20 Most Recent MSI Ge620-021us 15.6in Hd 1080 Led Notebook Questions & Answers
Fix Windows Script Host If you are experiencing script host issues, you might notice error messages such as "Library not registered." Script host issues occur when scripting components do not exist in the Windows registry, according to Microsoft. Your version of Windows determines how the missing scripting components affect your system. You can repair script host problems by using your PC's native features.
Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" regsvr32 %systemroot%\system32\vbscript.dll regsvr32 %systemroot%\system32\jscript.dll regsvr32 %systemroot%\system32\dispex.dll regsvr32 %systemroot%\system32\scrobj.dll regsvr32 %systemroot%\system32\scrrun.dll regsvr32 %systemroot%\system32\wshext.dll regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt. b> Register Components on 64-bit Systems b> Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" %systemroot%\system32\regsvr32 %systemroot%\system32\vbscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\jscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\dispex.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrobj.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrrun.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshext.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt.
Enable Windows Script Host b> Windows Script Host is an administration tool by Microsoft that creates an environment for hosting scripts. According to Microsoft, Script Host will manage security and invoke the proper script engine. Script Host comes standard on all Windows operating system versions 98 and later. Therefore, you can easily enable Script Host on your computer. Go to the Windows Desktop. Click on the "Start" button. Select "Run" from the menu of options and icons that opens. Type the word "regedit" into the text box of the Run window and then click "OK." The Registry Editor window will appear. Select "HKEY_CURRENT_USER\Software\Microsoft\Windows Script Host\Settings" from the folders on the left of the Registry Editor window. Double click on "Enabled" in the window pane to the right. Set the Value to 1. Return to the folders list in the Registry Editor. Select the folder "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Script Host\Settings." Again double click on "Enabled" in the window pane to the right and set the value to 1. That's it, you have successfully enabled Windows Script Host.
MSI Ge620-021us... | Answered on Jan 15, 2013
Use the recovery partition on your MSI laptop to recover its original factory settings. Recovering your MSI laptop to its original factory settings will resolve problems with instability that you may be experiencing as a result of missing system files that were accidentally deleted. Recovering your MSI laptop to its original factory settings will also completely remove any viruses on your computer's hard drive that you were unable to remove with anti-virus software. Fortunately, you can wipe all of the information off your laptop's hard drive and start with a clean slate.
Turn on or restart your laptop. Press "F3" repeatedly when the MSI logo appears on the screen during the boot process to be redirected to the "Windows Boot Manager." Highlight "Windows Setup [EMS Enabled]" using the arrow keys on the keyboard. Press "Enter" to access the recovery partition on the hard drive of the MSI laptop. The "System Recovery Option" dialog box will appear on the screen. Click "MSI Recovery Manager." Click "OK" when a message appears on the screen notifying you that your computer will be restored to its original factory settings. Click "OK" when a message appears notifying you that the hard drive will be formatted to begin the recovery process. A dialog box with a status bar will appear to indicate how much time is left in the recovery process. Depending on the of your hard drive as well as how much personal data needs to be erased, the recovery process could take up to 45 minutes. Click "OK" when a dialog box appears on the screen indicating that the recovery process is complete. Your laptop will automatically restart and boot up to the Windows setup screen, where you can begin personalizing the settings for your Windows operating system. Hope this helps.
b>
relic P4 pentium 4 mobo, with relic VIA chip set junk .
15 years old today, ..
via says most things work, what MS supports I'd never guess, Id try, it , takes no work at all
w7 installs while you watch games?on TV?
or mow the lawn.
https://us.msi.com/Motherboard/support/P4M900M2L#down-driver&Vista%2032
https://www.viatech.com/en/support/driver-support-faq/
MSI Computers &... | Answered 3 days ago
Fn+F8 toggles the wireless on and off.
MSI Computers &... | Answered on Jan 01, 2021
open your keyboard and cleans the key pad keys . If you using your keyboard more then 2 years its better to change it
MSI Computers &... | Answered on Jan 07, 2020
i want webcam driver for windows7...?
MSI Computers &... | Answered on Sep 12, 2019
I suppose, you won't be able to fix it that easily. Something is wrong with the keyboard and most likely you'll have to replace it. But I'd say that it is pointless. I mean, the laptop is a bit outdated so why not to get something better? There are so many options out there. If you need a laptop for doing job, here you can take a look at these laptops for quickbooks and daily accounting which can handle basically, any taks besides resource intensive ones like gaming, 3d rendering, etc.
MSI Computers &... | Answered on Aug 28, 2019
Although I've got a different type of MSI but I have where the "official guys" say there should be: at the back of it, maybe you need to remove the battery and look there under "S/N: xxxxxxxx"
MSI Computers &... | Answered on May 11, 2019
that 1996 is not correct (its series name only)
MSI N1996 Motherboard P6NG Neo-Digital MS-7505
the bottom sticker on the mobo tells what it really is.
MSI motherboard, just bought ? used"?
ever see it work before.
did you go to msi.com and the manual on setups"?
are you using the onboard VGA port to a VGA monitor.
The monitor shows no signal means exactly that.
This motherboard has 1 power jacks, the big one 24 pins
and the 4pin at top left of the fan.
you must use PSU v2.2 or newer to get that 4 pin power.
covered on page 24 in your manual, here.
https://www.msi.com/Motherboard/support/P6NG_NeoDigital#down-manual
and CPU and fan, (correct)
and memory
and a power switch to the power switch jack.
next time post all stickers on mobo so we can see what it really is.
they made vast numbers of motherboards. a fact.
MSI Computers &... | Answered on Apr 12, 2019
Well, you could uninstall anything related to the sound device. If you can, I suggest using the sound driver provided by the manufacturer. Let me know how it went, thanks.
MSI Computers &... | Answered on Jan 26, 2019
Beeping mostly means it's trying to give an error code along. Listen to the amount of beeps and the duration of them. This is the error code that it tries to give on. Look up in the manual what the beeps mean and how to solve it.
MSI Computers &... | Answered on Jan 17, 2019
Cheers!!
Need to replace the display flex ribbon cable to solve the flickering and color lines problem. This cable gets damage over the time of long usage.
MSI Computers &... | Answered on Nov 20, 2018
Add more RAM memory.
MSI Computers &... | Answered on Nov 10, 2018
No update will increase the speed.
There may be drivers from the keyboard manufacturer that need to be loaded in Windows.
MSI Computers &... | Answered on Nov 01, 2018
MSI Ge620-021us 15.6in Hd 1080 Led Notebook Logo
3 questions posted
Top MSI Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Davit Mamyan
Davit Mamyan
Roy May
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
return msi ge620 factory settings
  • Computers & Internet
