20 Most Recent
Canon PowerShot G2 (Black) Digital Camera Questions & Answers
White LCD on my canon
Hi:
I think you have broken (accidentaly with the fall) the cable with several wires that connect the LC display.
My real advice is that you take your camera to a store were they can give you direct support desmanteling the camera and replacing the cable or fixing it.
However, Zair already had a problem like yours and the best solutions was given by BowerR64. You can consult on the following page:
http://www.fixya.com/problems-solutions/t103443,p294056/Canon-PowerShot-G2-Digital-Camera.aspx
(just copy and paste on the address bar)
Regards
Canon G2 Powershot suddenly went dead
I read of a simmilar problem - a "zoom brush", caused by a faulty part, number CL1-1006-000. Usualy it appears earlier in the cameras career though...
Did you try leaving it battery-less for a bit longer than the short changes? Remove it from all possible power sources(There is a small battery inside the main battery compartment) for at least a few minutes. It should reset it in case its just a system crash. Just be aware that after the reset it will ask you to input date and time, and theres another known bug of most of the buttons freezing after inputing date/time. should be fixed by pressing the display button.
Hope you manage to fix it somehow...
How do I attach the wrist strap to the Canon PowerShot D30 camera
The wrist strap has a thin loop on one end. Thread this thin section (like threading a needle) through the strap hole. (It's on the left side of the camera. There are two openings with a bar over the top of the center of them at the bottom corner of the camera body.) Start threading from the middle of the body of the camera and push the strap towards the bottom of the unit. You may need to twist the loop to narrow it and keep it tight. Once you have this narrow loop through the camera, open up the loop and slide the thick material through the center of this thin loop. Pull the wrist strap until the thin loop tightens around the bar.
This is shown on page 12 of the D30 manual. The manual is available from Canon support on the Powershot page:
http://gdlp01.c-wss.com/gds/5/0300013985/02/psd30-cu2-en.pdf. The direct link to the manual is
http://gdlp01.c-wss.com/gds/5/0300013985/02/psd30-cu2-en.pdf .
I hope this helps.
(Many lanyard straps for electronic gear work the same way. Threading the narrow section under that bar does require decent near point vision. People who are far-sighted may need to wear bifocals or ask someone younger to assist.)
LOST THE VOLUME ON VIDEO, HOW TO FIX?
Do you mean when playing video back on the camera? If so, when the video is playing, press on the top of the wheel, the part with the triangle pointing upwards (up-arrow). You should see the small volume level indicator get an increasing number of bars and the volume will increase.
