20 Most Recent
Canon PowerShot SX40 HS Digital Camera 2GB Memory Card Camera/Lens Questions & Answers
Battery is charged. Camera will not turn on
Simple diagnosis, battery is not powering the camera. There are many possible reasons. If you value you camera, don't attempt anything - simply bring it to a compatible licensed service agent for a check up.
Canon sx40hs windows 8
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
Sx40 hs not focusing for all shots
Hi Brian. First you have to narrow the problem down. Is it your camera or the lens that's producing the problems. Can you try a friends' lens on your camera to see if it still malfunctions? if it does then it's your camera body. Alternatively you could try your lens on a friends' camera to see if he gets the same problem.
Are you using all the focussing points? If you are then this might be the problem because the focus points are spread across the viewfinder and if one of the points sees an object that is nearest to the camera, it will focus on that.
Try usng only the centre focus point and use the focus lock to try and get good focus. Hope this helps.
Canon 12x36 is ii stabilization is not working properly. Stabilization
tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
Canon Digital IXUS 500 5.0MP is not powering on when CF card inserted.
In general Compact Flash Cards have to be formatted within the camera that is using them as they use a format proprietary to that camera. Also there are size limits on cards. If your camera will only take 16 Mb cards and you put a 32 Mb card in, it will not read it. It sees it as 'No Card Present'.
I think the other answer is an AI Answer Bot.
