20 Most Recent Ricoh Aficio 220 Laser Printer Questions & Answers
Our company has a Ricoh
Something is misaligned but even an expert could prolly say what only by looking at it. If that happened to me I'd ask several Ricoh service centres what to do. If you're very lucky, one will tell you over the phone to adjust this or that and hey presto! Otherwise, call out the first centre that seems to really understand the problem and is willing to talk your through some possibilities, rather than just saying they'll come and look...
11/6/2017 12:22:18 PM • Ricoh Aficio 220... • Answered on Nov 06, 2017
DOSE A AFICIO 220 HAVE A HARD DRIVE
Yes it can have a hard drive if copier has print and scan capability
1/28/2014 10:56:30 AM • Ricoh Aficio 220... • Answered on Jan 28, 2014
I lost my manual for ricoh 220 and now whenever i try to make a copy the end product is half of the page.i would like to know how to format my copier or how to set the copier so that i get the exact s
Go to ricoh-usa.com/downloads then in search box enter 220 make sure manual is check below search box . Press search scroll down page click on manual. If need a different language try the ricoh.com website
1/28/2014 10:34:19 AM • Ricoh Aficio 220... • Answered on Jan 28, 2014
I moved my aficio 220 and now when i print i get faded results...i changed the toner but its still the same..what might be causing this..please help...
Lift the green lever as if to replace the toner cartridge, underneath you will see a narrow piece of glass. Pull it out of the machine, and clean it.
1/10/2014 8:43:17 AM • Ricoh Aficio 220... • Answered on Jan 10, 2014
0answers
Hi i get a set counter on my 220 what does that
I think it means that the machine is set up for a key counter , you need to enter the engineers service program mode and set copier 5 - 113 from 1 to zero.If you don't know what you are doing with the service program mode be very careful, if you get lost turn the machine off at its switch then start again.enter service mode through the control panel -- press in sequence yellow button , 1, 0, 7 , press and hold orange button for at least 3 seconds - this should enter mode, repeat if it doesn't. press 1 to select copier OK, 5 to select mode OK , scan through using the previous and next buttons to 113, OKpress 0 then OK to change .exit mode by pressing exit repeatedly until normal screen appears
11/24/2011 1:01:33 PM • Ricoh Aficio 220... • Answered on Nov 24, 2011
I have a Ricoh Aficio 220 and after moving it to a
There is likely toner on the laser shield glass. The laser shield glass is located just below the toner hopper -- should be covered by a small plastic cover held in by 1 screw. Remove this screw, pull off the cover, and gently slide the glass strip out. Clean the glass with a dry lint-free cloth then reinsert it and put the cover back on. Your blank strip should be gone.
3/27/2011 10:21:05 PM • Ricoh Aficio 220... • Answered on Mar 27, 2011
Ricoh Aficio 220 Laser Printer Problem not printing
This is an error related to the laser unit.
Switch off the machine.
Please replace the Polygon mirror motor situated in the laser unit.
Part number AX06-0181.
Good luck and please rate me.
3/1/2011 2:40:49 PM • Ricoh Aficio 220... • Answered on Mar 01, 2011
Can i print from my computer with ricoh aficio
Hi
Yes, you can connect it using a network, parallel cable or a usb cable.
Please let me know if you need more help and do not forget to rate this solution.
2/24/2011 11:14:01 AM • Ricoh Aficio 220... • Answered on Feb 24, 2011
I am working in ricoh
Hi, the message automatically goes away when you install the new photoconductor unit. Until you install the new unit, the message will remain on the screen, but it won't affect operation at all -- you can still use the copier just like normal; that message will just keep popping up.
The machine keeps a counter for how long the photoconductor unit has been in use, and around 60,000 copies or so it displays that message so that you know to replace the unit soon. You can keep the old unit in as long as you want, but eventually you will probably start to see a degradation in copy quality -- faint lines, spotting, dirty background, and/or light copies.
If you don't already have a new photoconductor unit on hand, the EDP code if you want to order one is 410423. I would recommend getting a genuine Ricoh photoconductor, because third-party units have been known to create problems on occasion.
Thanks for using FixYa!
2/7/2011 7:34:46 PM • Ricoh Aficio 220... • Answered on Feb 07, 2011
0answers
Aficio 220 Copier was working fine until I moved
remove the document glass check if the carriage is free, and make sure the place (ground) u kept the machine is balance,oppen the machine remove all the dettacheable unit and fix them back.
8/27/2010 10:08:51 AM • Ricoh Aficio 220... • Answered on Aug 27, 2010
Basically when the Ricoh Aficio
Probably not much you can do yourself....as there are 2 possibilities here. First there is the possibility that you have lost fusing pressure. The fusing unit in this machine using a combination of heat and pressure to "fuse" the toner onto the paper. You may have broken a fuser frame which is a common problem on the 220. This cause the fusing rollers to loose their pressure against each other and thus stop fusing. This usually causes poor or no fusing more on one side than the other. You might want to let me know if the toner wiping off is consistent accross the entire page.
The other possible cause is your thermistor set is bad. The thermistor reds the temperature of the fuser rollers so the machine knows when they are up to the proper temperature for fusing. I some circumstances I have seen them go bad and always register to the machine that the fuser is hot enough when it is not.
Either way you are going to have to be comfortable with removing the fusing unit from the machine and then dis-assembling parts of it in order to repair it. If you are interested in trying this you can reply to this post and I can at least give you the part numbers you might need depending on what you find.
Good Luck and Thank You for using Fixya.
8/26/2010 12:54:31 PM • Ricoh Aficio 220... • Answered on Aug 26, 2010
39 questions posted
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
lost manual ricoh 220 now whenever try
  • Office Equipment & Supplies
