20 Most Recent NEC MobilePro 770 Questions & Answers
2answers
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to http://www.microsoft.com 2. Select "Search microsoft.com" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
10/17/2018 7:46:36 AM • NEC MobilePro... • Answered on Oct 17, 2018
0answers
Wireless internet on NEC mobilepro 770?
dail up or get the serial port cable and run through another pc just a heads up mine has pocket internet explorer and most web pages won't load right.
1/7/2010 7:11:13 PM • NEC MobilePro... • Answered on Jan 07, 2010
I have A MobilePro 770,
Of course you need to load the software and setup a tcp/ip service.
Consult your service provider and manufacturer of phone.
Sorry.
10/19/2009 10:34:18 PM • NEC MobilePro... • Answered on Oct 19, 2009
Please copuld you help me?
you have entered the pin code wrong 3 times now you are required to enter a puk code to reset the pin code.
The puk code is sim card spesific it comes with the sim card when you get it or you can get it by calling your phone service provider of the sim card to get the puk code.
if you have entered the puk code wrong too many times you will make the sim card useless and you will have to contact your phone service provider for a new sim card, it will probably cost.
12/27/2008 10:25:24 AM • NEC MobilePro... • Answered on Dec 27, 2008
2answers
770 going weird
Could you have an alarm set somewhere? If nothing else, I'd back up and do a hard reset. Might be some programs that are lost - don't know for sure. Anything in the units memory will be lost.
11/30/2008 5:10:21 AM • NEC MobilePro... • Answered on Nov 30, 2008
BRAUN shaver Flex intergral 5550
Nothing happen on the LCD of my NEC Mobile Pro 770 and when the technician checked it The flex connector bettween the LCD and the Keyboard was broken. i need to replace it but do not know where to get one. Please inform in case you know.
Thanks a nd regards,
Castro.
10/27/2008 6:09:14 PM • NEC MobilePro... • Answered on Oct 27, 2008
Getting the wirelss to work
it needs to be 16 bit and 802.11b wifi card to work
7/10/2008 4:32:53 AM • NEC MobilePro... • Answered on Jul 10, 2008
Erro 647 when trying to connect 770 to desktop with windows xp
I had the same thing happen to me.. The site below will fix you up just follow all the steps.. Some things are worded slighty different in XP so just use common sense for those things..
Just make sure to set your Computer as HOST when it asks.
Also I could not find the mobile devices or something like that tab in Windows XP but it still worked.
http://www.pocketpcfaq.com/wce/21/windows2000.htm
6/7/2008 6:23:13 AM • NEC MobilePro... • Answered on Jun 07, 2008
Memory card
I use a 6 in 1 scandisk universal adapter that accepts SD and other storage cards. They can be purchased off the internet for about $30.00.
I put in my 1 & 2 gig cards and it works fine
2/8/2008 4:20:45 AM • NEC MobilePro... • Answered on Feb 08, 2008
NEC MobilePro 770
These are older devices, and Lihium-Ion batteries degrade from the date of manufacture. You will most likely need to follow instructions (easy to find on the internet) to "fix" the battery. It needs two new cells.
10/25/2007 7:49:42 PM • NEC MobilePro... • Answered on Oct 25, 2007
Connection problems
Attach the AC power cord or adjust the power saving mode so the unit does not go into "standby" mode. This is caused by the unit going into "standby" mode when data is being transferred.
9/15/2005 3:03:26 PM • NEC MobilePro... • Answered on Sep 15, 2005
Copy of Citrix ICA CE Client
The CE Citrix ICA Client can be downloaded from Citrix.com * From the "Citrix Downloads" section scroll down until you see "Recommended Client Chart". * Look for "Windows CE" on the chart. * Click on "ICA CE Client" to download.
9/15/2005 3:02:54 PM • NEC MobilePro... • Answered on Sep 15, 2005
Change the resolution
No. However, you can change the VGA Out from "Display the same image with LCD (640 x 240)" to 800 x 600 or 640 x 480.
9/15/2005 3:02:14 PM • NEC MobilePro... • Answered on Sep 15, 2005
Lower fidelity voice recording capability
MobilePro 770 units with a serial number before MC-B004P3US-033 may have a lower fidelity voice recording capability. This may cause voice recognition software to not function properly. This issue is not experienced with new units.
9/15/2005 3:01:44 PM • NEC MobilePro... • Answered on Sep 15, 2005
Some errors
Download the ATA PCMCIA/CF-Card update drivers* (file name MP8Pcm.exe) from ftp://ftp.necsam.com/pub/versa/mobilepro/. Click on the link to download. After the files are extracted, follow the installation instructions in Readme.txt. *This module requires 40KB of internal RAM memory. If the MobilePro has been Hard Reset or Main memory has been erased due to main/backup battery low, this module should be re-installed.
9/15/2005 3:01:08 PM • NEC MobilePro... • Answered on Sep 15, 2005
Error message: "Not enough free space to delete 'filename'"
This error occurs because Windows CE first moves the file to the recycle bin before deleting it, and if there is insufficient space, the error message is displayed and the system appears to hang. To resolve this issue, use one or more of the following methods. * Empty the Recycle Bin Use the following steps to empty the Recycle Bin: 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Empty Recycle Bin" 3. Tap "Yes" when asked to confirm the file deletion. * Change the Properties for the Recycle Bin so that files are deleted instead of being moved to the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the check box for "Do not move file to the Recycle Bin, remove immediately on delete". * To make additional space available for the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the slider to the right.
9/15/2005 2:58:00 PM • NEC MobilePro... • Answered on Sep 15, 2005
My MobilePro 770 intermittently stop responding at startup
With the Owner information screen or passwords enabled, it is possible that a deadlock condition can occur as the Graphics, Windowing, and Events Subsystem starts up. The only work around at this time is to disable the owner information screen in Settings/Control Panel/Owner and/or to disable Passwords in Settings/Control Panel/Passwords. This information is also found at Microsoft site at: http://www.microsoft.com/technet/ Article ID: Q260315
9/15/2005 2:55:56 PM • NEC MobilePro... • Answered on Sep 15, 2005
NEC MobilePro 770 Logo
25 questions posted
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
MobilePro NEC
  • MobilePro NEC
Most Popular Question
some errors
  • Computers & Internet
