20 Most Recent Canon PowerShot SX40 HS--Black Questions & Answers
Why is my viewfinder black when the camera is on and able to take pictures using the LCD screen?
some camera will inactive the electronic view finder if you shot through the lcd monitor, try to find out in the manual book about shooting trough view finder.
7/27/2013 7:08:42 AM • Canon PowerShot... • Answered on Jul 27, 2013
Canon 12x36 is ii stabilization is not working properly. Stabilization tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
3/21/2024 12:18:08 AM • Canon Cameras • Answered on Mar 21, 2024
Canon Prima BF-800 Zoom Compact Point and Shoot Zoom Camera. I can't use the date feature?
The date feature has to be set up and there is always a way to turn it off and on. I was looking for a manual, but this is not a North America model. This link might work better for you.https://www.google.com/search?q=canon+prima+bf-800+zoom+manualThe Error Codehttps://www.google.com/search?q=canon+prima+bf-800+zoom+hr+ha+errorMake sure the batteries are good!..
2/18/2024 8:48:21 AM • Canon Cameras • Answered on Feb 18, 2024
I have problem with my canon a95 a Change battery but still my camera say me to change a battery
If you are using Nickel Metal Hydride rechargeable batteries, they have come to the end of their lifespan. Buy New or use AA Lithium batteries. https://www.google.com/search?q=canon+a95+battery ..
2/15/2024 10:55:54 PM • Canon Cameras • Answered on Feb 15, 2024
My Canon AV1 only shoots in B mode, the light meter works correctly, and everything else seems fine. Has anyone had the same issue and found a solution?
If your Canon AV-1 is only shooting in Bulb (B) mode, it could be due to a malfunctioning shutter or aperture control. However, since the light meter is working correctly, it is possible that the issue is with the camera's shutter speed dial. The shutter speed dial is located on the top of the camera and should be set to a specific speed when shooting in aperture-priority mode. If the dial is stuck in the Bulb (B) position, then the camera will only shoot in bulb mode. I would recommend taking your camera to a professional camera repair shop to have it inspected and repaired if necessary.
1/21/2024 11:01:27 PM • Canon Cameras • Answered on Jan 21, 2024
Any instructions about repairing Canon Legria HF200?
Real help that is not AI Generated! Articles and instructional videos https://www.google.com/search?q=canon+legria+hf200+clean+lens+and+sensors ..
12/30/2023 9:14:41 PM • Canon Cameras • Answered on Dec 30, 2023
2answers
Canon PowerShot G5 Camera. Can the LCD screen on the Canon G5 be repaired of replaced?
Yes of course. Take it to your local Canon Service Centre. https://www.google.com/search?q=Canon+Camera+Service+Centre ..
12/14/2023 11:09:56 PM • Canon Cameras • Answered on Dec 14, 2023
Best canon ef lens for a canon rp with ef-rf adapter.
Ef85 f 1.8 ISNT to bad fun cheap lens can be a 50mm f 1.8
12/10/2023 9:59:05 AM • Canon Cameras • Answered on Dec 10, 2023
Why wont my 2gb sd card work with my Canon zr200
card max is 8 mb https://www.manualslib.com/manual/24534/Canon-Zr200.html?page=90#manual
10/20/2023 4:59:29 PM • Canon Cameras • Answered on Oct 20, 2023
Hi, My Canon Powershot A480 camera keeps on scrolling by itself
i kindly advice you restart the camera ,it may fix the problem,.Also ensure on the camera's buttons or around the scroll wheel there is no dust .If it persist try to reset factory the camera
9/21/2023 2:54:45 PM • Canon Cameras • Answered on Sep 21, 2023
Canon Digital IXUS 500 5.0MP is not powering on when CF card inserted.
In general Compact Flash Cards have to be formatted within the camera that is using them as they use a format proprietary to that camera. Also there are size limits on cards. If your camera will only take 16 Mb cards and you put a 32 Mb card in, it will not read it. It sees it as 'No Card Present'. I think the other answer is an AI Answer Bot.
9/13/2023 6:47:07 PM • Canon Cameras • Answered on Sep 13, 2023
Why is my Canon FS10 Flash Memory Camcorder flashing red when trying to charge?
i kindly recommend you reset teh camera ,also check battery contacts inside the camera and on the battery itself are clean and free from dirt or corrosion.In addition,you can alos buy a new battery
8/14/2023 10:06:24 AM • Canon Cameras • Answered on Aug 14, 2023
Canon Powershot sticky shutter
'PowerShot is a Range of cameras as opposed to a model. For camera repairs, you really need profession repair as you need to be in a 'clean room'. Check the iFixit page. https://www.google.com/search?q=Canon+Powershot+sticky+shutter https://www.google.com/search?q=Canon+Powershot+Repair+near+me Old style camera
7/9/2023 11:05:18 PM • Canon Cameras • Answered on Jul 09, 2023
How do I change the date/time battery in a Canon GL1.
There is no user serviceable battery. It has a re chargeable cell and charges over time whilst on the main power source.
6/29/2023 2:13:05 PM • Canon Cameras • Answered on Jun 29, 2023
I have a Canon IXY digital 930 IS camera and its FUNC.SET. button(aka ok button) is not working and i want to reset the camera because all functions aren't working properly.so how to reset the camera.
To reset your Canon IXY Digital 930 IS camera, you can follow these steps:
  1. Turn off the camera: Make sure the camera is powered off.
  2. Locate the menu button: On the back of the camera, you should see a button labeled "MENU." This is typically used to access the camera's menu settings.
  3. Press and hold the menu button: With the camera powered off, press and hold the MENU button for a few seconds.
  4. Power on the camera: While still holding the MENU button, press the power button to turn on the camera. Continue holding the MENU button until you see the camera's menu screen.
  5. Reset the camera: Once the menu screen appears, navigate through the menu options using the arrow buttons on the camera. Look for a "Reset" or "Factory Reset" option. The specific location and wording may vary depending on the camera model. Select this option to initiate the reset process.
  6. Confirm the reset: The camera will likely prompt you to confirm the reset action. Follow the on-screen instructions to confirm and proceed with the reset.
  7. Wait for the reset: The camera will perform the reset process, which may take a few moments. Once the reset is complete, the camera settings should be restored to their default values.
6/28/2023 5:34:17 AM • Canon Cameras • Answered on Jun 28, 2023
Canon powershot A530 gives me memory card error works with my 16Mb SD card but not with my new 2GB SD card
If the original card works this could be an issue with the card itself. If you can, connect the 2Gb to a computer and see if it still gives you problems. While you have it connected 'Format' it. This is basically resetting the memory card. Try this. Connect the card to the computer. Open the File Explorer, (the little folder shaped icon), at the very bottom left of the screen. The memory card should be listed in the box on the left side. Right click the card, (press the Right mouse button once). Another box should appear with a list including the word 'Format'. Click it and follow the instructions. When finished use the same Right Click method and 'Eject' the card. This just tells the computer your removing the card. Retry it in your camera.
6/19/2023 9:20:03 AM • Canon Cameras • Answered on Jun 19, 2023
Canon IXY 500 screen goes blank when Memory card is inserted.
Il est fort possible que le Canon IXY 500 ne soit pas en mesure de lire correctement la carte m?moire ou que la carte m?moire soit d?fectueuse. Voici quelques ?tapes que vous pouvez suivre pour r?soudre ce probl?me voici ce qu'il y a ? faire : Veuillez v?rifier que la carte m?moire est ins?r?e correctement dans l'appareil photo. assurez-vous que la carte est bien enclench?e et qu'elle est ins?r?e dans le bon sens. Ensuite, essayez une autre carte m?moire. Si l'?cran de l'appareil photo fonctionne normalement avec une autre carte m?moire, cela signifie que la carte pr?c?dente est d?fectueuse et doit ?tre restaur?e. Bien s?r, formatez la carte m?moire. Il est possible que la carte m?moire ait ?t? format?e pour une utilisation avec un autre appareil photo ou un autre p?riph?rique, ce qui peut causer des probl?mes de compatibilit?. Essayez de formater la carte m?moire dans l'appareil photo avant de l'utiliser. V?rifiez que l'appareil photo est ? jour. Il est possible que l'appareil photo ait besoin d'une mise ? jour du firmware pour prendre en charge la carte m?moire que vous utilisez. V?rifiez le site Web du fabricant pour les mises ? jour du firmware. Je pense que ?a marchera.
2/24/2023 11:32:12 PM • Canon Cameras • Answered on Feb 24, 2023
I have no sound on my Canon IXUS 95 IS
There are a few potential reasons why you may not have any sound when recording a video on your Canon IXUS 95 IS camera:
  1. The camera's microphone may be malfunctioning or damaged. Check to make sure that the microphone is not blocked by anything and that it is enabled in the camera's settings.
  2. The volume may be turned down or muted. Make sure that the volume is turned up and not muted in the camera's settings.
  3. The sound file may be corrupted or missing. Try transferring the video file to your computer and playing it with a different media player to see if the sound works.
  4. The camera may be in a mode that disables sound recording. Check to make sure that you are recording in a mode that allows sound recording, such as the video recording mode.
If none of these solutions work, it is possible that there may be a hardware issue with the camera's microphone. In this case, you may need to bring the camera to a repair shop or contact Canon customer support for assistance.
2/24/2023 9:16:15 AM • Canon Cameras • Answered on Feb 24, 2023
My canon mv940 digital camcorder isnt charging
If your Canon MV940 digital camcorder is not charging, it could be caused by a few different issues:
  1. Check the battery: Make sure the battery is not damaged or worn out. If it has been unused for a few years, it may no longer hold a charge and need to be replaced.
  2. Check the charging port: Make sure the charging port is clean and free of debris. If it is dirty or damaged, it may not be able to charge the battery.
  3. Check the charger: Make sure the charger is working and not damaged. If it is not working, it may need to be replaced.
  4. Check the charging cable: Make sure the charging cable is not damaged or frayed. If it is, it may need to be replaced.
  5. Check the battery compartment: Make sure the battery compartment is clean and free of debris. If it is dirty or damaged, it may not be able to charge the battery.
  6. If none of the above steps work, it is possible that the camcorder has a more serious problem that requires professional service.
It is important to refer to the user manual or contact Canon technical support for further assistance and specific troubleshooting steps for your camcorder model. It is also important to make sure the camcorder is not plugged in before attempting any troubleshooting steps. Due to the age of the device, it might be hard to find a replacement battery for it and you might need to look for an alternative solution such as a third party battery replacement or an external power bank.
1/17/2023 7:09:28 PM • Canon Cameras • Answered on Jan 17, 2023
Canon PowerShot SX40 HS--Black Logo
1 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
viewfinder black when camera able
  • Cameras
