20 Most Recent
Palm Zire 21 Handheld Questions & Answers
Outlook Express - no software included with Palm devices but There is third-party software to synchronize the email and Windows Address Book from Outlook Express to Palm OS devices.
Here is a relevant link:
http://www.livepim.com/expressmirror/index.htm - address book conduit to mirror the OE address book to Palm Desktop
Palm Zire 21...
Answered
on Apr 29, 2015
Welcome to Fixya
Sounds like the problem is the LCd screen already. Have you tried doing a hard reset to your palm? The data in your palm can only be transferred using Hotsync. Try uninstall/install the software again to the new computer. May i know the Windows OS of the new computer and what is the model of your Palm.
Thank you for using FIxya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Palm Zire 21...
Answered
on Sep 12, 2011
The display contact wire might be damaged or loose contact.
Palm Zire 21...
Answered
on Feb 24, 2011
Please check all loose wiring connection inside your Zire and get it fixed.
Palm Zire 21...
Answered
on Feb 02, 2011
It is possible that the battery has lost it's skill. If you can plug it in, either by usb to a computer or through the power supply, and the screen shows it is a goner.
The link below is for the palm zire m150 if your interested in replacing the battery yourself. The zire 21 is similar to that model so it's pretty much universal.
http://www.directfix.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=GHT&Category_Code=_ZIRETAKE
Palm Zire 21...
Answered
on Apr 09, 2010
Wait till one is provided by the manufacturer.
Palm Desktop: Windows 7 compatibility
Palm's synchronization software,
Palm Desktop 6.2, was designed for 32-bit versions of Windows XP and Windows Vista. Palm has not done thorough testing with the broad range of third-party equipment running Windows 7 and therefore can't provide assurances about compatibility.
Palm Zire 21...
Answered
on Mar 05, 2010
You may need to do a hard reset.
To perform a hard reset:
1. Press and hold the power button on the front panel of the handheld.
2. While holding the power button, use the tip of an unfolded paper clip (or similar object without a sharp tip) to gently press and release the reset button.
3. Wait for the Palm Powered™ logo to appear; then release the power button.
4. When a message appears on the handheld screen, warning that you are about to erase all the data stored on your handheld, press any other button to perform a soft reset.
Palm Zire 21...
Answered
on Mar 01, 2010
I did a hard re-set and I am hopeful that this has fixed the problem
Thank you for your interest
Jan Lamb
Palm Zire 21...
Answered
on Dec 30, 2009
Use a small torx or if none available, a small screwdriver to gently remove the two screws on the back of the unit. Gently pry the sides away from the back. Open the unit carefully. Remove the two screws securing the system board to the back of the Zire. Gently open( like a book) the boards and screens. Once I did that I turned the Zire on using the switch that is only a small bump on the sytem board. After a gentle tap pr two the touchpad bagan working again. Carefully reassemble the unit and hope it lasts another while. Just in case, do a Hotsync so that your data is saved should this "adjustment" fail to solve your problem.
Palm Zire 21...
Answered
on May 28, 2009
Try changing the HotSync settings
Select Desktop overwrites handheld for each conduit
Palm Zire 21...
Answered
on Mar 20, 2009
do you want to completely delete all the data on your palm zire if so try a hard reset (deletes everything!)
To do a hard reset:
1.
2.
Wait for the Palm PoweredTM logo to appear; then release the power button.
3.
4.
Palm Zire 21...
Answered
on Mar 20, 2009
www.palm.com should have the downloads for PALM DESKTOP.
Palm Zire 21...
Answered
on Feb 27, 2009
No, I'm not willing to pay for you to fix my problem, because I feel that after paying nearly $100.00 for my Palm, that you should at least help me get it so I can use it properly, And since that doesn't seem to be where you are. forget it. Unless you are willing to help me get started with my Palm free.
Thank you
Palm Zire 21...
Answered
on Oct 09, 2008
You should be able to log into hotmail and find your server information.
Palm Zire 21...
Answered
on Jan 11, 2008
To the best of my knowledge, if you don't have a pc backup, you are out of luck....
Sorry to be the bearer of bad news...
Download the Palm Desktop Software and start to use it if you decide to continue using the Zire 21.
The Software is free from Palm.
Palm Zire 21...
Answered
on Sep 26, 2007
