20 Most Recent
Sony Ericsson Xperia Ray ST18a Smartphone Unlocked Questions & Answers
Xperia ray cannot turn on
sounds like you have damaged the screen some how by removing the battery or even worse the motherboard would you not upgrade your phone Android 4.0 i well out of date. 7.01 is running now
Unlock xperia ray
Hi visit
Theunlockarena.com to unlock your Sony Ericsson xperia ray from telus network .Here they ask you the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile .
Sony Hbd tz510 remote code
The remote control code for Sony HBD-TZ510 home theater system may vary depending on the brand of the remote you are using. Here are a few common remote control codes that may work:
To program your remote, follow these steps:
- Turn on your Sony HBD-TZ510 home theater system.
- Press and hold the "Code Search" button on your remote control until the indicator light illuminates.
- Press the "DVD" or "AUX" button on your remote to select the device you want to program.
- Enter the four-digit code using the number buttons on your remote.
- Press the "Power" button to test if the code is correct. The device should turn off if the code is correct.
- If the device turns off, press the "Enter" button to save the code. The indicator light will turn off.
- If the device does not turn off, repeat steps 4-6 with a different code until you find the correct one.
Note: If you do not have the original remote control that came with your Sony HBD-TZ510, you may need to purchase a universal remote control that is compatible with your device.
I need to know how to use rm ed007 remote to set up my sony dvd to play on sony bravia tv
The "rm ed007" remote that you mentioned is most likely a universal remote control, which can be programmed to control multiple devices, including your Sony DVD player and Sony Bravia TV.
To program the remote to control your Sony DVD player, you can follow these steps:
- Turn on your Sony DVD player.
- Locate the code for your Sony DVD player in the code list provided with the universal remote.
- Press and hold the "Code Search" or "Setup" button on the universal remote until the indicator light turns on.
- Enter the code for your Sony DVD player using the number buttons on the remote.
- Test the buttons on the remote to make sure that they are controlling the Sony DVD player as expected.
To program the remote to control your Sony Bravia TV, you can follow these steps:
- Turn on your Sony Bravia TV.
- Locate the code for your Sony Bravia TV in the code list provided with the universal remote.
- Enter the code for your Sony Bravia TV using the number buttons on the remote.
- Test the buttons on the remote to make sure that they are controlling the Sony Bravia TV as expected.
How do I charge my Sony PSP 3000 with the USB cable when it's dead
Unless you have enabled the actual USB charge settings on the PSP you probably won't be able to charge it via a USB cable.
The simplest solution here is to buy a replacement mains charger. They are usually reasonably cheap to buy for a decent quality one. I personally would avoid the really cheap ones as they are not always as good a quality as an original Sony charger.
Another option is to buy a Docking Station for the PSP. Some of these are a table top stand that plugs into the mains electric supply. You then sit the PSP into it, attach a short power wire from the stand and leave it to charge as normal. There are other versions where you have to remove the battery from the PSP to charge it.
The batteries are actually quite easy to remove and replace so you could consider buying a spare battery as well as a backup.
