20 Most Recent Sony Kdl-32cx520 32" Full Hd Multi-system Lcd Internet Ready Tv Questions & Answers
First turn on device to be programmed. Press what device you want to program (tv) hold it down and at the same time hold power button down. Wait for red light to shut off and come back on. When light comes on remove finger device button and continue to hit power button on & off until device shuts off. Then hit stop button on the bottom off remote.
Sony Televison &... | Answered on Aug 04, 2020
Take it to a Sony Service Centre to save your money and get it fixed properly.
Sony Televison &... | Answered on Jul 20, 2020
If the screen of your TV is black and nothing is displayed, see the FAQ below: No picture on the TV screen.
When using a TV with the Self Diagnostics option, try the Self Diagnostics test. For details, refer to the following Q&A: How to use the Self Diagnostics option.
Sony Televison &... | Answered on Jul 13, 2020
Are you a television engineer? Do you have all the test equipment? Normal people can't repair their own televisions. Do you know that the main board you put in was a good one and not out of a scrapped set? Can you send it back and ask for another one? Taking it to a television engineer is by far the cheapest way to fix. Or you can change all the boards, but make sure you buy them from the manufacturer and not Jimmy. Change all the boards before you turn on the power to avoid 'domino effect', one bad board kills all the other boards attached to it.
Sony Televison &... | Answered on Jul 09, 2020
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sony Televison &... | Answered on Jul 01, 2020
Hello
Blu-Ray players' region hack proceedings are yet to come.
Sony Televison &... | Answered on Jun 24, 2020
It won't work as it has a different size screen and will produce the wrong size picture, if it works at all.
Sony Televison &... | Answered on Jun 19, 2020
google unit or call sony tech support
Sony Televison &... | Answered on Jun 08, 2020
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site either in Web View, on a mobile; or by a desktop PC. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sony Televison &... | Answered on May 28, 2020
Sony Kdl-32cx520 32" Full Hd Multi-system Lcd Internet Ready Tv Logo
1 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony bravia kdl 46v55 t con board
  • Televison & Video
