!! Funny: (SAMSUNG kit available on AMAZON (electronic handling SKILLS & tools are required)). WITONICS Samsung LCD Plasma TV CAPACITOR Repair Kit Replacement Parts... I would ONLY say SAMSUNG is certainly NOT ALONE in the egregious (my opinion ... again) behavior. Yes... CERTAINLY REPAIRABLE Thou shalt not... open electronic enclosures without "static protection" Calunce Velcro ESD Antistatic Wrist Strap With 2 5M PU Adjustable... Hope this helps Carnac the Magnificent
11/11/2017 5:06:47 PM • Harman Kardon... • Answered on Nov 11, 2017
manual
My subwoofer will not wake up, regardless of whether I flip the switch from Auto to On or not. Suggestions?
The sub settings for testing should be: Crossover frequency - Max; Volume - Mid; Phase - Normal. As a quick test, unplug the sub cab from the amplifier/receiver end. Switch on the sub and turn the volume down all the way. Briefly put your finger across to short the RCA/phono tip and ring. The sub should make a buzzing sound. You now know that the sub is working and the cable appears to be okay or not. If you've got power then that's a good thing. It could be something simple as a broken solder joint or bulging capacitor.
9/11/2014 2:15:10 PM • Harman Kardon... • Answered on Sep 11, 2014
WHY is my harman kardon HKTS 15 subwoofwer is making a booming sound
Disconnect the cable and check the impedance/ohms with a meter.If rated at 4 ohms then it should read near that value.For 8 ohms also the reading should be near that value.You can buy a cheap Volt ohm meter for under ten dollars.After taking the ohm reading,it will be easier to diagnose................
8/26/2014 6:32:57 PM • Harman Kardon... • Answered on Aug 26, 2014
TS14 subwoofer LED stays orange
Navigate to this page ..on page #13 you have a exploded view of your subwoofer .
5/4/2012 12:56:16 AM • Harman Kardon... • Answered on May 04, 2012
I am getting no sound from sub. The turns on, but
Bear with me on this.
Just because two systems don't light this sub up doesn't prove the amps are faultless unless they work with other subs. Can you assert that?
See page 14:
http://www.retrevo.com/support/Harman-Kardon-HKTS-14-Speaker-Systems-manual/id/386ci056/t/2/
How are you driving the sub - Speaker or Line Level?
1/31/2011 1:58:27 AM • Harman Kardon... • Answered on Jan 31, 2011
Subwoofer is not responsive
big red
i think it migt have a broken wire replace it to be sure
10/23/2009 10:24:13 AM • Harman Kardon... • Answered on Oct 23, 2009
2answers
I have a Harman kardon 1700Avr that is stuck in protect mode, Is there anyway to bypass or reset it? Thanks....
It's in the protect mode because of a component failure inside. It needs to be repaired to get out of the protect mode.
6/13/2021 1:53:28 AM • Harman Kardon... • Answered on Jun 13, 2021
Harman kardon avr 510 reset
Page 53 of the manual
Troubleshooting Guide; Processor Reset - Harman Kardon ...
https://www.manualslib.com > ... > Owner's manual
Harman Kardon AVR 510 Manual Online: troubleshooting guide, Processor Reset. Symptom Unit Does Not Function When Main Power Switch Is Pushed ...
6/4/2021 4:23:04 PM • Harman Kardon... • Answered on Jun 04, 2021
Good day, please I do I fix my Harman Kardon protect shut down?
Xplain with more details.....
6/1/2021 4:17:22 AM • Harman Kardon... • Answered on Jun 01, 2021
Harman Kardon AVR 1700 only flashing power but will not stay on
You have electronics problem. a damaged component.
5/25/2021 12:48:28 PM • Harman Kardon... • Answered on May 25, 2021
Harman Kardon HKTS 14 System Logo
14 questions posted
Top Harman Kardon Audio Players & Recorders Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Harman Kardon Audio Players & Recorders
Most Popular Question
ts14 sub woofer switch off loud noise
  • Audio Players & Recorders
