20 Most Recent Sharp " AQUOS 70"" Class / LED / 1080p / 120Hz / HDTV LC70LE732U" Questions & Answers
YOU CAN NOT USING THE REGISTER . ONLY ON THE PC
Sharp Cameras | Answered on Dec 12, 2018
hi there,
this is all i could find out at the moment.
it could be the latching system i am not sure if its electronic latch or spring. start by looking there if its electronic latch take it in to a shop if its spring latch maybe the end of the spring just needs putting back on.
The chances are that a switchcontact or motor is not engaging, and the unit will have to be opened up to be fixed.
Oftentimes, with these older units, switch or relay contacts become oxidized over time, and fail..
all this info i found from or fixya site.
hope this might help you out.
Sharp Cameras | Answered on Nov 04, 2017
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sharp Cameras | Answered on Sep 02, 2016
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sharp Cameras | Answered on Jan 26, 2016
is this a TV , if so it should work with an antenna if you select the proper input type which might be AIR or antenna
Sharp Cameras | Answered on Nov 13, 2015
M stands for macro.this is for extreme close so dont take photos with m displayed unless extreme close
Sharp Cameras | Answered on Jul 06, 2015
There is no tripod mount on this model.
Sharp Cameras | Answered on Apr 27, 2015
Sounds like condensation is forming on the inside of the camera lens or housing glass.
Sharp Cameras | Answered on Jan 18, 2015
it is neither clear what sort of output your cctv cameras produce, nor what sort of input your dvr accepts. but, for the most part, dvrs record digital tv signals, whereas cctv cameras output analogue signals. so, even though you may be able to plug a cctv camera "straight" into a tv via a scart connector, it is unlikely that any scart connectors on a dvr have the necessary circuitry to accept such signals.
Sharp Cameras | Answered on Dec 01, 2014
Sharp " AQUOS 70"" Class / LED / 1080p / 120Hz / HDTV LC70LE732U" Logo
5 questions posted
Top Sharp Cameras Experts
Marvin
Marvin
tylerbell49
Level 1 Expert
NOEL
NOEL
Are you a Sharp Camera Expert? Answer questions, earn points and help others
View Most Popular
Sharp Cameras
  • Sharp Cameras
Most Popular Question
screen not full tv
  • Cameras
