20 Most Recent
SanDisk Cruzer Sdcz36-002g-b35 2 Gb Flash Drive Questions & Answers
I am constantly receiving this message with a micro 2 GB cruzer
I have just experienced this problem with e 32Gb ScanDisk card. Every 40 seconds it dismounts with "The disk was not ejected properly. If possible, always eject a disk before unplugging it or turning it off." and the automatically remounts itself. The card was formatted in my Canon camera and works fine, I also can read the files with iPhoto from the camera, however with a LogiLink card reader it has the above described problem on my MacBoook Pro with MountainLion OS.Its about time Apple that you researched and found a solution!!!!Hans Steller
How do i download from my sandisk card to my computor
Insert the card into a compatible card reader, either built-in to the computer or attached via USB/FireWire. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
Inaccessible memory card
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card,
then remove the memory card from the camera and insert it into an USB memory
card reader. Connect this USB memory card reader and memory card into the USB
port of your working computer. Your computer will see this as an USB Mass
Storage Device or an external storage device; you can then open the folder on the
memory card and copy the photos to your computer.
Memory card reader is a handy device and is inexpensive. You
can copy photos from other cameras and you can also download photos off your
memory card to someone else's computer without the need of installing any
programs.
I have my SanDisk plugged
You need to use the supplied Sansa Media Converter program to convert your photos (and videos) to a format the Sansa can handle. If you don't have the SMC, you can download the Windows version from http://www.megaupload.com/?d=3IPZO6Q0
Just bought a used Pentax Optio 750Z online. Am
Is it a SDHC card? SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
You could try formatting the card. There is a function in the camera menus to do this. If it won't format then it may simply be too high capacity. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manuals for even recent cameras were written.
I JUST GOT A NEW
I do not see your camera model number or brand info in question but I think your camera is bit old one so that is why does not support such big memory card because camera hardware does not support it.
Use 2GB memory card in camera that will be accepted/ supported by camera hardware.
Thanks.
