20 Most Recent OEM Systems OEM: 32-bit PCI CMI8738-6 5.1 Channel Sound Card Questions & Answers
There are 2 ways to find your sound card driver
  1. you see the chip on your sound card where driver model write on chip.
  2. You download driver detective and install in the system.
Then you can search the sound card driver.
OEM Systems OEM:... | Answered on Mar 13, 2010
load the motherboard cd and try to re install all the necessary modules for the drivers. if that does not work, get youself Foxcom cd, it is suitable with most motherboards to help you load the sounc card drivers.
thank you
wonder
OEM Systems OEM:... | Answered on Sep 17, 2009
sound card is not working
try this software: http://www.innovative-sol.com/drivermax/
download and install it. Good Luck
OEM Systems OEM:... | Answered on Mar 27, 2009
this device have many spekers..... none of them works??? do you have volume up??? check if you have no mute button depressed....
check if all speakers are connected to proper connectors....
check users manual, there are always pars, that describing what to do, when problem like that appear... try factory reset
OEM Systems... | Answered on Mar 27, 2014
Most likely your problems is related to driver, especially sound driver. To double check if all the drivers is installed properly, go to: Computer > Right Click > Then select Manage > In the drop down menu on the left choose "Device Manager"
It should show what driver is installed and not yet installed. Do look up your driver at Emachines website for any download. After all driver is installed do reboot the computer.
OEM Systems... | Answered on Nov 18, 2013
It is obviously dying or incapable of supplying a sufficient flow of power to the system. Before it blows, you will want to buy yourself a new one to prevent losing other components within your system. You can find some very good power supplies at this website. Once the page loads, search for: PC Power & Cooling. After the page loads, select, "PC Power & Cooling" on the left under the category, "Manufacturer."
Make sure you find one that exceeds your power needs by about 100-150 Watts. Yes, they are expensive, but you DO NOT want to skimp on the most important aspect of the computer, power. Wen it comes to power, you get what you pay for. Almost all cheap power-supplies will last you one year and then blow. And once they blow, they frequently take other components with them. Components such as motherboards, memory, CPUs, and Video Cards.
The reason behind picking a PC Power & Cooling PSU is rather self-explanatory. Firstly, they have the highest efficiency rating of any single-rail PSU. Secondly the PSU tends to run cool, thus increasing its life span. Thirdly, they are reliable and provide a steady flow of power. All of this equates to a great power supply which will support your system for a long time.
Let me know if I can assist you further or if I need to explain anything mentioned above in more detail.
OEM Systems... | Answered on Mar 25, 2009
The Proscan PBTW274 smart watch does not have a memory card slot. There may be a memory card slot (SD, microSD) in the smartphone/tablet that you have synchronized with the smart watch. If you have a memory card in that phone, then you can use the smart watch app to send photos directly to the SD card instead of the main memory of the phone. The only documentation for the PBTW274 on the product site, https://www.curtisint.com/product/pbtw274/ , is in French. That manual is here: http://legacy.curtisint.com/html/CustService/Manuals/Smart%C2%A0Watch%C2%A0Manual-PBTW274%20French.pdf .
I hope this helps. The manual jumps from the brief mention of the watch features to a long list of tools in the app. I found it unclear at first,as well.
Computers &... | Answered 41 minutes ago
Simply, your mystery device isn't connected. Something, usually a firewall, or something in the mystery device hasn't been specifically told to connect to iTunes. Did you sign in to your iTunes / iPlayer account?
Computers &... | Answered 6 hours ago
OEM Systems OEM: 32-bit PCI CMI8738-6 5.1 Channel Sound Card Logo
Popular Tags
14 questions posted
Top OEM Systems Computers & Internet Experts
Lucky
Bill Boyd
Dayton Computer
Dayton Computer
Are you an OEM Systems Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • OEM Systems Computers & Internet
Most Popular Question
sound crad driver hsp56 cmi8738 pci sx
  • Computers & Internet
