20 Most Recent Ricoh ISO1 400DPI Flatbed Scanner Questions & Answers
Microsoft drivers and installers have changed over time. The ISO1 drivers for XP are available here: http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/is01/is01en.htm . Click on the down arrow to download the one for XP and then double click on the exe file.
I hope this helps.
(NT or Win2K drivers can work under XP at times; Win95 drivers are less likely to work even in the compatibility mode.)
Ricoh ISO1... | Answered on Nov 25, 2010
Make a phone call to your Ricoh service rep and report code SC 556.
Ricoh Office... | Answered on Sep 21, 2020
93300
HRB (Head Relay Board)
fuse blown
Mounted on the top part of the carriage unit.
Ricoh Office... | Answered on Sep 15, 2020
Contact your local Ricoh servicer and report code SC556.
Ricoh Office... | Answered on Sep 04, 2020
Your Ricoh printer does not accept re-manufactured toner cartridges.
Just keep using it.
How to Reset a Ricoh to Factory Settings ' It Still Works
https://itstillworks.com > Hardware
Press the "./*" key and the "#" key on the Ricoh copier at the same time and hold for 10 seconds. Nothing will seem to happen until you hold both buttons down for the full 10 seconds. Once 10 seconds is reached, the copier will shut down and begin to re-boot.
Ricoh Office... | Answered on Aug 14, 2020
HD could be defective .tyr disconnect
Ricoh Office... | Answered on Jun 21, 2020
How can I fix Printer Offline errors in Windows 10?
  1. Change printer settings.
  2. Restart the Print Spooler service.
  3. Change printer properties.
  4. Reinstall your printer drivers.
  5. Install the latest updates.
  6. Add a second printer device.
  7. Check if you're using a VPN connection.
https://windowsreport.com/windows-8-printer-offline/
Ricoh Office... | Answered on May 16, 2020
without error code or jam code no one can help u
Ricoh Office... | Answered on May 08, 2020
SC364
Description: TD sensor error black PCU
possible cause:
• TD sensor harness disconnected, loose, defective
• A drawer connector (located on the rear of a development unit) disconnected, loose, defective
• TD sensor defective, replace the PCU
Note: The TD sensor cannot be replaced independently. The PCU must be replaced if the TD sensor is defective
Image transfer unit not set
call service man
Sc 928 memory error , call a ricoh techn
1. Check that the pressure roller thermistor (end) is firmly connected.
2. Replace the pressure roller thermistor (end).
No. Type Details (Symptom, Possible Cause,
Ricoh ISO1 400DPI Flatbed Scanner Logo
2 questions posted
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
IS Ricoh
  • IS Ricoh
Most Popular Question
get ricoh
  • Office Equipment & Supplies
