20 Most Recent OEM Systems ATX P4 350 Watts Power Supply ( Channel Well OEM ) (PS350) Power Supply Questions & Answers
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
OEM Systems ATX... | Answered on Mar 17, 2011
should be written on the power supply on a specs sticker
hop this helps
OEM Systems ATX... | Answered on Jan 03, 2009
this device have many spekers..... none of them works??? do you have volume up??? check if you have no mute button depressed....
check if all speakers are connected to proper connectors....
check users manual, there are always pars, that describing what to do, when problem like that appear... try factory reset
OEM Systems... | Answered on Mar 27, 2014
Most likely your problems is related to driver, especially sound driver. To double check if all the drivers is installed properly, go to: Computer > Right Click > Then select Manage > In the drop down menu on the left choose "Device Manager"
It should show what driver is installed and not yet installed. Do look up your driver at Emachines website for any download. After all driver is installed do reboot the computer.
OEM Systems... | Answered on Nov 18, 2013
It is obviously dying or incapable of supplying a sufficient flow of power to the system. Before it blows, you will want to buy yourself a new one to prevent losing other components within your system. You can find some very good power supplies at this website. Once the page loads, search for: PC Power & Cooling. After the page loads, select, "PC Power & Cooling" on the left under the category, "Manufacturer."
Make sure you find one that exceeds your power needs by about 100-150 Watts. Yes, they are expensive, but you DO NOT want to skimp on the most important aspect of the computer, power. Wen it comes to power, you get what you pay for. Almost all cheap power-supplies will last you one year and then blow. And once they blow, they frequently take other components with them. Components such as motherboards, memory, CPUs, and Video Cards.
The reason behind picking a PC Power & Cooling PSU is rather self-explanatory. Firstly, they have the highest efficiency rating of any single-rail PSU. Secondly the PSU tends to run cool, thus increasing its life span. Thirdly, they are reliable and provide a steady flow of power. All of this equates to a great power supply which will support your system for a long time.
Let me know if I can assist you further or if I need to explain anything mentioned above in more detail.
OEM Systems... | Answered on Mar 25, 2009
The Proscan PBTW274 smart watch does not have a memory card slot. There may be a memory card slot (SD, microSD) in the smartphone/tablet that you have synchronized with the smart watch. If you have a memory card in that phone, then you can use the smart watch app to send photos directly to the SD card instead of the main memory of the phone. The only documentation for the PBTW274 on the product site, https://www.curtisint.com/product/pbtw274/ , is in French. That manual is here: http://legacy.curtisint.com/html/CustService/Manuals/Smart%C2%A0Watch%C2%A0Manual-PBTW274%20French.pdf .
I hope this helps. The manual jumps from the brief mention of the watch features to a long list of tools in the app. I found it unclear at first,as well.
Computers &... | Answered 1 hour ago
Simply, your mystery device isn't connected. Something, usually a firewall, or something in the mystery device hasn't been specifically told to connect to iTunes. Did you sign in to your iTunes / iPlayer account?
Computers &... | Answered 7 hours ago
Very risky. Only do it if you really need to. Most people just think it is a little update to the OS, but it is much more that that. It controls what happens before the operating system loads as soon as the computer switches on, "Hello, do we have a hard drive here, do we have memory, is there a video card here somewhere, is the fan working, can all you components talk to each other"? Then is says "okay, lets see if we can find the operating system and load it in the right order"? If the BIOS Update fails, none of that happens and you have a dead computer. I have only done it once in 30 years of computing, including building my own computers.
We really need FULL make, model, BIOS versions and Operating System in such questions. Our computer Guru Larry will be along soon to have a chat with you about that :>)
How to Update Your Computer's BIOS (with Pictures) - wikiHow
www.wikihow.com > ... > Computers
Open your BIOS manufacturer's support site. Generally, the easiest way to do this is by typing your computer's manufacturer name, your computer's model name, ...
How to update your PC's BIOS ' PCWorld
www.pcworld.com > Software
Sep 29, 2017 - How to update your PC BIOS · 1. Find your current BIOS version: · 2. Enter the UEFI BIOS: · 3. Boot into the UEFI control panel (when possible): · 4.
How to update BIOS on Windows 10 [COMPLETE GUIDE]
windowsreport.com > How To
May 11, 2020 - Flashing your BIOS is an advanced procedure, and if you don't perform it properly you can cause major damage to your PC. In most cases you ...
Computers &... | Answered 8 hours ago
non repair question. go away quietly now
Computers &... | Answered 9 hours ago
The Protection Error 6 error may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
To resolve the error:
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Computers &... | Answered 17 hours ago
Request the manual from Euro-Press.
Computers &... | Answered Yesterday
Yes they are. Printers are one of the most common types of output devices but they can also be considered input devices because of the multi-function printers that include scanners and copiers.
OEM Systems ATX P4 350 Watts Power Supply ( Channel Well OEM ) (PS350) Power Supply Logo
4 questions posted
Top OEM Systems Computers & Internet Experts
Lucky
Bill Boyd
Dayton Computer
Dayton Computer
Are you an OEM Systems Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • OEM Systems Computers & Internet
Most Popular Question
many amps
  • Computers & Internet
