20 Most Recent Canon EOS Rebel Ti / 300V 35mm SLR Camera Questions & Answers
Film door latch is loose
My crystal ball tells me that you are referring to you vintage 1939 Pentax SLR camera! Is that correct?
5/12/2017 2:01:09 PM • Canon EOS Rebel... • Answered on May 12, 2017
My camera is not turning on after i put the new
7/18/2016 7:25:43 PM • Canon EOS Rebel... • Answered on Jul 18, 2016
Replacement film door or rebel g11
7/18/2016 6:17:25 PM • Canon EOS Rebel... • Answered on Jul 18, 2016
Computer won't recognize my Canon XTi
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
11/17/2014 3:22:55 AM • Canon EOS Rebel... • Answered on Nov 17, 2014
Canon Rebel flash
The most common cause of the flash not popping up is liquid spillage, especially sticky liquids like Coke. If this is the case, you can work a business card on the right side and move back the latch to pop it up manually. Usually the spillage is on the right side where the large silver screw is. If you remove the screw carefully, you may find rust. Scrape it off with a sharp blade and then apply a light coating of lubricant grease to the screw and the hole. Be careful not to disconnect any springs. There are usually three screws on the bottom of the flash holding on the top cover. Be careful not to touch the wires and flash tube. There can be 300 volts which will cause a nasty shock.
11/4/2014 5:02:21 PM • Canon EOS Rebel... • Answered on Nov 04, 2014
How can I get repair parts for my eos elan 7 Canon film door?
Remove front cover to get to latch. Be careful not to touch the flash circuit as it can have a nasty 300 volt shock. Canon parts phone number: 732-521-7230. They used to take credit cards, not sure if they still do. They are really good about ordering by description.
11/4/2014 4:54:11 PM • Canon EOS Rebel... • Answered on Nov 04, 2014
All of my pictures are blurry and out of focus
I have a Canon Rebel T2i DSLR camera and all of my pictures are coming out blurry when I download them to my computer. WHY????
2/22/2011 3:28:06 PM • Canon EOS Rebel... • Answered on Feb 22, 2011
When I download my pictures
yeah , this is caused by messing around with the settings in the camera and you changed the resolution ..or the aspect ratio ..(for example from 4;3 into 16:9 and ending up with a wider format of the picture..)
The easiest way to get it fixed is to put into the normal mode ..than look in the menu ..and locate reset to factory settings ..or something like that ..It might be called different but it gets it to the original settings removing any personalization ..Find it in the menu ..(all camera has this option ) and engage it ..after that restart it ..and try to see if the new ones got back to normal ..
2/2/2011 5:14:18 PM • Canon EOS Rebel... • Answered on Feb 02, 2011
I have a Canon Eos T1i. I keep getting an Err 20
I have the same issue. I just bought the same camera and it seems its a lens/shutter issue from what I could find so far. I will keep searching and contact canon with this issue to get an answer from them.
1/26/2011 12:08:01 AM • Canon EOS Rebel... • Answered on Jan 26, 2011
When viewing my photos on my laptop they are
This is nothing to do with your camera. It is just a characteristic of the software that you are using to view the pictures. You may be able to change the settings of this software to make it frame the pics better, or you could get yourself a better viewer. I like FastStone, which is a free program you can download from the internet. Try searching for it at www.download.com
12/25/2010 2:50:13 PM • Canon EOS Rebel... • Answered on Dec 25, 2010
Says card protected and wont
A film camera is saying this?
Assuming you are referring to a digital camera of some type, take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
12/11/2010 11:56:00 PM • Canon EOS Rebel... • Answered on Dec 11, 2010
Hi I live in the Caribbean and I just purchase a
Hello sharon,
http://www.youtube.com/watch?v=ztoXoDMnwwA
try this youtube video.
regards,
mastergani
12/4/2010 5:00:48 AM • Canon EOS Rebel... • Answered on Dec 04, 2010
There's a distinct section on the left hand side
The camera has a sticking shutter assembly. The only cure is to replace the assembly and it's definitely not a DIY job and is not really cost-effective on a 35mm Rebel.
If the body is still under warranty then contact the seller for a refund/exchange.
9/2/2010 10:07:41 AM • Canon EOS Rebel... • Answered on Sep 02, 2010
3answers
My canon 300v doesn't wind on. the display goes
the problem was the lens
8/10/2010 6:26:11 AM • Canon EOS Rebel... • Answered on Aug 10, 2010
Shows card write protected..
Thanks for using Fixya.
(i) Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked. 9632f20.gif
(ii) Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Good Luck and have a nice day.
5/26/2010 4:46:23 AM • Canon EOS Rebel... • Answered on May 26, 2010
Problem transfering photos from canon t1i
Your card reader may not be the correct generation to read that 8gb card. Also if you use an AC power supply the camera may like it better since it may calculate that it doesn't have enough power to download that large of a card. I cannot tell for sure since the Canon rebel Ti is a film camera not a digital.
4/29/2010 7:45:26 AM • Canon EOS Rebel... • Answered on Apr 29, 2010
I have a Canon EOS Rebel Ti 35mm SLR Camera. I
Make sure the battery terminals are clean. Use a pencil eraser to scrub them until they and the battery terminals are bright and shiney. Other wise the camera will need a reapir and possible electronic parts replaced.
4/29/2010 7:41:38 AM • Canon EOS Rebel... • Answered on Apr 29, 2010
My canon eos 300v lcd screen is dead although rest
You can replace the LCD panel but will probably have to get it from a scrap EOS 300 and then work out how to do it yourself.
No camera repairer will touch your model though: it was a very cheaply made model designed and built on Canon's behalf by Kodak. As such it was really only designed to last up to five years and to then be thrown away. They simply aren't designed to be disassembled and repaired so other parts may break during the work and are quite literally worthless on the second hand market. When they do sell it's usually to those who make the mistake of thinking they're getting an EOS 300d...
It's not all doom and gloom though; because they're worthless perfectly good functional examples are sometimes available on FreeCycle and can be obtained for next to nothing on auction websites. Usually the only value is in the lens; cheaply made kit lenses are worth peanuts, but sometimes they come with a decent bit of glass which still retains a resale value.
I hope that my reply has given you a few realistic options regarding your camera and that you now understand why nobody else wants to repair it. Please take a moment to rate my answer.
3/1/2010 10:19:48 AM • Canon EOS Rebel... • Answered on Mar 01, 2010
Canon EOS Rebel Ti / 300V 35mm SLR Camera Logo
53 questions posted
Top Canon Photography Experts
old marine
old marine
Ekse
Are you a Canon Photography Expert? Answer questions, earn points and help others
View Most Popular
Canon Photography
  • Canon Photography
Most Popular Question
need free canon 300 35mm camera manual
  • Photography
