20 Most Recent Google Android GS30 9.7 inch Samsung ARM Cortex A8 2.3 Tablet PC Questions & Answers
Revert back to factory by hard reset!
Tablets &... | Answered 2 hours ago
Hard factory reset!
Tablets &... | Answered 5 hours ago
If you did a hard reset to factory then that would return the tablet to as new when there was no password!
Something does not make sense!
Tablets &... | Answered Yesterday
First of all, check the device's power is off. Then open the sim card slot and place the sim with gold plating downward and close the slot. You are good to go with your tablet.
How to Recover Data from Android Phone with Black Screen
Broken Android data Extraction can help you recover data from black screen of Android phone.Note that currently the data recovery from black screen phone supports to Samsung galaxy S6/S5/S4,note 5/4/3.
You will be able to recover contacts, photos, messages, videos, music, call history, WhatsApp chats, documents from black screen Android phone.Generally speaking you should be able to recover data from broken Android phones by this program with broken screen, black screen, touch screen not work, can't enter system or more circumstances.
LEARN MORE
Hi, you need to perform a factory reset, follow these instructions:
  1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
  2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
  3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
  4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
  5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
  6. Use the volume buttons to move up and down through selection in this menu.
  7. Using the volume down button, scroll down to "Wipe data/factory reset"
  8. Tap Power hard key to select option.
  9. Scroll down to select "Yes, delete all user data".
  10. Tap the power button to select. Wiping and formatting data will take a few minutes.
  11. You will return back to the Android recovery screen menu.
  12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Try
Settings / Backup & Reset / Reset
Hi Doug
I press two buttons at the same time on my tablet and a photo goes into my photos
Volume Down and Power buttons at the same time
Cheers
OR
Use a dedicated App
6 Ways To Take Screenshots On Android
Screenshot Capture Android Apps on Google Play
Google Android GS30 9.7 inch Samsung ARM Cortex A8 2.3 Tablet PC Logo
2 questions posted
Top Google Android Tablets & eReaders Experts
ray gallant
Dayton Computer
Dayton Computer
FiFo
Are you a Google Android Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Google Android Tablets & eReaders
Most Popular Question
just purchased google android 4 0 m710
  • Tablets & eReaders
