20 Most Recent Yukon Digital NV Ranger Pro 5x42 Binoculars Questions & Answers
0answers
Unable to see
Be the first to answer 10/25/2013 4:31:59 AM • Yukon Optics • Posted on Oct 25, 2013Be the first to answer
Yukon 2.5 x50 nvrs tactical
Hello, don't worry about it. It is HV to the image intensifier tube. The battery voltage goes through control circuit then to ccfl inverter (here is were dc voltage is switch on and off and switch dc voltage is step up by toroid coil that has two input and only two out puts). By impulsing the coil with two different switch dc voltage on the input this make the current lag the two different phase voltage by 90 degrees. Here is where the strange noise is coming from. The toroid coil is encased in iron case and if half of this iron case is loose, it makes case vibrate so the noise.
Now, the voltage come out of the toroid coil is switching dc (one could call it AC because that what AC voltage is, it switch between positive to negative) this voltage is about 300 to 900 switching DC voltage. This voltage will be applied to a 1/2 wave voltage multiplier (this voltage multiplier with have anywhere four four stages to 10 stages depend on what the input voltage to multiplier is.
Low the voltage out of the ccfl inverter the more stages the multiplier will have.
Now, the voltage multiplier will double the voltage per stage to need image intensifier tube voltage of 12000 to 45000 volts---DC switching or AC what ever one wants to call it. This voltage will bit you but it doesn't have a lot current associated with it, the current would be in the 10 to 15 ua (micro-amps) 1/10X6 amps.
Now, you know. GB...stewbison
9/24/2011 8:53:00 PM • Yukon Optics • Answered on Sep 24, 2011
3answers
How do I change Language on a sokkia set 250x total station
hi deshwashin error vod d13 brandt thnks
4/4/2024 7:00:30 AM • Optics • Answered on Apr 04, 2024
Need manual for edu science star tracker telescope
Yes I do
1/13/2024 1:28:24 PM • Optics • Answered on Jan 13, 2024
Tascos riflescope 3x9x50 adjutment caps
Visit your local gun shop and have them order them.
10/17/2023 10:13:50 PM • Optics • Answered on Oct 17, 2023
I need firing order for a 1981 Johnson seahorse 115
its just 1-2-3-4- with the port bank being 2-4 starting at the top and the starboard side being 1-3. They're all the same be it V-4 or V-6. 6=123456 60* and 90* are the same
5/31/2023 9:13:49 PM • Optics • Answered on May 31, 2023
Prime bluetooth wireless keyboard is not working
If the batteries are worn out or have not be put in properly. You may have to resync your devices the the USB receiver.
5/1/2023 6:31:18 AM • Optics • Answered on May 01, 2023
Franklin Chef FCE-42R Espresso Machine. How do I get a owner's manual for it please?
Question edited for clarity. Duplicate Question deleted. It doesn't seem to be available https://www.google.com/search?q=Franklin+Chef+FCE-42R+manual ..
3/13/2023 6:44:38 PM • Optics • Answered on Mar 13, 2023
Cross hairs do not adjust. Tell me what to do please?
All question need FULL 'make model (what it is)'. You posted to optics, so let's guess is a telescopic rifle sight? It is impossible to see and movement as the crosshairs move such a tiny amount. Half a millimetre in the sight is 10 feet at the target. The only way to zero in sights is on a fixed bench rest at the range. If you really think they are faulty, return them to the maker for repair.
3/8/2023 1:07:51 AM • Optics • Answered on Mar 08, 2023
I have a NexStar 90GT with no hand control, a replacement will cost $135, is it worth it to buy for this telescope?
Whether or not it's worth it to buy a replacement hand control for your NexStar 90GT telescope depends on a few factors:
  1. How often do you use the telescope? If you use it frequently and rely on the hand control to find objects in the sky, then it may be worth it to invest in a replacement.
  2. How important is the hand control to your observing experience? If you're comfortable manually finding objects in the sky and don't necessarily need the hand control, then it may not be worth the expense.
  3. Can you find a cheaper alternative to the official replacement? Sometimes, third-party sellers may offer hand controls that are compatible with your telescope at a lower price.
Ultimately, it's up to you to decide whether the cost of the replacement hand control is worth it based on your individual needs and preferences.
2/25/2023 7:57:32 PM • Optics • Answered on Feb 25, 2023
Hello, I an desperately looking for replacement rubber eye piece for my SIFT SWPA 7x50...
I can find no reference to a company called 'SIFT' and a model called 'SWPA', so sourcing is difficult. You can buy rubber eyepieces easily. https://www.google.com/search?q=7x50+binocular+eyepieces The search query would be make model eye piece replacement ..
2/23/2023 9:24:12 AM • Optics • Answered on Feb 23, 2023
4answers
No zoom function on a kalimar power zoom scope,
larry389's so-called solution is not a solution... just an opinion to which each individual is entitled... even when not correct! I've used a Zeika Opt. Co. Power Zoom Binocular No.25361 for over 25 years since inheriting them from my father who purchased them in early 1970. To say the least, treated carefully and with respect for the delicate instrument that they are, they've been wonderful and still work perfectly fine. Perhaps Larry's experience is based upon handling them like junk and, therefore, reaping what he has sewn.
2/6/2023 8:12:30 AM • Optics • Answered on Feb 06, 2023
I have a Whirlpool clean top stove with a cracked stove top. Can I get a replacement top & is it easy to install or do I need a professional to install it?
Yes, you can get a replacement stove top for your Whirlpool clean top stove, and it depends on the model and the availability of parts. You may contact Whirlpool customer service or check with a local appliance parts supplier to see if they have the replacement stove top in stock. As for the installation, it will depend on your level of experience and comfort working with appliances, as well as the specific model of your stove. Some stove tops may be relatively easy to install, while others may be more complex and require professional installation. Generally speaking, installing a replacement stove top can be a difficult and complex task that requires a certain level of technical knowledge and expertise. It's recommended to consult the stove's user manual or contact Whirlpool customer service for assistance with installation instructions or to find a professional to do the installation.
1/24/2023 8:29:55 AM • Optics • Answered on Jan 24, 2023
Yukon Digital NV Ranger Pro 5x42 Binoculars Logo
1 questions posted
Top Yukon Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Yukon Optic Expert? Answer questions, earn points and help others
View Most Popular
Yukon Optics
  • Yukon Optics
Most Popular Question
green light comes but no picture best
  • Optics
