20 Most Recent Canon EF 50mm f/1.8 II Lens Questions & Answers
Canon 50mm 1.8 error 01
Have a look here http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/#err01 Seems to be a connection problem Clean to connectors on both the lens and camera with a pencil eraser.
3/14/2016 8:18:51 PM • Canon EF 50mm... • Answered on Mar 14, 2016
Canon 50 mm 1.8 communication error 01 lens
Might be that the aperture is stuck and you need to get the lens repaired (might cost more than a new lens.) Or it might just be bad contacts. Clean the contacts and try another lens before asking Canon or dismantling the lens.
2/13/2015 7:14:14 PM • Canon EF 50mm... • Answered on Feb 13, 2015
2answers
How to fix the communication error canon 1.8 50mm
Turn camera off, remove lens Replace lens, turn camera on. To help prevent it from happening again, you can try cleaning contacts on both camera and lens.
2/13/2015 7:11:50 PM • Canon EF 50mm... • Answered on Feb 13, 2015
2answers
My lens fell down and I think is not broken but
Get a quote first for the repair as this lens is the least expensive Canon lens and it could be that the combined cost of postage and repair will exceed to cost of a brand new replacement.
2/13/2015 7:09:04 PM • Canon EF 50mm... • Answered on Feb 13, 2015
How to fix err 01
you have a faulty connection between the lens and body of the camera
  • remove the lens clean contacts on lens and the body of the camera
  • remount the lens
  • if you still encounter the error turn off the auto focus switch .
  • take a test shot (manual focus)
  • if you did not encounter the error your lens might have a faulty flex cable have it checked / replaced at the service center
8/26/2014 12:45:13 AM • Canon EF 50mm... • Answered on Aug 26, 2014
Hi there, I don't know if
You may just have the left auto focus points selected. You don't say which camera model you have. If on the back of your camera you can see a button with an icon showing 5 small white blocks in a plus sign in a white box press this to select the auto focus points. It should show the available auto focus points and then use the left/right (wheel) button to change the selection
8/6/2014 7:30:17 PM • Canon EF 50mm... • Answered on Aug 06, 2014
My canon 50mm 1.8 II focus length does not work.
Can you still switch AF/M?
1/10/2014 3:07:05 AM • Canon EF 50mm... • Answered on Jan 10, 2014
How do you remove the macro lens
The 50mm f1.8 lens is not a macro lens. If you attached a close up filter, it should just screw off. Try not to squeeze the ring too tight as that may make it harder to remove. Also "righty tighty - lefty loosey"
12/15/2012 12:32:43 AM • Canon EF 50mm... • Answered on Dec 15, 2012
3answers
Dropped the lens, nothing broke but focus ring came undone
This will need technical service eventually. Try temporary solution with Sellotape or similar
1/20/2012 7:03:19 AM • Canon EF 50mm... • Answered on Jan 20, 2012
I cannot get my new
Make sure you're holding down the lens release button, which is located on the front of the camera, while turning the lens. Sometimes a little bit of force is needed, I've found new lens' can stick a little bit. If it still won't come off, contact Canon.
5/10/2011 8:47:36 PM • Canon EF 50mm... • Answered on May 10, 2011
Hi. Canon EOS 40D + canon 50mm f/1.8 II. when I
I think you should upgrade you cameras software firts.
5/2/2011 1:23:53 PM • Canon EF 50mm... • Answered on May 02, 2011
2answers
Canon 50mm f/1.8 lens is not focusing.
I had the same problem with my ef 50mm 1.8. I used it on a cold day and broke off one of the internal gears. I used it for almost a year before I got the guts to take it apart and fix it. There are instructions online on how to take it apart, scary at first but not that hard overall. I used a small drop of crazy glue on the gear, put it all back together and just like new.
9/18/2010 4:51:46 PM • Canon EF 50mm... • Answered on Sep 18, 2010
Can i strip and clean the inside of my Cannon EF
You can. But do you have a lens collimator and other equipment needed to ensure proper alignment when you put it back together again? Without such gear, the resulting pictures will probably be worse than they are now.
5/17/2010 7:04:54 PM • Canon EF 50mm... • Answered on May 17, 2010
I don't think so. the lens is held by 3 or 4 internal plastic hook clipping type . send it to canon cost about 30 bucks. one clip breaks, you can say goodbye to your lens.
3/30/2010 9:52:04 PM • Canon EF 50mm... • Answered on Mar 30, 2010
2answers
Dropped the lens, the focus ring won`t move
You can send it to the canon-service but i think it will be cheaper if you buy a new or used one.
8/11/2009 9:02:47 PM • Canon EF 50mm... • Answered on Aug 11, 2009
Cleaning inside Canon 50mm /f1,8 II
you can have a look here:
http://www.ejarm.com/photo/ef5018iidis/
and here:
http://nis-lab.is.s.u-tokyo.ac.jp/~ybando/rgb_filter/disassembly.pdf
HTH,
Jean-Marie.
1/19/2009 11:12:06 AM • Canon EF 50mm... • Answered on Jan 19, 2009
Canon EF 50mm f/1.8 II Lens Logo
30 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
canon eos 40d canon 50mm f 1 8 ii
  • Cameras
