20 Most Recent Palm m125 Handheld Questions & Answers
2answers
Hot sync error 8001 with MS outlook
Answers on Chapura PocketMirror errors, Chapura maintains a really good database of fixes for errors with their PocketMirror Outlook PIM conduits. Copied from the site: First, make sure you are running the latest version of PocketMirror version 3.1.7. To check which version you are currently running, please see Chapura FAQ PM089. If you are still receiving the same error after installing the latest version of PocketMirror then continue with the following steps. If Option 1 does not resolve the issue, then move onto Option 2 and so on: Option 1: Run the Outlook 2000/2002/2003 "Detect and Repair" utility (You will need the Office/Outlook CD-ROM). 1. In Outlook click "Help/Detect and Repair". 2. After the repair is complete, reboot your computer and synchronize your handheld. Option 2: If you are running Windows XP and this error is occurring, please perform the steps in Chapura FAQ PM198. Option 3: If this OLE error occurs ONLY when synchronizing with Outlook closed, then please see Chapura FAQ PM053 "Outlook Backup Add-in causes HotSync failure when Outlook is closed." Option 4: If you have a laptop computer and are running Windows 2000/Outlook 2000, this OLE error may be caused if your laptop goes into sleep/hibernate mode when Outlook is open. To fix this problem reboot your computer and try to synchronize your handheld again. In the future make sure Outlook is closed when your computer "hibernates". Option 5: Uninstall and reinstall 3rd party conduits such as the TakeNote, DayNotez, PocketQuicken, QuickWord, Quicksheet, etc. To check for these conduits: 1. Click on the HotSync Manager icon (circular red/blue arrows on the bottom right of your PC screen, see image.) Note: The HotSync Manager icon may be hidden on Windows XP, please click the round white arrow button (see image) to unhide the icon. HotSync Manager Icon Example 2. Click on "Custom". If you see any of the above mentioned program conduits listed in the "Custom" screen ABOVE the PocketMirror conduits (Outlook Calendar, Outlook Contacts, Outlook Tasks & Outlook Notes) then uninstall any of these 3rd party programs. To do this go to "Start/Settings/Control Panel" or "Start/Control Panel" and double-click on Add/Remove programs. Then reinstall these programs from the original source media. Option 6: If you are using Outlook 98/2000, please follow the steps in Chapura FAQ PM108 "How do I change Outlook from "Internet Only" to "Corporate/Workgroup" Mode?"
11/28/2022 7:31:01 AM • Palm m125... • Answered on Nov 28, 2022
manual
0answers
Palm m125 manuals
Be the first to answer 10/20/2010 8:36:15 PM • Palm m125... • Posted on Oct 20, 2010Be the first to answer
I have an old Palm M125 monocrome hand held unit
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
9/28/2009 11:25:05 PM • Palm m125... • Answered on Sep 28, 2009
Goes through hotsynch process, but nothing happens
Install newer version of palm desktop and create new profile.
8/24/2009 12:32:10 AM • Palm m125... • Answered on Aug 24, 2009
My Computer Doesnt Turn On
sgtmelton1, GOOD MORNING. I WAS IN RADAR REPIAR IN THE ARMY AND AIR FORCE. THESE UNITS AT FIRST HAD ANALOG COMPUTORS THEN WERE MADE DIGITAL A FEW YEARS LATER. I BUILT MY ON TOWER, MOTHERBOARD,ETC. I'LL GIVE YOU SOME THINGS TO CHECK THAT MIGHT CHECK AND COULD BE THE PROBLEM. FIRST, IS THE OUT LET HOT. IF SO GO TO THE POWER SUPPLY MODULE, SEE IF IT HAS POWER TO IT AT THE POWER CORD TO IT. IF SO I WOULD REPLACE THE POWER SUPPLY MODULE THEY ARE ABOUT 40.OO DOLLARS. IF THIS DOES'T WORK CHECK THE ON OFF SWITCH ITS SELF. GOOD LUCK
3/19/2009 2:56:01 PM • Palm m125... • Answered on Mar 19, 2009
Palm pilot not syncing while in cradle
You can try cleaning the contacts on both the palm and the cradle. For the Palm itself you can try a small pencil eraser.
For the cradle a little isopropyl alcohol on a cotton swab works well.
Do examine the palm socket closely, sometimes the socket is damaged and may recess into the unit so it cannot seat properly
3/13/2009 7:09:53 PM • Palm m125... • Answered on Mar 13, 2009
Touchscreen application buttons
try this http://www.palm.com/us/support/downloads/m125update.html
10/18/2008 10:33:43 AM • Palm m125... • Answered on Oct 18, 2008
Problem Hot Synching Mail with new version of Outlook
You will need to Uninstall your old Software and Reinstall the new. If yours is like mine, You will come to a page that says "Regular" or Custom" Install. You need to select Custom and will later see two choices for Outlook or Palm.
9/13/2005 2:54:49 PM • Palm m125... • Answered on Sep 13, 2005
Inbox messages syncing mysteriously
Turn off the conduit. It sounds like you dont want the Mail to synchronize at all. You can set the Mail or VersaMail conduit to Do Nothing permanently if you would rather not have mail synchronizing. Go to HotSync icon in your system tray and click on it. Select Custom... Make sure your username is selected and then choose the mail conduit. Set it to Do Nothing and ensure you check the box 'Set as Default'
9/12/2005 6:26:37 PM • Palm m125... • Answered on Sep 12, 2005
Sync with outlook
Change ur sync method. To change the sync from palm desktop to outlook , insert the installiation disc in and then install the pocket mirror conduits conduits that will help u to sync with outlook .
9/11/2005 6:15:31 PM • Palm m125... • Answered on Sep 11, 2005
Hotsynch Email messages
you can use Versamail to sync your email with your handheld
9/11/2005 2:30:23 PM • Palm m125... • Answered on Sep 11, 2005
My palm Jandy doesn't hold the current date and time ....any solutions ?
check the battery, set date & time, update firmware, reset factory settings
9/15/2023 7:34:40 PM • Palm Computers &... • Answered on Sep 15, 2023
52" Casa Vieja Grand Palm Black Damp Rated LED Hugger Fan with Remote turning itself off automatically without touching remote or switch. Is it supposed to or is it faulty?
Does it switch off every time at exactly 20 minutes. I sounds like it has a timer on it? Some outdoor fans and also heaters have a wall button that you press and they time the amount that they are on. https://www.google.com/search?q=52%22+Casa+Vieja+Grand+Palm+Black+Damp+Rated+LED+Hugger+Fan+timer ..
5/4/2023 9:18:30 PM • Palm Computers &... • Answered on May 04, 2023
Palm Pilot M515 PDA getting 'Fatal exception'?
Question edited for clarity. The is help here, but don't forget this is a computer relic from 2001. https://www.google.com/search?q=palm+pilot+m515+fatal+exception ..
3/12/2023 6:45:15 PM • Palm Computers &... • Answered on Mar 12, 2023
I have forgotten my email address to assess my palm phone
You will either have to remember it or factory reset the device and start again with no data.
12/20/2021 6:59:30 PM • Palm Computers &... • Answered on Dec 20, 2021
Extend battery charge life
Rechargeable batteries should last about 3 years. Always buy fresh batteries and see if you can get them with a higher mAh written in the specs. Buy from a battery company and not from somewhere like Amazon. This one is 1250 mAh. https://www.batteryship.com/htmlos/htmlos.cgi/batteryship/catalog.html?item=TUNGSTENTX There are others https://www.google.com/search?q=palm+tx+battery+replacement ..
12/12/2021 1:56:30 PM • Palm Computers &... • Answered on Dec 12, 2021
Does anybody know where I can get software for an old PALM TX pda to download
hi,for computer or the pda?
12/10/2018 7:51:16 PM • Palm Computers &... • Answered on Dec 10, 2018
Palm m125 Handheld Logo
22 questions posted
Popular Products
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
David Payne
David Payne
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Palm Computers & Internet
Most Popular Question
palm pilot not syncing while in cradle
  • Computers & Internet
