20 Most Recent
Rollei Prego Micron Exc, Ln, For $30 Yes Read Read Read Questions & Answers
THE CAMERA DISPLAY CARD LOCKED ON IT DISPLAY PANAL .
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Where can I get an
Is it Rollei or Rollie?
Kindly mention your country - Is that UK or US or Germany?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
WarCan you recommend a video
Try Windows Movie Maker its easy to use and its free. If you are looking for something more advanced be prepared to spend a bit of money.
Where can I obtain a
Thanks for using Fixya.
I am not able to locate the model no. of your device. But here is a
link where all the models are listed. Select the model from that list and you will be able to download the manual in english.
Good luck and have a nice day.
Please could you email me
Hello Marion
OK, you will need to supply me with the model and the brand of the camera.
Once i have that information, i will be able to supply you with the manual.
Kind regards
Andrea
How to collapse the lens
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Looking for a replacement battery
You Could Purchase it from :-
http://cgi.ebay.com/Battery-charger-of-Rollei-Prego-dp4200-dp5200-dp6200_W0QQitemZ170375292184QQcmdZViewItemQQptZDigital_Camera_Accessories?hash=item27ab28a518
It is available in Stock and the Cost is $18.96.
Let me know, if needed further assistance.
Hope i helped you.
Rollei camera powers up and then shuts down
I would strongly suggest new, I mean NEW batteries, first.
You may be confident with your current batteries, but don't trust any rechargables you have, as they lose their 'power' (ability to supply enough current at the nominated voltage).
Also, don't trust any cheap batteries you have, definately no carbon type batteries.
Go buy some new Alkaline batteries (Energizer or Duracell, or some cheap Panasonic or Varta alkalines) and then we'll go from there.
This is an important step. Sorry if I'm stating the obvious, but a far far majority of digital camera faults and power related.
Let us know how this works out.
**.The best way to acknowledge contribution is to rate it's relevance.**
