Is there a Carbon fibre small compact with splitter
Carolyn
-If you are looking for a compact light weight (CF) tripod for video...., that is going to be...., stable & durable (for use with a smaller video camera or a DSLR) & with a mid-level spreader...., I have some bad news for you. They do not exist!!!!!
-You can get a number of tripods that meet some of these requirements..., but not all!!!
-No fear....., it is still possible to get a tripod that is small, light, repairable and with a higher weight capacity and better durability than either of the Manfrotto tripods you mentioned..., but they will not use a mid-level spreader!!!
-Questions for you...., the manfrotto #055CXB has a column that terminates with a flat plate & a 3/8-16" thread. The Manfrotto # MTV502AM tripod has a 75mm bowl mount. Do you use a video head with a flat base or with a 'bowl'?
-If your head has a flat base consider looking at CF tripods from brands such as Sirui (#N2204 or #N3204)..., great value tripod from China..., or products from Gitzo or Really Right Stuff...., (superior products...., and your grandkids will be using them..., but pricey)!!!!
-If your head uses a 75mm bowl mount get the Miller #1501 tripod...., stupidly strong and well supported.
-Bottom line..., with light to mid weight cameras, if you go with a good quality spreaderless tripod that uses 'rotary locks' vs 'quick release' locks...., the leg mechanisms are so superior that you will find that you will get less flex than most tripods with spreaders. They will also be smaller, lighter and allow you to shoot far closer to the ground!!!
Go t a shop that has a good selection of quality tripods and test for leg twist..., you will be converted!!! (note: to test this leg flex..., extend the legs & grab hold of (2) of the tubes near the top 'crown' and then try to move the legs to the left then right...., many will exibit significant flex at the joints!!!!
5/17/2014 8:20:25 AM •
Manfrotto...
Answered
on May 17, 2014
