20 Most Recent
Canon Prima BF-80 35mm Point and Shoot Camera Questions & Answers
Cant take picture
First reaction, when your camera acts strange, is to switch it off. Then when the memory access light stops burning, or flashing, you can remove the battery (Batteries) Give it a few seconds, and then reinsert the battery. Now the camera will start from scratch. So if the problem was caused by a software problem, it should be solved.
Only when after switching on, the error reoccurs, you have a bigger problem, that perhaps only can be solved in a photo store, or at the service centre, closest to you.
Instruction
There are several different "Prima Shot" cameras. You can find manuals for some of them at http://butkus.org/chinon/canon_point_and_shoot/canon_pointandshoot.htm
Canon 12x36 is ii stabilization is not working properly. Stabilization
tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
Canon Digital IXUS 500 5.0MP is not powering on when CF card inserted.
In general Compact Flash Cards have to be formatted within the camera that is using them as they use a format proprietary to that camera. Also there are size limits on cards. If your camera will only take 16 Mb cards and you put a 32 Mb card in, it will not read it. It sees it as 'No Card Present'.
I think the other answer is an AI Answer Bot.
