20 Most Recent LifeView LifeTV (720661115) TV Input Questions & Answers
you probably have to try flytv prime only and the drivers for vista (which usually may work also in win7 systems, as there does not seem to be any specifical to your flytv prime spo yet avaliable from the manufacturer.
it's an alternative that can be worth to try. find it here
if this does not work you may have to upgrade your device to a known supported win7 compatible device.
LifeView LifeTV... | Answered on Apr 04, 2010
download the factory defaults and reload them into it then upload your new fix back in to it
LifeView... | Answered on Apr 16, 2009
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Abctay com China Wholesale Wholesale Electronics Gadgets tv parts power...
Televison &... | Answered 5 hours ago
Your TV has been child locked. In order to unlock it , on the remote control,there is a MUSIC / SOUND BUTTON.You must press and hold this button for about 10 seconds and it will unlock your TV.
Let me know if it works by clicking COMMENT
Televison &... | Answered 17 hours ago
Would that be on a Sat Nav or TV or Plasma screen or ......../...
Televison &... | Answered 2 days ago
ARE YOU QUITE DAFT OF COURSE YOU CAN NOT DO IT
Televison &... | Answered on Aug 01, 2020
Remote could be faulty, the buttons could be stuck, the power supply could be faulty.
Projector ... computer ... sat nav ... what!
complain to your telco / router provider. You don't have a good enough internet signal or the wifi signal is not strong enough. Run Speedtest.
That looks suspiciously like French, but still doesn't make sense translated!
How to configure Remontes Replaced RRS41 remote control
Google
make model (of television) replacement remote control
or
(make of television) remote codes
or
(make of wonky remote) programming
Go to Prime Video Settings --> Parental Controls from your web browser.
Open the Prime Video PIN section under Parental Controls.
Enter the number to set up your PIN. Select Reset your PIN to change your current PIN.
Televison &... | Answered on Jul 31, 2020
HI there do check all circuit boards in back cover for any blown fuses or other electronic components , If all good then you will have to remove LCD screen to test LED lights . switch TV on from standby mode and shine a LED torch onto screen with room completely dark if ICONS do display ,Then i wood recommend for you start off checking your power supply circuit board or driver board . A easy way of checking if LED lights are working again in a dark room with TV switched on look through back cover vent holes for any light shinning through small openings this would determine if some or all back LED lights are blown.
Televison &... | Answered on Jul 30, 2020
Insert a thin, flat-head screwdriver beneath the VHS tape inside of the deck. Very Gently pry upward on the tape until it comes free from the tape deck's heads. Grasp the tape with a pair of needle-nosed pliers. Pull the cassette out of the deck.
LifeView LifeTV (720661115) TV Input Logo
Popular Tags
3 questions posted
Top LifeView Televison & Video Experts
Marvin
Marvin
Are you a LifeView Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • LifeView Televison & Video
Most Popular Question
need driver windows 7
  • Televison & Video
