20 Most Recent Beverage-Air BEVBM23 Commercial Beverage Dispenser Questions & Answers
Call a technician. If you are unsure what a relay and start capacitor are there is no way you should be trying to test them. Stay safe!
Beverage-Air... | Answered on Jul 04, 2012
its plugged, try a piece of say 16 gauge copper wire or a piece of weed wacker trimmer line(best) to snake it out
Beverage-Air... | Answered on Jul 23, 2011
Hi.
If the unit has been off for one year and now it is not starting, you may need a gas recharge, or the suction capillary tube attached to the evaporator coil may need replacement which will also require a recharge. In that case the recharge must be done by a technician. Testing gas pressure is also an operation that cannot be done by the user.
Things that you can check before calling the technician:
See if compressor is starting. If compressor is starting and running most of the time but there is no cold, then gas pressure is low and you need a recharge. If the compressor does not start check volts to the compressor relay. If there is voltage, replace the relay. If compressor is trying to start, but there is clicking and humming noise and motor does not start regularly, replace Overload capacitor and starter relay.
Here a diagram:
To get parts or to book a technician call BEVERAGE_AIR - 3779 Champion Blvd. • Winston-Salem, NC 27105 USA • TEL: (336) 245-6400 • www.beverage-air.com
Regards.
Ginko
Beverage-Air... | Answered on May 30, 2011
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Beverage-Air... | Answered on Apr 01, 2011
electrician do one thing, electricity. If the unit cools, the compressor is running. a power outage should not put the compressor in a "Weaken" state. I would check the starting components. don't overlook your surge protector causing a voltage drop. try running the unit without the protector.
let me know if I can be of any further help.
Beverage-Air... | Answered on Jul 11, 2010
Adjusting the charge or replacing the compressor is not a DIY project, the smell is not likely coming from the regrigerant but from overheated wires.
Beverage-Air... | Answered on Jun 14, 2010
it is just condensation,so if it aint got a drain hole you will need to put silica gel cristals in a cloth bag to soak up condensate.and dry them in the oven as normal.....
try adjusting your co2 pressure down a litle bit it should help
Beverage-Air... | Answered on Jul 04, 2008
in the sealed system you will need to tap it
Beverage-Air... | Answered on May 28, 2008
There is no"filter" underneath. There is. however, a tray underneath your fridge, designed to catch any excess water. If you remove the bottom louvered piece in the front on the fridge, you will find, probably on the right hand side, a tray which is engineered and designed to catch any excess water (as if the fridge were defrosting), but there is no "filter" which I know about. Refrigerators are pretty simple machines. They don't typically require lots of maintenance, but they do require monitoring here and there.
Beverage-Air... | Answered on Jan 18, 2018
you type in their e-mail address and see if you get a reply
most likely you will get an undelivered reply so it will not be legit
Beverage-Air... | Answered on May 27, 2017
Beverage-Air BEVBM23 Commercial Beverage Dispenser Logo
24 questions posted
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Beverage-Air Refrigerators
Most Popular Question
gf 24 beverage air not cold
  • Refrigerators
