20 Most Recent NEC (ND-3520A-KIT-BLU) Burner Questions & Answers
NEC-3520A Suddenly stop to burn correctly, but reads OK
Have you tried lowering the burn/erase speed? To begin, simply do what you need to do on the lowest speed, and then keep increasing until it gives the error again. This will most likely work. I had this problem and I burn now CDs at 16x.
7/2/2007 5:10:39 PM • NEC... • Answered on Jul 02, 2007
Anytime I switch on my NEC laptop, it takes time to load and when it does. It turns gray with bios setup options
Hi, Please place the laptop into safe mode and run a virus scan within safe mode to ensure your computer does not have any unwanted threats that might lead to the issue that you're currently experiencing. Thank you.
7/28/2022 9:18:07 PM • NEC Computers &... • Answered on Jul 28, 2022
2answers
NEC Versa LX Screen will not come on
NEC Versa LX Screen no model told screen, a monitor is it"? the 1998 PC that? has no change at all to run zero. Pentium II (p2) relic, no modern OS run on it the coin cell battery and huge battery are toasted. hdd is bad. it has zero value now, and to fix it will be costly . the CCFL back lamps are dead. what is there to like, sure free in a garage sale. zero value. ,try moving from 1998 to 2010 to gain a future.
6/6/2022 5:46:00 PM • NEC Computers &... • Answered on Jun 06, 2022
Computer picture on HDMI Input above its native resolution of 1280 by 800 goes unstable on Nec M362w. Flickers from bottom of screen. Any ideas ??
USA? or where? ours is 60hz only, are you using 50Hz and bought in USA now it fails? dont do that. NEC M362w, connected to what? this is called a Projector. 1280 by 800 is native reso. so that is not a problem. Hz>? 50 or 60 or above>? what Hz./ rate.? OURS only does 60-hz how long is the HDMI cable 6 ft, or 60ft or what? what PC is it connected to. and is it set to 60 HZ or wrong page 146 in the manual covers all those tricking Horz,/vert/refresh rules the projector does this at other rates HDTV (1080p) 60 HDTV (1080i) 60 HDTV (720p) every monitor or projector or PC has limits here and seen here. for proj only. https://www.manualslib.com/manual/711311/Nec-M362w.html?page=157&term=hz&selected=13#manual set PC to 1080P and it will do ether, 50 or 60hz refresh. no PC told, no clues and matters huge.
3/22/2022 12:50:00 PM • NEC Computers &... • Answered on Mar 22, 2022
The sound on my nec versa p8210 is not working.
Try a pair of headphones to see if that part is working.
9/14/2021 1:30:00 PM • NEC Computers &... • Answered on Sep 14, 2021
Flash player 10 download
Hi
You can download the flash player from adobe's website i.e. from this link---
Flash player 10 download link
Alternatively you can download it from----
Adobe flash player 10
Daniel Scott
8/31/2020 3:37:19 AM • NEC Computers &... • Answered on Aug 31, 2020
2answers
I can not play movies
Hi..
AMR (Adaptive Multi Rate) is common audio file format for mobile devices like mobile phones, laptops, portable recorders.. etc.
in fact totem movie player can't play any amr files (files encoded in amr codec) by itself. Totem Player depends on Gstreamer libs, which haves necessary media handling components .
from your post its not clear that whether your totem can't play movie files from the very beginning or just you can not play movies recently.
your totem player may lacks Gstreamer library files or somehow your Gstreamer libs got corrupted recently.
Reinstalling Gstreamer Library file may help you.
you can find latest source version of Gstreamer on this page
(more detailed download of Gstreamer can be found on http://openports.se/multimedia/gstreamer-0.10 )
3/21/2019 11:11:54 AM • NEC Computers &... • Answered on Mar 21, 2019
2answers
Why my nec monitor 19" gets off after 5 or 10 minutes and along with their color doesn't working when I do select auto option
What is your power and energy saver settings at? Tap windows key and start typing power sl and power and sleep settings should be the first choice. If its not obvious from there, scroll down and or click additional power settings. And the time out reason should be listed and be changable from there.
3/15/2019 11:06:05 AM • NEC Computers &... • Answered on Mar 15, 2019
2answers
I have a NEC Multisync p462 lcd display monitor... I need to know how to display the monitor in portrait format (monitor on its side)
what is it hooked up to? If a windows computer you can quickly do this by holding down 3 keys at once. Ctrl + Alt + choose an arrow key. Tip if your doing this on dual display, what ever screen your mouse last clicked on will be changed when you do this. Ctrl + Alt + left arrow or right arrow depending on orientation desired.
3/15/2019 10:30:28 AM • NEC Computers &... • Answered on Mar 15, 2019
How add a NEC Multisync 70GX monitor to my PC win10
connect it to computer and power source and then right click anywhere on desktop. choose display settings. May need to scroll down in your display settings, but windows 10 will automatically detect additional displays from that screen. Then you can choose extend or duplicate and choose primary and resolution.
3/15/2019 10:24:04 AM • NEC Computers &... • Answered on Mar 15, 2019
I have a nec laptop but it has japaniss language i can,t change
In windows or the bios? If its Windows then reinstall windows with an english install media.
1/31/2019 3:10:48 PM • NEC Computers &... • Answered on Jan 31, 2019
How to make wifi extender through nec atren wm3500r in home wifi?
Firstly, check for reset button on your WiFi extender, press and hold for few seconds till all lights off.
Search for WiFi SSID and connect your laptop or mobile, browse for given ip on extender in browser, give it's password and follow the wizard to complete setup.
1/29/2019 3:41:26 PM • NEC Computers &... • Answered on Jan 29, 2019
How do I switch on the WiFi button on NEC VersaPro VZ-E tablet pc
Dear Chinthaka, In the case of nec versapro vz-e tablet pc, I cound't find any button for wifi. Only option to enable or disable wifi is using cmos setup at pc boot up time. Please find in cmos setup at pc boot up time. Good Luck.
11/27/2018 11:37:37 AM • NEC Computers &... • Answered on Nov 27, 2018
NEC (ND-3520A-KIT-BLU) Burner Logo
1 questions posted
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
David Shaub
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NEC Computers & Internet
Most Popular Question
nec 3520a suddenly stop burn correctly
  • Computers & Internet
