20 Most Recent Nokia 9300 Handheld Questions & Answers
My mobile nokia 9300 shows
the problem was relating to your sim card or sim network ic .check it then go to the option profile and select the general to active
3/14/2015 6:18:15 PM • Nokia 9300... • Answered on Mar 14, 2015
manual
Type your problem for a solution..light lcd not working.
SYSTEM CODE
9/5/2013 10:38:27 AM • Nokia 9300... • Answered on Sep 05, 2013
0answers
I have Nokia 9300, I
i have forgot my lock code of my nokia 9300i
6/23/2013 4:48:25 PM • Nokia 9300... • Answered on Jun 23, 2013
Change Profile of Nokia 9300 from Front Panel
nokia 9300 saya ngalami troubel. ga sengaja saya pencet profil "offline" akhirnya hp bagian depan mati ga mau nyala. kemudian saya setting yang dalam tetapi ga bisa. bagaimana caranya untuk mengembalikan profil semula. tq....
1/27/2013 11:59:38 AM • Nokia 9300... • Answered on Jan 27, 2013
My nokia 9300 has problem
Do you mean keypad and lcd.....
if so change the Coil....for more info contact me on +919742320078
9/12/2011 2:20:38 PM • Nokia 9300... • Answered on Sep 12, 2011
I hve forgot the lock code of my nokia 9300. how
after trai regulation my nokia 9300 locked IMEI:004400571615366 can any one help plsss.. thanks in advance..
9/7/2011 10:31:39 AM • Nokia 9300... • Answered on Sep 07, 2011
My nokia 9300's screen went
First of all, your question is not clear enough for me,but let me conclude what you are saying.
Loosing the internal display depends on LCD and Flex connector that connects the upper and the lower panel. But most problem that i encounter about this mobile is the replacement of Flex connector due to some cut areas along its parts. Outer display is separate from internal display so possible to see the outer display.
This mobile need to fix by an experience techinician because fixing this problem is more complicated to work with, more likely on dismantle,replacing and disassembling the parts than any small type of mobile.I may advice you to bring it to an authorize service center to make this problem.
Regarding your personal data that stack inside your phone, You need a tool to recover all of your important data.Download this link to copy all files coming from the phone and all the way to your computer.
NOKIA PC SUITE DOWNLOAD
Follow this procedure :
1. dowload the link above and locate the download file were save.
2. run the application and install the program,just follow the instruction and wait till the installation is done.
3. open the application and connect the phone thru the computer using data cable or usb cable.
4. wait until the mobile is recognize by computer.
Now you can see all data stored from phone to computer,you can download and transfer them to another phone if applicable.
Please correct me if this is what you try to say.
Best Regards.
7/4/2011 3:36:38 PM • Nokia 9300... • Answered on Jul 04, 2011
Nokia 9300 sim insert poroblem
9300I SIM NOT EXSEPT
6/19/2011 9:29:43 AM • Nokia 9300... • Answered on Jun 19, 2011
I want to master
Hi, the standard master reset code for nokia is 12345. But if fails, you can get the code here for FREE*) :
www.nfader.su
Best regards, Jay
*) need to key in your IMEI #
6/2/2011 10:41:17 AM • Nokia 9300... • Answered on Jun 02, 2011
My nokia9300 is of not
this problem can be by the virus
or due to numerous apps to reduce working memory
try restoring and removing apps
also scan for viruses still problem exists contact your vendor for formatting
5/15/2011 7:18:30 AM • Nokia 9300... • Answered on May 15, 2011
Im using Nokia 5730, everything
HI, MUNABI ,
for nokia handsets lock code is 12345(by default) , but you have already tried for same .
i think some one changed the code .
so lets try another combinations like horizontal , vertical etc. ,(may it work but probably it will noy)
so if you urgentlly needed then you can upadate your software from any nearby service center so you code again reset to 12345.
4/27/2011 10:31:45 AM • Nokia 9300... • Answered on Apr 27, 2011
2answers
I have a nokia 9300
Hello Abhay,
There is no problem in your phone.
You can not view both the display at time.
This feature is not provided in phone by the Nokia.
So you have to access one display at a time.
4/23/2011 6:49:40 AM • Nokia 9300... • Answered on Apr 23, 2011
How to format of nokia
Welcome to Fixya
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
Have a good one!
3/26/2011 6:59:18 AM • Nokia 9300... • Answered on Mar 26, 2011
How do i retrieve deleted text messages on my
Messages -> Folder "Deleted items" should contain things you have deleted.
3/15/2011 1:05:58 PM • Nokia 9300... • Answered on Mar 15, 2011
How do I run a wireless (WLAN)connection on my
A built in wifi simply means that your gadget is equipped with the ability to communicate wirelessly. Yes,it will automatically connect to your internet connection , provided it is able to detect the presence of a wifiaccess point such as a wireless router. These access points are quite common in public places that are considered as wifi hotspots
3/3/2011 6:09:45 PM • Nokia 9300... • Answered on Mar 03, 2011
Hi sir, i have problem with
try to format it via thish code
remove sim and memory
and also battery
press ctrl+shift+f+on off swith and insert battery phone ask u format. try thish
if ur fault solve dont forgate thanx
note:u can lose ur data
2/14/2011 6:50:27 AM • Nokia 9300... • Answered on Feb 14, 2011
Nokia 9300 Handheld Logo
87 questions posted
Popular Products
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Nokia Computers & Internet
Most Popular Question
nokia 9300 sim insert poroblem
  • Computers & Internet
