20 Most Recent Google Android 10.1 inch 4.0 Capacitive Screen Tablet PC Questions & Answers
Check your charger output using tester or try to other unit. If it is working ot means your tablet battery is defective or damaged. Replace your battery.
Google Android... | Answered on Mar 20, 2015
Replace a new battery beacuase means your battery is damage. Dont use your unit while charging to prevent battery from damage.
I'm having the same trouble. Did you get it going. I'd love to know.
Google Android... | Answered on Mar 16, 2014
you have to go to your home computer and go to google.com and reset your password then login to Google on your tablet you should be ok
Google Android... | Answered on Feb 28, 2014
How to Remove Google FRP lock on any phones 2017 trick 100 ...
? 5:53
https://www.youtube.com/watch?v=COwNLg9phMU
Sep 14, 2016 - Uploaded by ROY 4K
this is the trick to unlock google lock on any devices you don't need computer or OTG ... can u able to bypass ...
2 Ways to Bypass Factory Reset Protection on Samsung devices 2017
https://www.progeeksblog.com > Android Aug 21, 2017 - Follow the steps to bypass Google account verification after hard resetting your Samsung Galaxy device. ... With the release of Android 5.0 Lollipop, Google introduced Factory Reset Protection to protect your device and personal data. ... Here is the download link: Bypass Samsung Google ...
New FRP Bypass APK 2017 - (100% Working step-by-step guide)
https://www.progeeksblog.com/frp-bypass-apk/ Download New FRP Bypass APK 2017. As we all know, with the release of Android 5.0 Lollipop Google introduced a new security feature called Factory Reset ...
Try The NEW Method To Bypass Samsung FRP - PROGEEKS BLOG
https://www.progeeksblog.com > Android May 29, 2017 - A new trick has been released to bypass Factory Reset Protection on your Samsung ... Recently I published a post on Samsung FRP Bypass. as of that time, it was .... Latest video tutorial shows how to bypass Google FRP.
Top 10 FRP Bypass Tools to Bypass Google Account - dr.fone
https://drfone.wondershare.com/factory-reset-protection/top-10-frp-bypass-tools.html Sep 7, 2017 - Get to know about some of the FRP bypass tools of 2017 to bypass google account right here. We have listed every essential FRP bypass app ... ‎Tool 2: Remote Google ... · ‎Tool 3: FRP Bypass APK ... · ‎Tool 4: A New FRP ...
Bypass Google FRP After a Factory Reset on Samsung Devices ...
visihow.com/Bypass_Google_FRP_After_a_Factory_Reset_on_Samsung_Devices Bypass Google FRP After a Factory Reset on Samsung Devices Device is Working Fine vs Device has Already been Reset and FRP Pops Up vs A Different ...
How to bypass "Verify your account" (Factory Reset Protection ...
https://android.stackexchange.com/.../how-to-bypass-verify-your-account-factory-res... Nov 2, 2015 - As per my other answer, this will remove FRP from the device. ... If he sends the phone back to you: Log in with your Google account at the ...
Easy Way to Bypass Factory Reset Protection on Samsung Devices
www.techoxygen.com/easy-way-to-bypass-factory-reset-proteciton-samsung-devices/ Feb 21, 2017 - Easy method to bypass Google account on Samsung devices. Unlock FRP and remove previous synced Google account from your Samsung ...
How to: Bypass Google Account Verification (FRP Lock) on Any ...
www.jgtechblog.com/bypass-google-account-verification-1812/ Mar 16, 2016 - Google introduced the Factory Reset Protection for Android devices with the launch of Android Lolipop, the feature is like the Apple's iCloud ...
How to bypass Google Account Verification (Factory Reset Protection ...
https://www.unlockscope.com/.../bypass-google-account-verification-factory-reset-pr... Jun 24, 2016 - How can you bypass the Google Account verification feature after a ... the new Google Account Verification or Factory Reset Protection (FRP) ... Bypass google FRP Google Search
Tablets &... | Answered Yesterday
*On your Android phone or tablet, open the Chrome app .
*To the right of the address bar, tap More. Settings.
*Tap Site settings. Pop-ups and redirects.
*Turn Pop-ups and redirects on or off.
Tablets &... | Answered 2 days ago
I know it sounds oversimplified, but this could just be a weak battery. Try switching off the tablet and plugging it into the charger for at least 12 hours before trying to restart it. Holding the power button down for 10-15 seconds when you do restart it could also help.
hi there.
this is all i could find out from the internet so not sure if it will work for you.
I think it,s time for a factory reset , you will lost all you data !!!!!
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
or try this link out.
android man on his back with red triangle on his chest Google Search
Revert back to factory by hard reset!
Hard factory reset!
If you did a hard reset to factory then that would return the tablet to as new when there was no password!
Something does not make sense!
Tablets &... | Answered 3 days ago
Google Android 10.1 inch 4.0 Capacitive Screen Tablet PC Logo
12 questions posted
Top Google Android Tablets & eReaders Experts
ray gallant
Dayton Computer
Dayton Computer
FiFo
Are you a Google Android Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Google Android Tablets & eReaders
Most Popular Question
battery runs down fast
  • Tablets & eReaders
