20 Most Recent Google Android 4.0 7 inch 1080P Video Capacitive Screen 16GB Tablet PC Questions & Answers
I tried this its not working... please help
Google Android... | Answered on Apr 19, 2019
Can you check your charger voltage with a meter? And, make sure it's the right charger for the tablet. They all look a lot alike.
Google Android... | Answered on Nov 28, 2017
The symptom you described may be due to the main battery being discharged. In many tablets, there are 2 batteries, one main and one used to keep memory intact during suspend mode. When the unit powers on, it turns on the backlight (probably the highest power drain of anything on the tablet) so you can see the icons on the screen. If the main battery doesn't have enough energy, the sense logic will put the machine back into suspend mode, and it will appear to go off. You should plug your charger in, and see if this fixes the problem. If it doesn't then you need to check the voltage of the charger with a meter. If you don't have a meter, you can buy then at Harbor Freight for around $5. With the meter on, and the charger plugged in, stick the red lead of the meter in the center hole, and touch the black lead to the barrel of the power connector from the charger, and you should read some volts. The charger should say on it somewhere it's output voltage. Hopefully you've marked your charger with what device it goes to because many chargers look the same and have the same power connector but are not in fact the same.
Making the screen brighter uses more energy. So if you were successful with your "sun" icon, you could have made the problem worse.
Google Android... | Answered on Nov 27, 2017
Replace your tablet battery
Google Android... | Answered on Mar 20, 2015
Press volume down while turning on then choose restore to restore your andriod os
Look in your manual and find out how to do a 'hard reset'.
If this info is not in the manual, take it back to the retailer and get them to do it.
Google Android... | Answered on Apr 03, 2014
Tyler....File format means the type of file the data was written to. For example, some Music is in MP2 or Mp3 for example. WMA is another. You must know what format your tablet understands in order for the tablet to translate the song in to a playback mode. This information is in your operations manual that came with the tablet.
Google Android... | Answered on Dec 25, 2013
CONNECT TO POWER SUPPLY .... PRESS ON BUTTON (20 SEC) THEN ... WITH OTHER HAND / FINGER KEEP TAPPING SCREEN .... REPEAT UNTIL TAB WAKES UP
Google Android... | Answered on Jul 22, 2013
most any manuels, remote, phone, camera can be downloaded from internet. Either from company site or I usually google it
Google Android... | Answered on Jun 27, 2012
How to Recover Data from Android Phone with Black Screen
Broken Android data Extraction can help you recover data from black screen of Android phone.Note that currently the data recovery from black screen phone supports to Samsung galaxy S6/S5/S4,note 5/4/3.
You will be able to recover contacts, photos, messages, videos, music, call history, WhatsApp chats, documents from black screen Android phone.Generally speaking you should be able to recover data from broken Android phones by this program with broken screen, black screen, touch screen not work, can't enter system or more circumstances.
LEARN MORE
Tablets &... | Answered 9 hours ago
Hi, you need to perform a factory reset, follow these instructions:
  1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
  2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
  3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
  4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
  5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
  6. Use the volume buttons to move up and down through selection in this menu.
  7. Using the volume down button, scroll down to "Wipe data/factory reset"
  8. Tap Power hard key to select option.
  9. Scroll down to select "Yes, delete all user data".
  10. Tap the power button to select. Wiping and formatting data will take a few minutes.
  11. You will return back to the Android recovery screen menu.
  12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Try
Settings / Backup & Reset / Reset
Hi Doug
I press two buttons at the same time on my tablet and a photo goes into my photos
Volume Down and Power buttons at the same time
Cheers
OR
Use a dedicated App
6 Ways To Take Screenshots On Android
Screenshot Capture Android Apps on Google Play
Google Android 4.0 7 inch 1080P Video Capacitive Screen 16GB Tablet PC Logo
34 questions posted
Top Google Android Tablets & eReaders Experts
ray gallant
Dayton Computer
Dayton Computer
FiFo
Are you a Google Android Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Google Android Tablets & eReaders
Most Popular Question
just purchased google android 4 0 m710
  • Tablets & eReaders
