20 Most Recent Canon EF 17-35MM F/2.8L USM Lens Questions & Answers
There isn't one. Polishing out a scratch would alter the shape of the lens and ruin the image quality. Anything which fills the scratch will also alter the optical properties.
Just live with it, even fairly bad scratches are rarely visible in the images taken with a scratched lens although they sometimes catch the light at certain angles. using a lens hood will prevent that.
Canon EF 17-35MM... | Answered on Jun 23, 2011
99% of the time when this happens it's because the camera isn't making proper contact with the lens. If you unscrew the lens halfway you'll see it still says MF but the aperture will turn to "00". Use a clean pencil eraser to clean the contacts on the back of the lens and try again.
Canon EF 17-35MM... | Answered on Feb 15, 2011
Ok for one if your lens works on AF and it doesn't work on M, then you have bigger problems. I think that the gearing for the lens must have jammed when it went it gets put on M, so someone in the past must have messed with it in AF and jammed the gears. Thats my guess. I would recommend getting it fixed but if your lens isn't worth as much as the fix just go buy a new one.
Canon EF 17-35MM... | Answered on Feb 16, 2010
Sounds like your imaging sensor has failed and is not recording blue or green tones. Take your camera to a good camera store or send it to Canon for a service estimate.
Canon Cameras | Answered 3 days ago
This answer is 8 years too late, but whatever. The PC1263 is actually the PowerShot A590 IS. To delete all photos, press the "MENU" button, select the "Playback" tab (the one that looks like a little triangle) and scroll down until you see the option "Erase All." Press the Select button and confirm. All photos will be erased.
Canon Cameras | Answered on Jul 31, 2020
9 years old model, probably not worth repair. You can get used one on ebay for little money
Canon Cameras | Answered on Jul 18, 2020
Feel free - we won't prevent you.
Canon Cameras | Answered on Feb 13, 2020
Same as any camera - uncover lens, point camera at subject, press shutter button. Simples.
Canon Cameras | Answered on Dec 31, 2019
The current firmware is version 2.1.2. Use this link to get to the Canon download page. Scroll all the way down to “Drivers and Downloads”. Select “Firmware” and then the appropriate version for Windows or Mac.
https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/support-dslr/eos-5d-mark-ii?subtab=downloads-firmware
Canon Cameras | Answered on Oct 26, 2019
The camera is trying to process information to or from the memory card. If the status does not change after a few minutes, you may have a damaged memory card. Turn the camera off. Remove the memory card and inspect it. Reinsert the memory card. Can you view photos on the LCD by pressing the arrow button? If so reconnect to your computer. If not, you most likely have a damaged memory card. Try inserting the memory card into a card reader connected directly to your computer. This may be able to still read the card when your camera cannot.
Canon Cameras | Answered on Oct 03, 2019
Canon EF 17-35MM F/2.8L USM Lens Logo
6 questions posted
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
scratch
  • Cameras
