20 Most Recent Argus DC3515 Digital Camera Questions & Answers
Got the camera used w/o manuel or disk. need to know how to use it
First of all, thank you very much James for choosing FIXYA today for your online technical support needs. Here is a direct link to the ONLINE USER'S MANUAL for that model:http://www.arguscamera.com/support/manuals/DC3510-15.pdf To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual. You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.And here is a link to the ARGUS Support page where you can download the necessary drivers for that camera:http://www.arguscamera.com/support/index.html I truly hope that was helpful to you. Good luck and take care. Joe.
12/22/2011 5:46:08 AM • Argus DC3515... • Answered on Dec 22, 2011
I need user manual
4/7/2011 5:20:26 PM • Argus DC3515... • Answered on Apr 07, 2011
Camera does not work with
Probably the card is locked or you haven't formatted it yet here is a diagram for the SD card.
Diagram
I wasn't able to obtain a manual but I would expect to format you would need to go into the camera menu set up scroll through to Format generally at the last follow the screen instructions to format
1/18/2011 1:01:13 AM • Argus DC3515... • Answered on Jan 18, 2011
My argus cintar DC5315 will not work with a 2GB SanDisk SD card
Due to the devices age (i have one too, i bought it Christmas 2005) its internal parts are not as strong as newer cameras, and therefore, cannot support as much memory as new cameras. I have an 8gb SD card and the camera does not even turn on with that much space, but with 128MB it works just fine.
1/24/2009 4:26:04 PM • Argus DC3515... • Answered on Jan 24, 2009
Driver
What operating system are you running please?
5/16/2008 5:08:31 AM • Argus DC3515... • Answered on May 16, 2008
Fan won't turn on in a argus 300 projector
Steps : 1) W/the power cord UN-pugged, remove the 6 screws holding the 'metal projector portion' to its lower wood case. 2) If you find loads of old dirt, spider webs, etc present on the underside then vacuum them all off well, _especially_ around the fan motor. 3) Position the 'metal projector portion' on it side, on it's lower wood case, such that you can both see the fan blade _AND_ the bulb (in my case = Sylvania CLS, 300W, 120V) is not touching the wood case. 4) Manually try to spin the fan blade. 5) If the fan blade spins freely and the wires connecting it to the AC power are sound then you might have a bad fan. The orig fan (at least in my 300) was marked as follows { The Alliance Mfg. Co, Alliance O (letter 'O' or number '0', not sure), Alliance No. 2261890, winding ohms ~35 ohms, and on 115V the fan draws~ 2.5A AC current once it warms up } So in this case, w/the AC connector unplugged from power and w/bulb switched OFF, you're looking for a stable 30<->40ohms across the AC cord connector. If you're not seeing that then might try tightening the only wire nut present that goes to the fan and re-CK ohms. Otherwise, unless the other soldered connection looks bad, then you likely need a new fan motor. 6) However, if the fan blade seems bound, resistant to spinning (ie: a flick of your finger should normally yield 5-7 revolutions) then there may be a solvable issue in the area of the rear bearing assy. To verify :: 6.1) Remove the fans rear bearing cap (you may need an ice pick or small screw driver shoved in sideways to hold the machine screw's Philips head while removing each nut). 6.2) Grasping the exposed shaft, if the fan can now be rotated much easier by twisting the shaft in your fingers then the issue is in the area of the rear bearing assy area. Clean the bearing cup well and add a few drops of 3-in-1 oil to the oil matt in the rear bearing's cup that surrounds the bearing. Clean the shaft area well. And pay attention to a small fibrous washer on the shaft {it's height & it's OD -vs- ID might be a bit more than ~1/16-in } and if you see some fibers ( ? fiberglass ? ) flaying outward toward the rear bearing area (when latter is installed) then try to brush them off. Then add one drop of 3-in-1 oil to the shaft where it mates to the bearing. Then re-install the rear bearing's cup via its pair of machine screws previously removed. If the fan now spins freely then it's very likely you've fixed the problem. Making sure the lamp switch is OFF, and no one (especially children) will be touching the exposed AC connections, you can quickly test by plugging in the 300's AC cord (as the fan is wired to always come ON). 6.3) Otherwise, still NoGo then you're likely back to '5)'s need of a new fan motor.
12/20/2023 7:10:58 PM • Argus Cameras • Answered on Dec 20, 2023
How can operate argus mastershow super eight projector..?
Follow the instructions in the manual.
6/6/2019 8:15:11 PM • Argus Cameras • Answered on Jun 06, 2019
How do I focus the lens on my argus 500
I presume you mean the slide projector, not the 1960s computer? With most projectors, you merely rotate the lens, which is on a helical mount, until the picture is sharp.
5/23/2019 9:17:58 PM • Argus Cameras • Answered on May 23, 2019
I have an Argus pre-viewer IV What kind of batteries goes in ?
The same kind that you took out, I expect. Is this not mentioned in the manual ?
1/27/2019 11:27:07 AM • Argus Cameras • Answered on Jan 27, 2019
Where can i get projecter belts for a argus holiday dual 848
Look on eBay
7/24/2017 6:32:50 PM • Argus Cameras • Answered on Jul 24, 2017
2answers
Need manual for argus dualmaster super eight
Have you tried googling this as many manual can be easily found over the internet. If you cannot find it, then try calling the local agent or manufacturer.
7/4/2017 9:08:37 AM • Argus Cameras • Answered on Jul 04, 2017
Manual for argus dualmaster super eight
What about it ?
7/4/2017 9:08:07 AM • Argus Cameras • Answered on Jul 04, 2017
I cannot get my argus DC1500 camera update for this USB dual mode camera. I have tried to find a way on the camera itself and also on the net. Help would be appreciated.
What makes you think there would be any update for your camera? Software updates most of the time only are done on system cameras and DSLRs, when the factory wants to add extra info, like for new equipment (lenses) for most cameras there is never any update. when you did register the camera online, they will inform you when any update will be released.
3/14/2015 11:52:30 PM • Argus Cameras • Answered on Mar 14, 2015
5.0 mega pixels need to know how to work it
What is the exact model number?
7/31/2013 12:29:36 AM • Argus Cameras • Answered on Jul 31, 2013
0answers
Argus DC3515 Digital Camera Logo
6 questions posted
Top Argus Cameras Experts
ZJ Limited
ZJ Limited
k24674
Are you an Argus Camera Expert? Answer questions, earn points and help others
View Most Popular
Argus Cameras
  • Argus Cameras
Most Popular Question
driver
  • Cameras
